Ping in front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luke01, Feb 21, 2016.
  1. Feb 21, 2016 at 8:41 AM
    Luke01
    Luke01 [OP] Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    My 2012 DCSB has developed an audible ping in the front end ever time I shift from drive to reverse when I apply the brakes. It only does it once after that it's quite. Am I looking at a brake issue or something else (LCA bushing, CV Shaft, Front diff) before I start chasing my tail on this I want to see if anyone else has dealt with it before.
    Just over 60,000 miles been lifted 3 inches new LR UCA with ball joint installed 2 years ago.
    I am about to pull the wheel to see what I can find.
  2. Feb 21, 2016 at 9:18 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Sounds like you might have the brake pad "slap" problem. The floating caliper design allows the pads to shift. Usually happens once going in each direction and then they're good.
  3. Feb 21, 2016 at 9:19 AM
    Luke01
    Luke
    Dallas, TX
    Anything I need to worry about?
  4. Feb 21, 2016 at 9:22 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    If it's the brake slap, then it's nothing to worry about. Is it just audible or can you feel it from the cab?
  5. Feb 21, 2016 at 9:22 AM
    Luke01
    Luke
    Dallas, TX
    Just can hear it can not feel it.
  6. Feb 21, 2016 at 9:34 AM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    agreed, sounds like the brakes shifting.
  7. Feb 21, 2016 at 8:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree that what he is hearing is the brake pads shifting in the caliper. However the Tacoma doesn't have Floating Calipers. The Tacoma has Fixed Calipers.
    Edited: Correction: The 5 lugger Tacoma does in fact have a floating caliper. All 6 lugger Tacoma's have a fixed caliper.
    Floating Calipers: https://www.youtube.com/watch?v=ar5j1mUdFA8
    Fixed Calipers: https://www.youtube.com/watch?v=OzGMiDsNzzo
    jtweezy[QUOTED] likes this.
  8. Feb 21, 2016 at 10:35 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Same year, similar mileage, similar lift, same sound: it's the brakes. Don't worry about it unless they start to feel weak. I had mentioned it to Toyota when mine still had new-truck smell and he told me they'd grease them if I wanted but the sound will be back in a few weeks.
  9. Feb 22, 2016 at 3:33 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    Mine does it also when switching directions the pads reseat and you can hear it.
  10. Feb 22, 2016 at 7:18 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Thanks! There are a bunch of threads here saying we have a floating caliper, but it never made sense to me how we would have the pad slap with a floating caliper. Sanity restored again, thanks to Jimmy.
  11. Feb 22, 2016 at 8:20 AM
    Pigpen
    Dan
    Northwest Montana
    I installed a second retainer clip on my pads on the recommendation of some here - it didn't help. I've heard that applying a little brake pad grease to the back side of the pad where it's in contact with the caliper, not where it contacts the disk alleviates the problem.
    Bold and underline for general internet viewing - not directed at anyone in particular.
  12. Feb 22, 2016 at 9:17 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The 5 luggers might have floating calipers... but the 6 luggers surely do not. its a 4 piston fixed caliper.
  13. Feb 22, 2016 at 9:18 AM
    nd4spdbh
    SoCal
    WTF i though you were supposed to apply grease to the stopping surfaces of the disk and pads.......
    /sarcasm
    Seriously does that even need to be said, are people really that stupid?
  14. Feb 22, 2016 at 1:58 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This is correct, I just looked it up in the service manual.
    5 Luggers have floating calipers.
    6 luggers have fixed calipers.
  15. Feb 22, 2016 at 11:32 PM
    Pigpen
    Dan
    Northwest Montana
    Never under estimate the power of stupid.
