Pioneer AVH-W4400NEX
Discussion in 'Audio & Video' started by Techsan, Sep 3, 2018.
  1. Nov 23, 2018 at 8:39 AM
    #41
    mctechhweng
    mctechhweng Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    I did a lot of stuff in my setup to remove unused wires from the Maestro harness for my build. This helped me get a very flexible & thin harness. I also integrated very little OEM stuff so I split the factory harness apart and stuffed the wires I don’t use out of the way.
    override likes this.
  2. Nov 23, 2018 at 10:09 AM
    #42
    lastrada
    lastrada Active Member
    Thanks for the info everyone, I will probably go ahead and get the 4400 and try it.
    Toms 17, override and mctechhweng like this.
  3. Jan 16, 2019 at 3:51 PM
    #43
    Jayjeepcommander
    Jayjeepcommander Member
    Hi i have w8400nex with the maestro rr. So you mean to tell i dont need the micro bypass for video play while driving.? I just the screen touch thing ontill it saids set on?
  4. Jan 16, 2019 at 3:53 PM
    #44
    Jayjeepcommander
    Because i just installed a micro bypass on my w8400nex and it works but the minute i start driving the caution warning comes on.
  5. Jan 16, 2019 at 3:57 PM
    #45
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    That's what we mean to tell you.
  6. Jan 26, 2019 at 10:24 AM
    #46
    Heavenlyhawgs
    Heavenlyhawgs Active Member
    Jack
    2013 Tacoma
    Not sure what you mean. I have AVH W4400 and Maestro wiring harness and micro switch installed. When stopped video works but as soon as i start moving video goes out. Not sure what to do about it. Would like to be able to see video while driving for my granddaughters sake.
    Thanks for your hel
  7. Jan 26, 2019 at 10:48 AM
    #47
    Jayjeepcommander
  8. Jan 26, 2019 at 10:48 AM
    #48
    Jayjeepcommander
  9. Jan 26, 2019 at 10:49 AM
    #49
    Jayjeepcommander
  10. Jan 26, 2019 at 10:52 AM
    #50
    Jayjeepcommander
    https://youtu.be/LxQDe0osxUA what's this video, it will fix your problem
  11. Jan 26, 2019 at 12:26 PM
    #51
    Heavenlyhawgs
    Jack
    2013 Tacoma
    Thank so much... Worked perfectly
  12. Jan 27, 2019 at 6:34 PM
    #52
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    can you send me the accessories you needed to buy for the 8400 to work on the SR5, i have the crutchfield site open and it's saying
    iDatalink Maestro ADS-MRR Interface Module
    iDatalink HRN-RR-TO2 Factory Integration Adapter
    American International TOYK971 Dash Kit
    Metra AX-TOYUSB USB Port Cable
    Metra 40-LX11 Antenna Adapter
    That it? the parts alone are 225
  13. Feb 5, 2019 at 4:17 PM
    #53
    jr49
    jr49 Well-Known Member
    California
    2015 SR5 PreRunner Double Cab
    Any reason specific reason why the stock mic won't work? my truck didn't come with GPS but installed a Toyota unit with NAV from another thread here and it worked with my shark fin (i'm assuming that's where GPS is), would i have to use a GPS adapter? does backup camera work too?
  14. Feb 5, 2019 at 4:24 PM
    #54
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If you do not have the JBL system, you can get by with the 70-1761 harness, and whichever brand of steering wheel control adapter you want. The maestros and PAC modules work best, but Axxess has plug and play harnesses available that I enjoy.
    Oh, and of course the mounting kit.
  15. Feb 5, 2019 at 4:28 PM
    #55
    destin_meeks
    Destin
    Tuscaloosa, AL
    There is a thread on here about a device you can use to retain the stock mic, but without that, it’s not an easy task.
    There is a GPS antenna adapter and an XM antenna adapter (they are different)
    If your camera displays on the radio, there is an adapter for that (maybe cam-ty11 or cam-ty12 ?)
    If the cam is in the mirror, there’s not a harness for it but if you don’t mind a little splicing, it can be moved to the new radio
  16. Feb 5, 2019 at 4:33 PM
    #56
    jr49
    California
    thanks. reading that thread now. My camera displays on the radio so i'll check the adapters for that. gonna start doing a little homework on this topic and see if it's something i can do myself. the unit i have is starting to act up on me so it's time to replace it.
  17. Feb 5, 2019 at 4:49 PM
    #57
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah, you “can” do it pretty cheap and easy, but the adapters definitely add up.
    For steering wheel controls, I like the maestro SW the most, because it gets programmed on the computer which is by far the easiest way. All buttons can be customized, and you can use both short presses and long presses (short press for volume down, long press for mute, etc)
    It just requires some splicing into the factory wiring.
    If you want an easier install but less customization and no long press functions, the axxess aswc-1 is easy with the available harness.
    You need the mounting kit no matter what. You need the antenna adapter no matter what.
    Since you’re getting a CarPlay/AndroidAuto unit, I would get the USB adapter to retain the factory usb plug if you have one.
  18. Feb 5, 2019 at 6:04 PM
    #58
    Taco_Coma
    South NJ
    2018 DCSB SR5
    can you post the link to that thread?
  19. Feb 6, 2019 at 10:47 AM
    #59
    jr49
    California
  20. Jun 27, 2019 at 5:05 AM
    #60
    Creamytaco
    Creamytaco New Member
    Garrett
    2013 Tacoma TRD sport dc lb
    So as long as you careful tuck the wires way into the dash the avic8200nex will fit in a 2013 non jbl Tacoma?
