Pigpen's Working Man's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Pigpen, Jun 21, 2016.
  1. Mar 18, 2019 at 10:23 AM
    #161
    ChadsPride
    Sponsored by TacomaWorld.com
    Run what you brung! I sure miss the mpg's
    MattCowsmasher likes this.
  2. Mar 18, 2019 at 10:23 AM
    #162
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Wanna trade :D throw in my roofrack to
  3. Mar 18, 2019 at 10:29 AM
    #163
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    Come up for a quick visit. I have some 255s that are coming off for the 235s. They're a bit low on tread for my taste, but if you make the drive, I'll give 'em to ya. Otherwise, they're going on CL for $100.
  4. Mar 18, 2019 at 10:30 AM
    #164
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I would but already have 255s shooting for 285s now.
    ChadsPride likes this.
  5. Mar 18, 2019 at 10:41 AM
    #165
    Pigpen
    Dan
    Northwest Montana
    Por que?
  6. Mar 18, 2019 at 10:42 AM
    #166
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Getting rims soon 9in wide an 255 is to skinny for it.
    ChadsPride and Bigdaddy4760 like this.
  7. Nov 11, 2019 at 3:50 PM
    #167
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    did the body bushing still fully fix the touching of the slider? Still no touching today? any squeaking?
  8. Nov 15, 2019 at 5:23 PM
    #168
    Pigpen
    Dan
    Northwest Montana
    I haven't touched them. They still make a little bit of a knocking noise on occasion. I don't even notice most of the time. They're still grossly over-tourqued too. The bushings have not compressed noticably, if at all. I'm very happy I did this mod.
    MattCowsmasher and ChadsPride like this.
  9. Nov 15, 2019 at 5:55 PM
    #169
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    I like these CVs with the high angle boot.. where did yah get em?
  10. Nov 15, 2019 at 6:30 PM
    #170
    Pigpen
    Dan
    Northwest Montana
    CVJ Axles
    https://www.cvjreman.com/
  11. Nov 16, 2019 at 5:03 PM
    #171
    Pigpen
    Dan
    Northwest Montana
    Also, the little lady and I just got back from Honduras. Going from 80 degree water to snow on the ground isn't an easy transition. IMG_20191106_184249204.jpg
  12. Nov 16, 2019 at 5:05 PM
    #172
    Pigpen
    Dan
    Northwest Montana
    :wave:
    Hi Chad!
  13. Nov 17, 2019 at 3:52 AM
    #173
    ChadsPride
    Howdy!!! ​
  14. Jan 23, 2020 at 8:12 AM
    #174
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    How did you like the Toyo M-55's?
    Do you know how many miles you got out of the?
    Thank you.
  15. Jan 26, 2020 at 1:00 PM
    #175
    Pigpen
    Dan
    Northwest Montana
    I loved the M55s. Mpgs were good. Traction was great in all conditions. They had just enough squish when aired down too. I have no idea how many miles I got out of them. I run separate sets of tires for summer and winter. My only complaint about them is that the center tread strip is on a raised block. This strip wears smooth long before the outer lugs wear down, making for a loud, high pitch ride on road. They're heavy and expensive too, but I can live with those factors.
    I'm now on Dean Backcountry MTs in the same size. So far I like them, but mpgs are not as good as with the M55s. They're about the same price, quite a bit shorter (32.8"), and have a more aggressive tread.
    BloodyTaco and Phessor[QUOTED] like this.
  16. Jan 26, 2020 at 5:30 PM
    #176
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    Thank you for your response. I have narrowed it down to the M55's or KM3's in 255/85R16's.
  17. Jan 28, 2020 at 9:07 AM
    #177
    Pigpen
    Dan
    Northwest Montana
    The M55 has a narrow tread patch - narrower than the overall width of the tire. This means less rolling resistance on road, and less rubbing inside the wheel well. I'm seriously considering going back to the M55. They're 33.5 inches tall, smooth driving, and tough as nails. It's a very tall tire that performs well and fits cleanly inside the wheel well on a Tacoma with no serious modification.
  18. Feb 2, 2020 at 9:17 PM
    #178
    Pigpen
    Dan
    Northwest Montana
    Oops!IMG_20200202_143753470_HDR.jpg IMG_20200202_143812233_HDR.jpg IMG_20200202_151622807_HDR.jpg
    BloodyTaco and Sasquatch3153 like this.
  19. Feb 2, 2020 at 9:19 PM
    #179
    Pigpen
    Dan
    Northwest Montana
    bebo_junker and Sasquatch3153 like this.
  20. Feb 25, 2021 at 7:10 AM
    #180
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Sub'd for future photo reference of Leer 122!
