Picked up an old air compressor and need help
Discussion in 'Off-Topic Discussion' started by Rosscopeeko, Jan 10, 2015.
  1. Jan 14, 2015 at 8:00 PM
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    How do you do that?
  2. Jan 15, 2015 at 6:16 AM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    Cool. Glad you got it going again.
  3. Jan 15, 2015 at 7:05 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    It is my understanding that to hydrostatic test an air tank, it is filled with water with colored dye to the "test" pressure which is higher than the "working" pressure. If no leaks or drop in pressure is observed over time, the tank is considered safe for a specific time period. For safety, the tank under test is usually placed in a larger container in the unlikely event of a catastrophic failure under pressure.
  4. Jan 18, 2015 at 12:37 PM
    Rosscopeeko
    Rosscopeeko [OP] Well-Known Member
    BC
    08 DC LB 4x4 sport
    Shadetree is pretty much right. You fill the tank with water, right full with no air space. Get a reducer fitting that goes from a tank port, down to a zerk fitting. Hook your grease gun up and pump slowly to reach 1.5x's the tank working pressure that's stamped on it. Some say 1.3x's. You should also have a ball valve to release the pressure when you're done.
  5. Jan 18, 2015 at 6:03 PM
    gozar
    Arizona
    Thanks for the explanation guys.
  6. Jan 18, 2015 at 6:46 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Don't forget to remove and plug the safety relief port. Test won't work with that in place.
