Pics of my Old Man EMU (OME) lift and Total Chaos UCA intstall.
Discussion in 'Suspension' started by Sandfire, Oct 23, 2009.
  1. Oct 23, 2009 at 3:00 PM
    Sandfire
    Sandfire [OP] Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    First, thanks to Chris 4x4 and others who have posted helpful threads, I took the laptop to the garage and consulted it with questions. These pics should be in the order I dis-assembled everything.
    Up on jack stands with wheels removed and ready to begin.
    Removing the brake line bracket.
    Removing the old upper control arm nut.
    Removing the upper control arm bolt.
    Bending the fender on the opposite side out towards the wheel well in order to tap the control arm bolt up and out through the engine compartment.
    Removing the three nuts on top of the old strut, leaving the center nut in place.
    Removing the lower shock mount bolt.
    Dropping the sway bar, I had to do this in order to get the strut out (it wedged between the sway bar and drive axle) if you have a pre-runner or any 2x4 you shouldn't have to do this step.
    Tear down complete, at this point I took the new OME stuff along with the old struts to my local, trusted mechanic. He used a spring compressor to dis-assemble the old stuts so we could reuse the top bushings and plate on the new stuff. Here is a pic of the new OME 885 spring mounted to the OME N140s shock. I am pointing a screwdriver at the added 5mm trim packer (this just on driver's side) used to correct the infamous taco lean from the weight of the fuel tank and driver.
    New strut installed along with the assembled total chaos upper control arm. I have heard both ways on here but chose to put the upper control arm bolt in from the back/bottom (opposite of how it used to be) since I was working alone and didn't have someone to lean over the hood and shove it in while I held the assembly in place. OH yeah, and on the driver's side it is a real bitch to get it past the fuel lines!!
    Truck before lift with stock rubber.
    Picture below is the truck pulled straight out of the garage after the lift. It also has newly installed Micky Thompson Baha ATZ 4ribs in a 285/70/17. I do have the TSB done but have not installed the rear add-a-leaf and OME shocks that are sitting in the garage. Now I need to get it aligned.
  2. Oct 23, 2009 at 3:01 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    wow! looks awesome man. good work!
  3. Oct 23, 2009 at 3:13 PM
    bluevan99
    bluevan99 Active Member
    07 DC LB SR5 TRD Sport
    Sweeetttt! Looks like a little yellow spray paint action on the garage floor ;)
    Did you take before and after measurements?
  4. Oct 23, 2009 at 3:15 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Looks good!! Is it a 3" lift up front?
  5. Oct 23, 2009 at 3:19 PM
    Robtrd
    Robtrd Member
    Robert
    Riverside, CA
    08 TRD SPORT
    The front don't look 3in?
  6. Oct 23, 2009 at 3:20 PM
    Sandfire
    southwest midwest
    Thanks guys! The yellow spray paint action was from an old trailer building project last year. I will have to find my old measurements and check it now to give you accurate numbers. It certainly feels like 3" when getting in the truck now!
  7. Oct 23, 2009 at 3:20 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Nice job
  8. Oct 23, 2009 at 3:22 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I kinda agree with you but the bigger tires might shorten the gap between the rubber and fender.:rolleyes:
  9. Oct 23, 2009 at 3:22 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Maybe because of the increase in tire size. It fills up the wheel well more.
  10. Oct 23, 2009 at 3:27 PM
    Kenny650
    Kenny650 Well-Known Member
    Perfect.
  11. Oct 23, 2009 at 3:48 PM
    Sandfire
    southwest midwest
    A few more pics, maybe these will seem taller, it's weird how it looks way bigger in person but not so much in the photo, of course my camera and picture taking skills are crappy....
  12. Oct 23, 2009 at 3:52 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey so did you measure it? It still seems a little low in the front.:rolleyes:
  13. Oct 23, 2009 at 4:20 PM
    Sandfire
    southwest midwest
    I did, it is right at 39 inches from ground to bottom lip of fender running center line through the wheel. I can't find my old measurements, (I took them a while ago) Maybe someone with a stocker can tell me normal height for a 4x4?
  14. Oct 23, 2009 at 4:21 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    That sounds right
  15. Oct 23, 2009 at 4:25 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    looks good man, nice pics and explantion of things!
  16. Oct 23, 2009 at 4:33 PM
    CanadianGuy
    CanadianGuy Well-Known Member
    Vancouver, BC
    08 Access Cab 4x4 TRD
    looks good man, good pics
  17. Oct 23, 2009 at 4:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks GREAT! Your measurements put it right at 3" as compared to my old specs. :)
  18. Oct 23, 2009 at 4:51 PM
    Sandfire
    southwest midwest
    Thanks! and for the PM help!:thumbsup:
  19. Oct 23, 2009 at 4:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your quite welcome :)
  20. Oct 23, 2009 at 6:18 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Did you have to get wheel spacers for your tires? Last night I saw a tacoma with ATZ's at a dealer and that sealed the deal for me, they look WAY bigger and better in person than on the internet.
