pioneer AVIC GPS antenna location
Discussion in 'Audio & Video' started by krylon153, Mar 4, 2010.
  1. Mar 4, 2010 at 2:43 PM
    krylon153
    krylon153 [OP] Active Member
    Vancouver, BC
    For thos that have a avic head unit (mine is the avic-x710bt) can you tell me you installed your GPS antenna. I have read some of you just put it behind the head unit but I worry about the signal strength. My other thought is to run wire up to the left of the dash on top all be it a bit of an eye sore. I appreciate any thoughts/ ideas on this
    thanks
  2. Mar 4, 2010 at 3:44 PM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Well my first location was on a little metal platform up under the compass-temp display but sat. location finding was really slow, so I moved it to a place above the glove box another metal platform that it just stuck too, works way better, it needs to see the sky, just not behind metal.
  3. Mar 4, 2010 at 4:11 PM
    krylon153
    Vancouver, BC
    Great info, good to know. maybe I can find and area behind the HU that only has plastic above it. defiantly will make for a cleaner install!
  4. Mar 4, 2010 at 4:21 PM
    e-man
    e-man Active Member
    eric
    los angeles
    07 silver PreRunner 4x2 TRD Off-Road
    pop n lock 5300, aries 4" oval black step bar, oem cargo divider , pioneer avic z110bt nav unit, pioneer ndbc4 backup camera, - just starting out but more to come
    I have a z110bt - put my gps antenna with metal pad right on top of head unit. No problems whatsoever. Called pioneer and they said that some people do this and he hasn't received any negative feedbacks. Keeps it nice and hidden.
  5. Mar 4, 2010 at 4:46 PM
    krylon153
    Vancouver, BC
    good suggestion. did you use the magnetic pad or just right on top?
  6. Mar 4, 2010 at 4:56 PM
    e-man
    e-man Active Member
    eric
    los angeles
    I put magnetic pad on top of HU and placed antenna on top of pad. No problems with navi and my satellite connections status is fine. BTW - Avic Z110BT is a great unit. Works great with a back-up camera. 7 inch screen FTW.
  7. Mar 4, 2010 at 5:17 PM
    SilverStreak05
    SilverStreak05 Well-Known Member
    NorCal
    2005 4x4 TRD Off-Road
    DR coilovers, DR rear reservoir shocks, Deaver custom 11 pack leaf springs
    I have a D3 and mounted my GPS antenna on the top corner of the front fender. There's a flat spot there and it sits perfect.
  8. Mar 4, 2010 at 6:11 PM
    bookmonke
    Mark
    Jacksonville, FL
    I got my F90BT used, so it didn't have the metal pad and couldn't find the one I made when I had a Z1, also check out avic411.com site, lots of info.
  9. Mar 4, 2010 at 6:29 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I chose the area right next to where the rear view mirror mount enters the headliner. It's black/shaded and you never even notice the GPS antaena up there. I just used a dab of clear silicone on the GPS thing and stuck it up there on the shaded area. Works perfect and you really don't see it.
    If you mount it with silicone just put some tape over it for like 3 hours or so till it dries. Then it wont EVER come down!
  10. Mar 27, 2010 at 10:45 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    The easiest place is just inside the truck on the passenger side between the dash and the windshield. It's protected from the elements, has a clear view to the sky, and is out of the way. No headaches either. I'll post a pick when I get a chance. By the way, never have had any problems with my GPS or Satellite reception.
  11. Mar 28, 2010 at 5:24 AM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    2010 TRD Sport 4 door Speedway Blue 4" Nerf Bars Vent visors Weathertechs Mats Hella 500 HID Mod Bull Bar Devil Horns Eclipse AVN 726E Energy Speakers
    I have an Eclipse AVN726E and placed the gps antenna right on top of the head unit, and slipped it in dash. Makes for a clean install :cool:
  12. Mar 28, 2010 at 4:23 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Same here and no issues with GPS signal
  13. Mar 28, 2010 at 9:34 PM
    toyby4
    toyby4 Well-Known Member
    05 INDIGO INK PEARL TRD Sport
    Black HID Headlights, HID FOGs, Leer Tonneau, Tint, Pioneer NAV, Backup CAM
    I have a AVIC F 700 BT ...I put mine in the bottom corner of the windshleld on the passenger side... works great.... 'cept in parkades!:eek:
  14. Mar 29, 2010 at 5:22 AM
    bama taco
    bama taco Member
    Gainesville VA
    2010 DC Sport
    I just installed a Pioneer AVIC X910BT, and I put my GPS antenna under the dash on top of the plastic AC vent (just to the right of the HU). I mounted the metal plate there, and just wedged the antenna between the plate and the dash. It's a tight fit, and it isn't going to budge. My reception has been spot-on.
  15. Mar 29, 2010 at 5:29 AM
    Zizo
    Zizo Engineer Extraordinaire
    Anthony
    Greenville, SC
    '06 DoubleCab 4x4 TRD Sport
    TRD Supercharger, 3" lift w/ Fox Shox, Pioneer Sound System, Remote Start, Avid Off Road Bumpers, All Pro Sliders, LED light bar, HID headlights, much more...
    No one here uses the roof? I ran my wire thru the firewall and up the "gutter" of the windshield on the driver's side. It sits on my roof. Best reception possible :)
  16. Mar 30, 2010 at 2:07 PM
    Ecapvegas
    Ecapvegas Active Member
    Sin City
    2010 Silver 4x4
    I have the Z110BT and mine is in the same place. I considered "hiding" it like some others have, but decided against it because I've always been under the impression that satelites work better if they have a clear line of sight.
    However, I know a few people that have mounted them on top of the head unit and never had a problem with reception (at least they'll never admit to it :D)
  17. Mar 30, 2010 at 2:38 PM
    phd12volt
    phd12volt Well-Known Member
    So-Cal
    07 Tacoma Manual 2wd Access Cab 5-Lugger
    Homelink Mirror Autopage Alarm/Remote Start/C3 Tracking Alpine w505 w/P1 Nav
    i have the alpine w-505 i tried the antenna inside the dash, worked just as well as on top of the cab. So it is back inside the dash. :)
