Pioneer AVIC 920bt Install Questions
Discussion in 'Audio & Video' started by GSteve, Jun 21, 2010.
  1. Jun 21, 2010 at 6:22 PM
    GSteve
    GSteve [OP] New Member
    Phoenix
    '10 4x4 Off Road Access Cab
    New to Forum. Installed DICE ipod adapter, but now want install 920BT and have a few questions:
    1. part #/mfg for adapter cable to mate unit w/factory harness?
    2. If I add the Bluetooth steering wheel control (#84244-35030-B0) and cable (#84204-58010) to audio controls, will it work with this unit via adapter cable?
    3. Can I replace mirror w/mirror that has mic - i.e. does the factory harness in the 2010 have the mic wires and will it work with this unit via adapter cable?
    4. Can I use the pre-installed satellite antenna and is it located behind the radio in the dash? Plugs into unit?
    5. Can I get the back-up camera to display on this unit (and how)?
    thanks,
  2. Jun 21, 2010 at 6:30 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    With that many questions I might take it to a professional. I'm sure someone will chime in.
  3. Jun 21, 2010 at 6:32 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Hey Steve! Welcome to the forum! Why don't you head over to the "New Members" forum and introduce yourself.
    Now to answer your questions:
    1. http://www.amazon.com/SCOSCHE-TA02B..._1?ie=UTF8&s=automotive&qid=1277169838&sr=8-1
    2. Yes you will need the PAC-SWI-PS adapter. The install for this can be found here.
    3. I don't believe you can use the stock mic. I would do what epa4wd did here to have the most stock look (also check here for more detailed pictures of what he did). Also you could run it through the headliner and attach it to the lip of the headliner above the mirror.
    4. Yes you can, but you must purchase a $70 connector and run it to the antenna lead. A more detailed DIY can be found here. The connector cable is mentioned there also.
    5. Here is the back-up camera location. Just do this and run it to the port on the back of the 920.
    A couple weeks ago I was planning on buying a 920bt, but the money just isn't there now. It seems to be a great product, and here is a thread which has most things you need to know about where stuff is at for the install. Let me know if you have any questions. Good Luck! :thumbsup:
  4. Jun 26, 2010 at 7:31 AM
    GSteve
    Phoenix
    Where can I find the wiring diagram for the 2010 audio system. I have the 6-disc changer, 6 speakers and the subwoofer (non-JBL). From reading other posts it appears there is an an amp in the system. I need the pinout on the connectors, etc. to I can install the 920BT. Still waiting on a few parts, but getting ready.
    Thanks,
  5. Aug 18, 2010 at 3:06 PM
    gcancilla
    gcancilla Active Member
    I have a 2010 Double Cab with Factory XM and JBL. I am replacing the head unit with a Pioneer z120bt with the 920XM tuner box. Do I still need the SFA12M to use the factory XM antenna or with the current wire from the factory installed XM tuner work?
  6. Aug 18, 2010 at 4:03 PM
    Chad
    Chad
    Cary, NC
    Eh, I'm guessing you would still need to SFA12M, but I'm not 100% certain. does the stock antenna going into the stock headunit have the plug similar to the SFA12M or is it in one of those multiple wire plug things?
  7. Aug 19, 2010 at 6:21 AM
    gcancilla
    I figured as much. I have not pulled the unit yet to see what the connections look like.
