pine tree
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toy4Life, Sep 12, 2007.
  1. Sep 12, 2007 at 2:12 PM
    Toy4Life
    Toy4Life [OP] 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    What's up everyone? I was wondering if anyone has tried any hardcore pulling with there truck. The reason I ask is because I have a 15-20 ft pine tree that I want to cut down. I'm thinking about trying to pull the stump out with my truck. Any opinions +/- would be appreciated.
  2. Sep 12, 2007 at 2:37 PM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I doubt it will budge without cutting some roots, but only one way to find out!:D
  3. Sep 12, 2007 at 2:49 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I'll have to take pics to document my success or failure
  4. Sep 12, 2007 at 2:52 PM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    drink a case and give it hell!
  5. Sep 12, 2007 at 5:31 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I like the way you think! I'll have to wait a little longer before I try. Otherwise a whole mess of hornets are going to give me hell. I don't want that.
  6. Sep 12, 2007 at 5:49 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Do you have a hitch that you can tie your strap too? Or are you going to use the tow hooks up front and pull in reverse?
  7. Sep 12, 2007 at 6:23 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I have the hitch, but I'm not sure which way I'll try.
  8. Sep 12, 2007 at 6:23 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Good luck Toy. I'm looking forward to the pictures, or better yet, a small video would be cool.
  9. Sep 12, 2007 at 7:08 PM
    MarkC
    Mark
    99 4x4 SR5
    forward with the hitch in 4 lo.. i was never a fan of pulling stuff backwards
  10. Sep 12, 2007 at 9:38 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Its very Doubtfull the Taco can do it. I down (push down and not pull) 70-100 foot trees often with a backhoe and it brings the entire root bulb out. Its neat since there is no stump left behind. The approach requires massive amounts of torque (think Johnson-Bar kind of torque) You have to pull/push the tree at about 10 to 15 feet about the root bulb. Unlike a backhoe's bucket, a chain will snap the tree in half. Maintain sufficient distance so the tree does on end up on your rig. If the chain is at the root bulb you may not have sufficient torque to pull it out. Dont kill your transmission.
  11. Sep 13, 2007 at 1:54 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    It's not a huge tree, but I suspect I'll tear up my lawn before the transmission. anyway I care about my truck too much to push it to that limit.
  12. Sep 13, 2007 at 2:56 PM
    sak3358
    sak3358 Well-Known Member
    I was going to do the same thing, use the truck to yank a tree. Mentioned it to a friend of mine and he immediately jumped into me about using anything other than a heavy gauge chain to pull it out. Seems a friend of his used nylon tow straps to pull on a stump. The strap broke and came through the rear window causing massive brain injuries. Just food for thought.
  13. Sep 13, 2007 at 5:14 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Will consider. That's why I started this post. I wanted some other opinions.
    I have a tendency to think that me and my truck are invincible when we're together.
    Yeah......me and my truck are BFF!
  14. Sep 14, 2007 at 4:58 AM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    And I thought nylon tow straps did not have any recoil.
  15. Sep 14, 2007 at 6:20 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Depends on the strap I think. A standard nylon strap should not have any recoil even under load, and even if it did there is not much to it. Then you have the nylon straps that have the frame hooks sewn onto the ends, now if they let go then you have a 2 lb hook coming at you.
    The ones you really have to watch out for are the Dick Sepec (sp?) "off road recovery straps" They are somewhat elasticized (sp?) the theory behind that being you have the force of the elastic pulling as well as the force of the truck that is pulling, and so it is that much more force for free pulling on the stuck truck. Problem is, they are only rated for so many pulls or so many years, and like any rubberband left in the heat they are prone to fail. These are the ones that can come back on you and cause problems.
  16. Sep 16, 2007 at 7:11 PM
    throwbacktaco
    throwbacktaco Member
    Lower Alabama
    '95 3.4 V6 288,000 miles and counting
    Fabtech adjustable coilovers, HD military wrap leaf springs, 3" body lift, 33 x 12.50 super swamper tXus radials, deckplate mod, STRAIGHT PIPE
    you would be surprised what ive pulled with my taco and a LOT of momentum...
  17. Sep 16, 2007 at 7:15 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Such as?
  18. Sep 21, 2007 at 3:04 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    It was a team effort between me and my Taco, but I was successful. I have a couple of short videos, but I have no idea how to post them. If I can post them.
    If anyone can tell me how, I'll put them up this weekend sometime.
  19. Sep 21, 2007 at 6:20 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    That is a good question. Maybe you could post them to YouTube and then post the link here. How big are they, and what format are they in? I am looking forward to seeing them...
  20. Sep 22, 2007 at 9:34 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    There are two videos as well as some still shots. they're both about a minute +/-. I'll try YouTube.
