Pioneer AVH 8400bh
Discussion in 'Audio & Video' started by aubi1414, Jun 7, 2013.
  1. Jun 7, 2013 at 5:36 PM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Ok so I have installed my unit and if anyone knows for a fact that the relay bypass want work please let me know because my relay bypass is not working and I can't get a DVD to play at all. Do I have to switch control this?? Also, who knows how to splice into the rear view mirror backup camera for it to work with this device as well? Your pics of the install or video would be awesome!!
    Thanks,
    Justin
    ___________
  2. Jun 7, 2013 at 8:58 PM
    aubi1414
    Justin
    Pensacola, FL
    nobody? really?
  3. Jun 7, 2013 at 9:02 PM
    medic2230
    Murph
    Bama! Roll Tide
    I know there are a few who have it in their trucks but I think a radio shop did it.
  4. Jun 7, 2013 at 9:02 PM
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
  5. Jun 7, 2013 at 9:15 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I have the 8400 and the bypass from the first link right above me is the one I used and it works.
  6. Jun 7, 2013 at 9:25 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I have a similar unit, easiest thing to do for the bypass is put a three way toggle on the ground.
  7. Jun 7, 2013 at 9:31 PM
    aubi1414
    Justin
    Pensacola, FL
    Thanks for the replies. I just tested the black to the green and the DVD works and am going with the toggle switch tomorrow as for this unit the relay does not work. I tried that and failed. I looked at that the other one on Amazon as well and dont have the patience to wait on it to get here, but thanks for that option as well :) About to read the review on the rear view mirror cam
  8. Jun 8, 2013 at 1:12 PM
    aubi1414
    Justin
    Pensacola, FL
    So now my air bag light is on and ac want come on!! What the hell??? Also, I ran the reverse wire purple from the unit to the red wire that is paired with the red and white wire connector. I ran the RCA plug with the two wire to the connector w/ 4 wires in it and connected is as you all told me. WHY in the world would my airbag light and ac not work now???
  9. Jun 8, 2013 at 1:15 PM
    aubi1414
    Justin
    Pensacola, FL
    Oh yeah and it want come out of PARK???? and turn signals arent working
  10. Jun 8, 2013 at 2:05 PM
    aubi1414
    Justin
    Pensacola, FL
    I blew IGN1 fuse. Anyone know why that fuse would have blown?
  11. Jun 10, 2013 at 6:33 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My understanding on the newest Pioneer units is that they require some kind of double-pulse relay to fake it out. The single relay solution and aftermarket single relay units do not work. You need a double-pulse unit or, as you've found, a switch.
  12. Jun 10, 2013 at 6:37 AM
    aubi1414
    Justin
    Pensacola, FL
    That's correct. Ok so when I have my reverse(purple) wire from unit connected to the red wire(red/white connector) as well as my RCA shielded wire and center wire connected to the other connector the red and black wire(4 wires total). The camera will come on when I turn it on but when in reverse it only comes on to the mirror not both the HU and mirror when in reverse. Any thoughts why when shifting to reverse it want come on as the mirror does??
  13. Jun 10, 2013 at 6:47 AM
    jlleiber
    Justin
    Indiana
    That walkthru I linked shows the Purple Headunit wire going to a connector with a Red/Yellow wire, not Red/White as you just said. I would make sure you have the actual Reverse Signal Trigger wire that is shown in Post #6 of that walk-thru. Then again Post #16 says he has a 2010 and the wiring connectors look different - so maybe the reverse signal trigger wire is located elsewhere in a '10 :confused:
  14. Jun 10, 2013 at 6:58 AM
    jlleiber
    Justin
    Indiana
    Also, according to the 8400 manual, the wire you should be connecting to the Tacoma Reverse Signal Trigger wire is Violet/White
  15. Jun 10, 2013 at 7:48 AM
    aubi1414
    Justin
    Pensacola, FL
    The one from the headunit is labeled reverse and is violet/white? are you saying the one under my dash I am supposed to connect too is supposed to be violet/white as well???
  16. Jun 10, 2013 at 7:50 AM
    aubi1414
    Justin
    Pensacola, FL
    My wires look identical to the ones in the link you sent me and I connected exactly as shown? Hmmm im confused as hell now??
  17. Jun 10, 2013 at 7:52 AM
    aubi1414
    Justin
    Pensacola, FL
    This is what I connected the reverse too in my 2010.
    Quote:
    Originally Posted by kmartshopper [​IMG]
    Messing around with the volt meter I think I found it! Its the Red Wire in the connector above the camera connector.
    Sorry for the hacked picture, no time have to get back to work [​IMG]
  18. Jun 10, 2013 at 7:59 AM
    jlleiber
    Justin
    Indiana
  19. Jun 10, 2013 at 8:29 AM
    aubi1414
    Justin
    Pensacola, FL
    Ill try it again and see if I blow anymore fuses lol
  20. Jun 12, 2013 at 9:04 AM
    medic2230
    Murph
    Bama! Roll Tide
    Did mine just like that. Didn't blow any fuses. I hooked into the reverse wire behind the drivers kick plate on the floor.
