Pics & Recommendations
Discussion in 'Suspension' started by InaKoma08, Sep 5, 2008.
  1. Sep 5, 2008 at 1:49 PM
    InaKoma08
    InaKoma08 [OP] INAKOMA08
    Nokesville, VA
    2008 TRD Access Cab
    FABTECH 6" Lift, 17x9 Moto Metal MO951, 35x12.50x17 Mickey Thompson Baja ATZ, Line Of Fire, Jardine Catback,
    I have an 08 Tacoma Access Cab 4x4 TRD Off Road. Im lifting it 3 inches all the way around, and I was wondering what tire size would be better? A 285/70/16 (31.7) or a 285/75/16 (32.8). If anyone has pictures with a tacoma like mine with a 3in. lift and aftermarket tires, Id like pics and the size of what tire you are running. Thanks.
    - Matt
  2. Sep 5, 2008 at 1:51 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    285/75/16 i would go with that tire.
  3. Sep 5, 2008 at 1:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep...285/75/16, and you may need to do a bit of trimming and maybe remove the front mud flaps.
  4. Sep 5, 2008 at 2:18 PM
    InaKoma08
    Nokesville, VA
    2008 TRD Access Cab
    Thanks. The lift kit come in on Monday (installing on Friday) and I kinda want to put the lift kit on and tires on at the same time instead of driving around with a weird looking lifted tacoma and stock tires. Just wanted some opinions, pics would have been nice. I dont want them to look to small but I dont want them too big either. Im going with a General AT2, (same thing as a BFGoodwrench AT but cheaper). Thanks for the feedback! Gotta go order tires!
    -Matt
  5. Sep 5, 2008 at 2:39 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
  6. Sep 5, 2008 at 2:49 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have the toytec 3" lift and some 285/70/17 they claim to be 33s but really measure 32.6. So click my little camera. I removed my front mud flaps and trimmed some plastic fender in the front. If you would like som pictures of what I trimmed I can get them.
  7. Sep 5, 2008 at 2:52 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    im running 285/75-16 nitto terra grapplers they look great and i removed the mud flaps and still have slight rubbing at full turn but not enough for me to worry about trimming anything
  8. Sep 5, 2008 at 2:54 PM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    luk8272, not to steal the thread but i would actually like to see those pics if you dont mind im curious how you trimmed yours if i did end up doing mine im not sure how id go about it. thanks.
  9. Sep 5, 2008 at 3:32 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I used a razor knife and a drimel, then zip tied the flimsy piece of plastic that would rub when I turned from lock to lock. I'm loading the pics to photobucket right now they are kinda large. I cut the big nob in front of the tire and trimmed some on the inside of the front fender also. There was a little to trim away from the bumper as well but not much. The 285/70/17 and 285/75/16 will be the same height. Not sure about the width.
    You can see the zip ties here.
    This is the knob in the front cut off. I was in the front of the truck taking the pic.
    Here is the little I removed near the door.
