PIAA 540 install help
Discussion in 'Lighting' started by Kmacafee, Aug 25, 2011.
  1. Aug 25, 2011 at 1:29 PM
    Kmacafee
    Kmacafee [OP] Well-Known Member
    Greetings
    I have searched the threads but could not find what I was looking for so I hope someone can help. I have a 2011 TRD Access Cab that I just installed new Aluminess bumpers on. I am trying to install PIAA 540 driving lights and based on what other people have told me, one should be able to use the existing relay that powered the stock fogs. I simply hooked the PIAA wires to the fog light harness and they do not work.
    Do you have to use the PIAA harness and that stupid remote switch? I can't believe the PIAA lights have any different requirements than the stock ones but hope some of the guru's here can set me straight.
    Thanks in advance for any words of wisdom.
    Cheers
    Kevin MacAfee
  2. Aug 25, 2011 at 1:35 PM
    Kmacafee
    I double checked the wiring. I did turn on the key, depressed the fog light switch and nada.
  3. Aug 25, 2011 at 1:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There shouldn't be anything different about the PIAA set-up vs. stock wiring. They do draw more power though, did it blow a fuse when you hooked them up to the stock wiring?
  4. Aug 25, 2011 at 3:08 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  5. Aug 25, 2011 at 3:24 PM
    Kmacafee
    I wired direct from factory harness to PIAA's. It appears Toyota used 20 gauge wire and PIAA uses 18 but its hard to believe thats the issue.
    Whenever you push the standard fog light switch, the fuse blows. I may just use the harness.
  6. Aug 25, 2011 at 3:31 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have PIAA 520 driving lights behind my grill and I used the standard switch the PIAA came with but just the other week, I swapped it with this switch which fits into our stock slots with minimum trimming. The switch also comes lit if you want. I installed a lighted one and I love it!!
    http://www.oznium.com/gsw-45
  7. Oct 29, 2011 at 12:45 PM
    TxCavScout
    TxCavScout New Member
    Wherever Uncle Sam sets me down..
    '11 TRD SP 4x4
    Just installed my 510's in the same manner as the OP, blows the 15A fuse. Tried a 30A and still blows the fuse. Any ideas? :confused:
