PIAA 510 Fogs and Hella backup lights installed
Discussion in 'Lighting' started by RobZ71LM7, Dec 22, 2010.
  1. Dec 22, 2010 at 3:33 PM
    RobZ71LM7
    RobZ71LM7 [OP] Member
    Mount Washington, KY
    09 Tacoma Reg Cab, 2.7L 5-speed
    Just installed PIAA 510's in the factory location with the provided harness. They work great and the included harness is nice. I was concerned about mounting into the plastic bumper at first, but it ended up working nicely. I removed the plastic inserts and set the stock PIAA bracket in the center between the two bulges I cut the hole with a 90* air powered angle grinder and burr bit. I tossed the factory mounting nut and placed two large fender washers underneath along with a flanged M10 nut to spread the clamping force over a larger area. They're very secure.
    I mounted the relays for both lights into two unused M8 threaded holes on the driver's side inner fender. I used "mini" fuse holders since they are the same type fuse as used elsewhere on the truck.
    I ditched the factory 16 ga wiring for the Hella fogs/rear backup lights and upgraded to 14 ga and ran it down the driver's side frame rail. They are grounded on a stud behind the driver's side taillight.
    I used an amber switch for the front lights and a red switch for the rear lights both from Oznium. They energize the relays with power from the under dash fuse block which is only hot when the key is in the "on" position.
    PIAA 510 Plasma Ion Fog Lamp
    http://www.amazon.com/PIAA-5161-Pla..._1?s=automotive&ie=UTF8&qid=1293059267&sr=1-1
    Hella Optilux 1200 Fog lights (used as backup lights)
    http://www.amazon.com/Hella-H71010281-Optilux-Rectangular-Halogen/dp/B0002MA3NK
  2. Dec 22, 2010 at 3:52 PM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    nice to see a decent looking option for the factory fog location, I think you may have convinced me to look into those.
  3. Dec 23, 2010 at 6:19 PM
    gone2baja
    gone2baja Member
    Mark
    AZ
    06 Access cab W/off road package
    The lights look great, I also like the fact they nicely in the factory location.
    Did you notice a noticeable improvement over the stock units?
    It really looks like a neat and clean install it looks like a nice upgrade.
  4. Dec 23, 2010 at 7:01 PM
    RobZ71LM7
    I didn't have factory fogs before the PIAA's. I had placed an order on eBay for the ~$100 Chinese knock-offs of the OEM fogs. But they were cancelled and I'm glad as these fogs fit nicely and are really well built. I think $100 is too much to pay for Chinese copies. Just be sure to leave an air gap around the housings and plastic. They get really hot even in 30* F weather.
