Physical dimensions of the small ARB recovery bag
Discussion in 'Off-Roading & Trails' started by OZ-T, Dec 27, 2012.
  1. Dec 27, 2012 at 2:27 PM
    OZ-T
    OZ-T [OP] You are going backwards
    Peter North
    British Columbia
  2. Dec 27, 2012 at 2:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Dec 27, 2012 at 2:42 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I know you're looking for the exact, but going off a normal tow strap size and the picture, it looks to be +/- 12'' by 12''. Or about 30cm by 30cm for you silly Canadians.
  4. Dec 27, 2012 at 2:43 PM
    OZ-T
    Peter North
    British Columbia
    I'm mostly interested in the depth
    and accurate measurements ;)
  5. Dec 27, 2012 at 2:44 PM
    CanisLupus
    Stokesdale | NC
  6. Dec 27, 2012 at 2:49 PM
    OZ-T
    Peter North
    British Columbia
  7. Dec 27, 2012 at 2:49 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    aboot yea by so by 'ay
    just make sure it matches your touke and your mukluks
    no problem
  8. Dec 27, 2012 at 2:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Dec 27, 2012 at 2:50 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    42 if you get the one with a towel
  10. Dec 27, 2012 at 2:51 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    11
  11. Dec 27, 2012 at 3:02 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Itll be whatever depth you decide after you realize the stock bag is too small to fit an extra set of gloves and pocket shovel so you buy a new bag and dump the contents into your new bigger bag and throw the original out. Sooo check the tag when you stop in at homedepot.
  12. Dec 27, 2012 at 3:08 PM
    ImplicitlyAlberta
    David
    edmonton
    Heres a better pic with measurements.
    Hope this helps.
  13. Dec 27, 2012 at 3:09 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  14. Dec 27, 2012 at 3:58 PM
    OZ-T
    Peter North
    British Columbia
    The bag is going to be going in a specific place in the truck so the dimensions are set
    May look at the compact bag as well
  15. Dec 27, 2012 at 3:59 PM
    tinker_troy
    T R O Y
    WY/SD
    Wait... isn't rep talk a bannable offense Mr. 4x4?
  16. Dec 27, 2012 at 4:00 PM
    OZ-T
    Peter North
    British Columbia
    Rep
    Rep
    Rep
  17. Dec 27, 2012 at 4:01 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    +1 when I get to a computer as well...I mean....:spy:
  18. Dec 27, 2012 at 4:22 PM
    OZ-T
    Peter North
    British Columbia
    Can anyone tell me if the bags have a solid bottom
  19. Dec 27, 2012 at 4:26 PM
    JimBeam
    JB
    2015 Tundra
    Wouldn't be much of a bag without a bottom...then it would be a recovery gear cover
  20. Dec 27, 2012 at 4:32 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
