Ping after switch to synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spilser, Jun 30, 2016.
  1. Jun 30, 2016 at 1:52 PM
    spilser
    spilser [OP] Well-Known Member
    2013 DCSB TRD OR 4x4 Mag. Gr.
    Hey guys, I just put 5w30 extended protection mobil 1 synthetic in my 2013 v6 auto that has 24k miles today. After a drive I noticed more pinging then usual under load around 1500-1700 rpm.
    Yes I drained the oil pan, not the tranny.
    Oil level is good
    Used Toyota OEM filter.
    Should I switch back to conventional, the noise makes me nervous.
  2. Jun 30, 2016 at 2:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The oil doesn't have anything to do with the engine pinging.
    Try a higher octane gasoline.
  3. Jun 30, 2016 at 3:01 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    ^ this go get some higher octane fuel maybe you got some bad gas and its coincidental with the oil change. Let's us know how that went.
  4. Jun 30, 2016 at 3:10 PM
    spilser
    That's what I thought. But it is the same tank of gas. I would have minimal pinging that you had to really listen for prior to the oil change. 10 mins after makong switch to synthetic and it's very noticeable under load. I have an appointment for the tsb reflash for spark knock on Saturday. If that doesn't work I'll try 93, but id rather not have to run 93 in my tacoma
  5. Jun 30, 2016 at 3:11 PM
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    Since the day I bought my truck, it was always noisy and made pinging noises almost like a diesel. My 2003 did the same exact thing and I have used Mobil 1 in all my Toyotas without issue. I would not lose sleep over it. I have used other brands of synthetic oil that made the engine run slightly quieter then Mobil 1 but really it almost imperceptible. Higher octane fuels will make it run smoother and quieter but the noises in most cases do not indicate an issue. As stated above oil will not cause pinging.
  6. Jun 30, 2016 at 3:24 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If you're buying ethanol blend(E10) and it has phase-seperated, you can't be sure of the octane.
    Ethanol is basically used as an octane booster in blended gas. For 87, the octane of the gas in the blend is actually 84.
    Overblending is common as well.
    Just some food for thought.
  7. Jun 30, 2016 at 3:35 PM
    Redheadfranklin
    Redheadfranklin New Member
    Oroville, CA
    '14 DCLB 4x4 silver sky metallic
    None yet
    I just noticed my 2014 pinging alot when the tranny up shifts too quick under light throttle at maybe 20-25mph. Higher octane fuel has made no difference. A heavier foot so the transmission doesn't upshift so fast seems to work best.
  8. Jun 30, 2016 at 4:23 PM
    spilser
    That is when I notice most noise as well. I have heard the ecu reflash tsb chanoes shift points. I'm just confused why my oil change made me notice more
  9. Jun 30, 2016 at 4:42 PM
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Check into have the TSB performed. https://www.tacomaworld.com/threads/t-sb-0044-14-feedback-engine-ecm-reprogram-pinging.337705/page-2
    One of the most challenging aspects of being a good mechanic is trying to diagnose a failure using customer feedback, then trying to determine if a certain change or event is what caused the failure. It's highly likely that your oil change had nothing to do with the pinging. Example: You changed your oil, the outside ambient air temperature was 80*F +, you were running basic unleaded fuel, and you're around 24,xxx miles. My truck started exhibiting the pinging noises around 30,000 miles & you're close to that @ 24,xxx.
  10. Jun 30, 2016 at 9:16 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Maybe the synthetic oil has smoothed out the engine, in return making the pinging more pronounced.
  11. Jul 1, 2016 at 2:38 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Whut?
    Smoothed out the engine? Does that even have a meaning?
  12. Jul 1, 2016 at 8:05 AM
    gonathan85
    Nate
    Central California
    Agreed :confused:. I think he's experiencing pinging, but it has nothing to do with the oil change. It just happened to start around when he changed the oil. What do you think?
    Either way I'd recommend having the TSB performed if possible.
  13. Jul 1, 2016 at 8:19 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    My 14 has pinged under a load going uphill and in low rpm higher gear since day 1. I have just lived with it or pulled it out of OD when in these situations.
  14. Jul 1, 2016 at 8:28 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    My '13 started pinging after switching to synthetic as well. It doesn't make any sense but that is what happened. If you sift through the ping threads several people say it started or became noticeable after going synthetic. I got the reflash and it went away for the most part. I still hear it every once in a while.
    spilser[QUOTED][OP] likes this.
  15. Jul 1, 2016 at 11:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bad tune.
    gonathan85 likes this.
  16. Jul 1, 2016 at 2:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I agree. He should get the TSB if applicable to his truck.
    gonathan85[QUOTED] likes this.
  17. Jul 1, 2016 at 7:57 PM
    spilser
    Appointment at 11 tomorrow, hopefully for this tsb and the needle bearing (barely noticeable, but wouldn't mind the "improved" part with new fluids.)
  18. Jul 2, 2016 at 5:59 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Ive seen to many post over the years of guys complaining of pinging after doing an oil change. Its gotta be more than a mere coincidence. Might have something to do with new oil boiling off and the vapors in the crankcase being drawn into the combustion camber via the PCV affecting the fuel burn.
  19. Jul 2, 2016 at 6:11 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I just can't see the link between switching to synthetic oil and pinging. My 4.0's OEM oil was changed at 1500 miles with M1 5w-30. Not a ping before or after the switch. Pining is related to ignition timing/fuel octane/fuel-air mixture/engine temps, etc. The oil has nothing to do with that.
    Toyota states that a certain amount of ping is normal. But if you're getting hard ping under load during hot temps....it's time to bump that octane level up.
  20. Jul 2, 2016 at 6:23 AM
    Armkb
    09 TRD Sport DCLB
    Not a ping here either with my 09 and synthetic. Seems to be more prevalant with later year models.
