Pioneer AVIC-W8400NEX Installation and Review
Discussion in 'Audio & Video' started by Techsan, Sep 27, 2018.
  1. Oct 26, 2018 at 3:13 PM
    boulderoffroader
    boulderoffroader Well-Known Member
    Colorado
    2018 TRD Pro
    Capacitive touch screen (like an iPhone) versus resistive (like Toyota HU) is a main benefit, plus 8400 has built in Nav. 4400 does not.
    okichewy1[QUOTED] likes this.
  2. Oct 26, 2018 at 4:11 PM
    Techsan
    Techsan [OP] Well-Known Member
    South Texas
    2017 BBPDC
    The capacitive touchscreen was big for me. A real GPS (not a cellular app) was big. Compare the features and what they’re worth to you.
  3. Oct 26, 2018 at 4:16 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Also the 8400 with its GPS NAV set up has a mph speed warning so you won't go faster than set speed limit and risk a ticket
    Bottom right corner of the screen illuminates with a yellow orange icon with posted speed limit
    okichewy1 likes this.
  4. Oct 26, 2018 at 4:29 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    does wireless mirroring work while the truck is in motion?
  5. Oct 27, 2018 at 9:23 PM
    BoneyM
    BoneyM Member
    Tom
    2021 Tacoma Limited
    I just finished installing the same HU in my 3rd gen. I wish it only took me 4 1/2 hours... The anytime backup camera mod, running the HDMI and USB2 cables from the center console, and Kyleinator's inline mic adapter added some additional challenge and time to the process. I'm really happy with the result, and I like that I didn't need to install the aftermarket mic. Thanks to Kyleinator and friends for that!
    I never did figure out the "wired remote" part. I found an alternate wiring diagram (for same model/year truck, same Maestro T02) that showed using the "data cable" instead of the "wired remote", so I used that. Seems to work fine, except the "on hook/off hook" buttons on the steering wheel don't work. I don't think I care, as I never really used them, even with the factory HU. But for the next soul looking to ditch Entune, who might also be searching TW for help doing this, are there any gurus out there who know where the blue/yellow wire goes that's coming out of the Maestro wired remote (along with the 3.5mm jack)? The Maestro wiring diagram just shows it pointing towards the HU, and not going to the HU wiring harness. No other mention of it anywhere I could find.
    A couple other things of note, that would've been nice to know before I started, and that weren't recommended by Crutchfield (or any other research I did ahead of time):
    • To keep your factory AUX port, Pioneer says you need Pioneer part CD-RM10 (to connect the Pioneer harness to the Maestro T02 harness). Pretty sure the 3rd gen factory AUX port only supports audio, and if so you could get away with a 3.5mm stereo to RCA adapter.
    • If you want to use the factory GPS antenna, you need the Maestro Acc-SAT-T02 adapter kit.
  6. Oct 28, 2018 at 5:44 AM
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Are you a tester for Kyleinator or did he start producing the adapter already? How does it work for you overall?
  7. Oct 28, 2018 at 6:16 AM
    BoneyM
    BoneyM Member
    Tom
    2021 Tacoma Limited
    I'm one of the testers. It's working great. It's only been installed less than a day, so I haven't called too many people with it yet, but for the few calls I have made, the call quality has been very good. As good, if not better, than with the factory HU.
  8. Oct 28, 2018 at 6:53 AM
    Techsan
    South Texas
    2017 BBPDC
    I never permanently mounted my aftermarket mic hoping this would pan out. Any comments on the installation?
  9. Oct 28, 2018 at 8:04 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Luckily, most cameras have gridlines built in (and a wire you can cut to disable them. Every camera I’ve installed from the expensive pioneer and echo master, down to $20 eBay cameras clients bring me. So have no fear!
  10. Oct 28, 2018 at 8:11 AM
    BoneyM
    BoneyM Member
    Tom
    2021 Tacoma Limited
    It was fairly straightforward. There are four wires you have to tie into on the 28-pin harness, plus ground + acc, which you can get from anywhere. I used the HU harness for 12v/ground, as I was tapping those into the Maestro. For the 28-pin harness, I used this, to avoid having to tap into the factory wires (optional).
  11. Oct 28, 2018 at 8:19 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yellow wire is for kenwood radio’s. 3.5 jack is for pioneer and others.
    There is a 3.5 jack on the back of the headunit labeled W/R and it goes there.
  12. Oct 28, 2018 at 8:28 AM
    Techsan
    South Texas
    2017 BBPDC
    Appreciate the reply. I really like your idea of using a “jumper harness“. I’m a big believer in soldering/heat shrinking everything and that would suit the need perfectly.
  13. Oct 28, 2018 at 9:09 AM
    BoneyM
    BoneyM Member
    Tom
    2021 Tacoma Limited
    That makes sense, thanks! Now I understand why the diagram is drawn the way it is in the Maestro, but it would've been much clearer if they had split the two wires on the diagram and put the words Kenwood and Pioneer next to each.
    Now that I have a choice, I have to ask: which connection is preferred, "data cable" or "wired remote"? Do they provide identical functionality? If so, it seems strange that both ADS and Pioneer support both connection methods, potentially simultaneously.
  14. Oct 28, 2018 at 9:18 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I have always selected “data cable” in the RR flashing, but I always connect both plugs. I have not had issues with buttons not working, but I can’t say for sure which wire is actually being used. I’ve learned when in doubt, hook them both up.
  15. Oct 28, 2018 at 9:28 AM
    #35
    BoneyM
    BoneyM Member
    Tom
    2021 Tacoma Limited
    Since I have to take it back apart in a few days when the GPS antenna adapter and the right dash kit :annoyed: arrive, I'll hook the other cable up then. Thanks again!
  16. Oct 28, 2018 at 10:42 AM
    #36
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Unless I did something wrong, the Maestro ACC-SAT-T02 adapter didn't work for me. Got no satellites when connected. Plugged in GPS antenna that came with the 8400nex and satellites came up right away.
    Same thing when I was using the adapter when I had the Kenwood DDX9905s headunit.
  17. Oct 28, 2018 at 11:32 AM
    #37
    destin_meeks
    Destin
    Tuscaloosa, AL
    I'm saying this off the top of my head so it might not be correct
    In a lot of cars I work on, the GPS antenna and the XM radio antenna fit the same plugs, but do not work each other. If the XM antenna got grabbed by mistake, it wont work for GPS.
    Again, I'm trying to picture it in my head so I may be mistaken
  18. Oct 28, 2018 at 11:54 AM
    #38
    JaTe
    Maryland
    Hmmm...may have to look into that. I don't have the XM module so it's quite possible I did that.
  19. Oct 28, 2018 at 12:39 PM
    #39
    BoneyM
    BoneyM Member
    Tom
    2021 Tacoma Limited
    I noticed when I unplugged both antennas that the plugs for both were identical, except for color. The XM antenna was black, the GPS antenna was white.
    destin_meeks[QUOTED] likes this.
  20. Oct 29, 2018 at 9:59 PM
    #40
    Sofasloth
    Sofasloth Well-Known Member
    2017 Tacoma Limited
    I grabbed the XM antenna and connected it for GPS accidentally the first time I tried. I knew it was wrong right away when GPS could not get a signal. The GPS antenna was on the left side of the HU opening closest to the steering wheel. The XM antenna was the one coming from the other side.
