PIA 510's
Discussion in 'Product Reviews' started by XXXX, Jan 3, 2012.
  1. Jan 3, 2012 at 5:22 PM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    They suck and I personally know many people locally that have had issues. IMO they are overpriced under engineered POS lights. They leak like crazy and if your driving with them on and happen to hit some water in a puddle the lenses crack!
    Don't waste your hard earned money if you expect a light that can handle offroad conditions. Stock Toyota fogs are 100% better.
    If you mall crawl and yours are A-OK that's great I don't want to hear it. My review is for offroad vehicle use only.
    Here is what PIA's website says regarding "trouble shooting" and I wish I read it before buying (in red).
    My lamps have water in them for the third time,
    how can I stop this from happening?
    Some moisture inside the lamp is normal. The lamp should dry out after a few minutes of operation. If it doesn't, check the following:
    1) The lens may be upside down. The PIAA name must read right side up so the vent on the bottom can drain. 2) The lens/reflector unit may not be mounted tight against the lamp housing. Loosen, then re-tighten the screws. 3) The gasket may be twisted or pinched. Some gaskets have a vent gap.Make sure it's on the bottom. 4) Lamps with a "Snorkel" type wiring grommet in the back of the housing must have the opening facing down. 5) 9O Pro lamps have a vent on the back of the housing in the center. The opening must be facing down. Water leaks through an obvious gap in the sealant or from a loose lens are defects covered under warranty.
    My reply rant to their trouble shooting bullcrap
    1) My lights were installed correctly - not upside down.
    2) My lights were put together by PIA. WTF should I need to check the housing? Oh and it was loose.
    3) Mine have no vent but were installed by PIA incorrectly and don't sit flat.
    4) Yes mine have the vent facing down
    5) N/A
    So here is my proof they blow...literally they blow bulbs
    dry as can be
    great seals
    quality
    engineered to perfection
    great paint
    clean as a whistle inside
    and some new Narva Rangepower 50 bulbs because I refuse to buy anything from PIA ever again + they are a much better bulb at the same price
    Hope this helps some people avoid wasting their money. IMO any light would be better. Ive had $10 Harbor Freight lights leak less - and they were turned backwards in my truck bed.
  2. Jan 3, 2012 at 5:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You mad
  3. Jan 3, 2012 at 5:26 PM
    XXXX
    sKiP
    05 Prius
    $180 on POS lights....yes I'm mad. I'm going to flood their fakebook page with happy thoughts next.
  4. Jan 3, 2012 at 5:28 PM
    OZ-T
    Peter North
    British Columbia
    I guess the 540's are probably the same , no ?
  5. Jan 3, 2012 at 5:30 PM
    XXXX
    sKiP
    05 Prius
    I'm sure all their 5XX models suck. You will have plenty of time to seal yours up thought.
    I recommend 100% silicone so you can get back into them for bulb replacement. Don't forget to fill in the breather tube with silicone as well.
  6. Jan 3, 2012 at 6:03 PM
    OZ-T
    Peter North
    British Columbia
    Thanks B
  7. Jan 3, 2012 at 6:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    PIAA sucks, and has for a few years. They used to sell some quality (kinda) shit, but now I would buy walmart lights before PIAA shit.
  8. Jan 3, 2012 at 6:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    PIAA's customer service is horrible. You didn't by any chance speak to some jackass named Alan who works for PIAA did you?
    http://www.tacomaworld.com/forum/vendor-reviews/172551-piaa-customer-service.html
    And OZ, the 540 fog lights aren't worth the money. The light output is pathetic, they don't even come close to the factory fogs. I'm happy with the 520 driving lights though. They're bright as hell!
  9. Jan 3, 2012 at 6:47 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    oh yeah, i know Alan allright (i know we talked about this guy in another thread). i think he could single handedly put piaa out of business.
    i had 525's on my jeep for 6 years, and when i finally did take them off, they were kinda caked with the same dirt and crud inside as the OP's (they still worked), but my jeep went places that no light would have probably survived. they were ultimately done in by my wife's parking job at the train station. cracked the lens. i tried buying a replacement lens but piaa changed the design. i wound up getting a no charge new set of 525's from them because of that recently (which i just sold here on tw) so i can't knock piaa TOO badly.
  10. Jan 3, 2012 at 6:51 PM
    OZ-T
    Peter North
    British Columbia
    Well , I already bought them
  11. Jan 3, 2012 at 6:54 PM
    Pugga
    Massachusetts
    I mean... they're great! Best lights I've ever had :rolleyes:
    Hopefully mine are just bummed, I bought them used and have not been impressed with them. Sorry to break it to you OZ...
  12. Jan 3, 2012 at 6:56 PM
    OZ-T
    Peter North
    British Columbia
    It's OK
    If they are too dim I can always get something else and use them as additional back up lights
  13. Jan 4, 2012 at 4:58 AM
    Pugga
    Massachusetts
    Someone did manage to retrofit the PIAA's with HID's and I guess they were pretty bright. I think he used 510's though and it's tough to swallow cutting up $200 lights.
  14. Jan 4, 2012 at 9:00 AM
    XXXX
    sKiP
    05 Prius
    If you guys aren't happy with the output try throwing in a higher wattage bulb from another manufacturer.
    I'm running Narva Rangepower 50's in my headlights and fogs and they blow away Sylvania silverstars at the same wattage and same price point.
    One thing is that they are NOT DOT approved....they are European and meet their standards.
    Here's my source http://candlepowerinc.com/
  15. Jan 4, 2012 at 9:00 AM
    XXXX
    sKiP
    05 Prius
    Jlink
    He's one of the local guys I was talking about in the OP. His one has 1" of water in it currently :(
  16. Feb 6, 2012 at 11:16 AM
    XXXX
    sKiP
    05 Prius
    dbrfan likes this.
  17. Mar 21, 2012 at 3:48 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    :mad:
    I just bought the 520's should i take them back?
  18. Mar 21, 2012 at 3:50 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  19. Mar 21, 2012 at 5:17 PM
    XXXX
    sKiP
    05 Prius
    That's totally up to you. I would advise against getting them wet though cause they leak and the lenses crack. Look on the good side though once the bulbs blow from getting wet they won't get hot enough to crack the lenses so that's good :D
    Nice. Just sucks they are only 2-3/16" and everyone has 4" or larger holes.
  20. Mar 21, 2012 at 5:20 PM
    Pugga
    Massachusetts
    Sounds like you should avoid deep water crossings but as far as light output goes, I love my 520s. I've got 4 520 driving lights on the front of mine.
