pics of 1.75" lift and 265/75/16???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDfarmerTN, Feb 17, 2012.
  1. Feb 17, 2012 at 9:53 PM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    wna see pics of trucks with billys at 1.75 and some 265/75/16 tires, preferably aftermarket black ones, but anything helps
  2. Feb 17, 2012 at 9:57 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I have some...but can't post from my phone. Look at the signature though.
  3. Feb 20, 2012 at 9:04 PM
    adanfon
    adanfon YNWA
    Adán
    Visalia, CA
    '11 Tacoma DCLB 4x4
    well theyre not black rims but it meets your other requirements...
  4. Feb 23, 2012 at 9:43 AM
    eforward
    eforward New Member
    Bozeman, MT
    11 SR5 Longbed
    OME 885 1/4 top plate & 5100, toy tec aal & TSB, ARB up front w/winch
    How is the ride at 1.75" and 1/4" top plate spacer?
  5. Feb 23, 2012 at 9:54 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    that's one of the most recent I have, sorry for the quality, i took it with a toaster oven
    265/75/16 AT/KO's. TSB 4 leaf, billys @1.75. I think the rear in person looks like it sits down a bit, but in pictures it looks level. I have a tool box w/ 150# chain in it, tow straps, tie downs, axe, various other stuff that isn't necessary but i have a tool box so i keep it in there.
  6. Feb 23, 2012 at 10:42 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    did you remove your center caps or did you paint them black.. cant tell from the pics? i thought about painting mine but wasnt sure if it would look good
  7. Feb 23, 2012 at 10:48 AM
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    i removed them, i felt like w/ them on it made the wheel look "flat" with out them it gives it a bit of depth. Quick suggestion, get some flat black and paint your drums, it'll look significantly better than the surface rust they tend to generate
  8. Feb 23, 2012 at 11:14 AM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    looks good
  9. Feb 23, 2012 at 12:53 PM
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    thansk man
  10. Feb 23, 2012 at 12:56 PM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Not black but the same spec's...........
  11. Feb 24, 2012 at 7:19 PM
    adanfon
    adanfon YNWA
    Adán
    Visalia, CA
    '11 Tacoma DCLB 4x4
    its good i like it way better than when it was at 2.5.
  12. Jul 9, 2012 at 11:18 PM
    Redtaco704
    Redtaco704 Well-Known Member
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Bilstein 5100's all around, Pro-Comp AAL, Pioneer in Dash DVD, Image Dynamics Component speakers, Custom 10" sub enclosure
    So are you running the bilsteins at 1.75 and with a 1/4" spacer on each side? Any alignment issues?
  13. Jul 9, 2012 at 11:24 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    same on the 1.75 plus toytec top plates
  14. Jul 10, 2012 at 7:21 AM
    johnreg
    johnreg Active Member
    Republic of Brackendale, BC Canada
    SR5 4WD
    Billys 5100 all around Front set at 1.75
    Bilsteins all around, front set at 1.75, 265 75R 16 on stock painted wheels
