Pioneer 8100 wiring help!
Discussion in 'Audio & Video' started by TheJaffenator, Nov 11, 2015.
  1. Nov 11, 2015 at 10:22 PM
    TheJaffenator
    TheJaffenator [OP] New Member
    David
    2006 Tacoma TRD Sport
    So I promise I've searched, and I just can't find an answer...
    I'm installing a Pioneer Nex8100 in my '06 Tacoma TRD Sport non-JBL, and I have everything wired with a Scosche TA02B harness, except I can't find where to wire the speed signal input (pink wire) and how and where the e-brake wire is connected (light green wire).
    I can't seem to find pictures or step by step instructions on this part of the install, and thought someone here might be able to lend a hand.
    Thank you in advance, and my apologies if someone really has done this.
    ~The Jaffenator
  2. Nov 11, 2015 at 11:18 PM
    TheJaffenator
    David
    Thanks for the response Rock Lobster.
    I guess I don't actually have to ground the e brake wire to do the bypass. The stereo place today showed me the bottom left corner trick.
    I'm still really new to electronic work, but what did you get from the driver side dash? I just can't tell if I'm supposed to be hooking it to another wire, or bolting it to something or what.
    Again, my apologies if my questions are super beginner, it's just a nice stereo and I want it to work, haha.
  3. Nov 17, 2015 at 4:14 PM
    JDeLuca
    JDeLuca Well-Known Member
    Joe
    Staten Island NY
    2013 TRD Sport MGM
    TRD Cat Back Exhaust, Bed mat, Weather Techs wet okole seat covers
    Curious as to where you ran the antenna's for the gps and satlite.
  4. Nov 28, 2015 at 7:58 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    This may be a little late seeing as you posted this weeks ago, but the speed sensor is for the GPS, what for I'm not sure, as I have never had mine hooked up. The GPS works fine without it. When it was first powered up, the unit said the GPS was in some type of default mode. As far as I remember, someone posted that the GPS uses the speed sensor for the times when you lose Sat. reception to keep track of where the vehicle is.
    Anyway, if you still want to hook it up, inside the driver's side kick panel is a purple/white wire from a 13 pin connector. that is supposed to be the speed sensor. I ran both wires (speed sensor, and parking brake) over there, but never hooked either up. I also used the left corner workaround to bypass the DVD safety (I never use it either way).
    I didn't install my Sat. antenna, but mounted my GPS right on top of the head unit (inside the dash). I wasn't crazy about any exposed wiring, and had read about others doing this with no ill effects. So far, no issues from mine either.
