Pioneer AVIC-W8400NEX Installation and Review
Discussion in 'Audio & Video' started by Techsan, Sep 27, 2018.
  1. Jan 30, 2019 at 7:09 PM
    #101
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    Yes...it will fit
  2. Feb 2, 2019 at 10:52 AM
    #102
    dragonle87
    dragonle87 Well-Known Member
    Atlanta, GA
    '13 DCLB TRD Sport
    Does the 8400 have GPS voice turn-by-turn directions?
  3. Feb 2, 2019 at 2:50 PM
    #103
    mctechhweng
    mctechhweng Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    Yes. So does google maps and apple maps.
    Something else I noticed was that apple car play now gives me the ability to change the volume of just google maps. When I had the 8200-nex I didn't have control over just the nav voice volume so this is a nice feature. Not sure if it came with the 8400-nex or an ios update.
    dragonle87[QUOTED] likes this.
  4. Feb 4, 2019 at 6:07 PM
    #104
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    can you send me the accessories you needed to buy for the 8400 to work on the SR5, i have the crutchfield site open and it's saying
    iDatalink Maestro ADS-MRR Interface Module
    iDatalink HRN-RR-TO2 Factory Integration Adapter
    American International TOYK971 Dash Kit
    Metra AX-TOYUSB USB Port Cable
    Metra 40-LX11 Antenna Adapter
    That it? the parts alone are 225
    also did it fit the sr5 radio trim?
  5. Feb 12, 2019 at 9:04 PM
    #105
    rp185702
    rp185702 Well-Known Member
    I installed the W4400NEX and am curious about the anytime camera mod. Most installs include the 28 pin harness to the factory entune radio, but the pioneer HU doesnt have that. How did you install the anytime camera mod without that?
    Thanks
  6. Feb 12, 2019 at 9:58 PM
    #106
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    The only thing that really defines an anytime backup camera is the ability to power the camera and change over to the camera video on demand. That means you have to pull the power from a circuit that is powered when you want to look at the camera (Or whenever the radio is on) and you have to adapt the OEM signal into RCA video.
    There is a harness you can buy that gives you an RCA & a hook into the camera power wire.
  7. Feb 13, 2019 at 2:40 PM
    #107
    Techsan
    Techsan [OP] Well-Known Member
    South Texas
    2017 BBPDC
    Have you tried the beta firmware update yet? Did it resolve the display issue?
  8. Feb 13, 2019 at 4:04 PM
    #108
    Tacomavkk
    Tacomavkk Well-Known Member
    Woodinville, WA
    2018 TRD Off-road DCSB Quicksand
    I have not. Been traveling and ultra cold weather before that didn’t entice me to stay in the garage. However I did clarify that pioneer notified me of a fix actually provided by idatalink for the maestro. Which makes more sense because I don’t have a pioneer account to speak of.
  9. Feb 13, 2019 at 4:33 PM
    #109
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    This has been a CarPlay update (presumably through iOS)
    I have seen it on every model I've installed down to the cheapest, Pioneer 1300/1330 model. Even going back to an old 4200-nex (same software as 8200) seems to have separate nav/music volume sliders
  10. Feb 13, 2019 at 9:23 PM
    #110
    rp185702
    Thanks for responding so quick. The part I'm confused with is using the physical switch to activate the cameras in the head unit. Do the aftermarket camera buttons work to activate the front camera on the pioneer head unit?
  11. Feb 13, 2019 at 10:06 PM
    #111
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    You just adapt the OEM camera harness to an RCA, a ground wire and a 12v or 6v supply wire depending on what your car has. You plug the RCA into the aftermarket input for backup camera. You either power the camera off accessory, remote, ignition or you wire up an OR function between the reverse wire circuit and a switch, but you need to send it the right supply voltage.
    You can just change the input whenever you want on the radio to "Camera View" & the radio automatically switches to "Camera View" if you put the car in reverse (& wire the radio correctly).
  12. Feb 14, 2019 at 6:44 AM
    #112
    rp185702
    That's what I figured. I already have a front camera installed and am able to switch to camera view via the pioneer menus. I was hoping for a physical switch as navigating the menus is not ideal. This is a real first world problem, haha. Thanks for answering
  13. Feb 15, 2019 at 1:58 AM
    #113
    Tacomavkk
    Woodinville, WA
    You just have to keep the left most button pressed until the camera view pops up and you can switch between front and rear.
  14. Feb 15, 2019 at 6:19 AM
    #114
    rp185702
    You just changed
    No, f'ing way! Thanks! You just solved an issue that's been bugging me for months.
    Tacomavkk[QUOTED] likes this.
  15. Feb 20, 2019 at 1:24 PM
    #115
    MTP
    MTP Member
    Mundelein, IL
    2019 Off-Road MT
    Is anyone else who installed this particular unit having audio skipping issues while using wireless Android Auto? I have a Pixel 3, and it skips about once per minute. Wired AA and wireless CarPlay work fine, but not wireless AA.
    Thanks!
  16. Feb 22, 2019 at 8:53 PM
    #116
    Techsan
    South Texas
    2017 BBPDC
    For what it’s worth, I updated my Maestro firmware to 2.6 and it did solve the issue.
  17. Feb 25, 2019 at 2:15 AM
    #117
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Also interested in this exact question. I have the standard entune HU, not JBL. Any extra adaptors we need that crutchfield doesn't include?
  18. Feb 25, 2019 at 9:57 AM
    #118
    Tacomavkk
    Woodinville, WA
    Excellent, I just got back from my trip this weekend so have still not tried it. Thanks for the update.
  19. Feb 25, 2019 at 8:14 PM
    #119
    xenonsupra
    xenonsupra Well-Known Member
    Joe
    Greenville, SC
    2019 White Pro MT, 1994 Supra TT 6spd
    Getting mine installed professionally on Saturday. So pumped. I absolutely hate the factory headunit. If anyone wants it let me know. It has Nav at least...
  20. Feb 25, 2019 at 8:47 PM
    #120
    Totall4285
    Palm Harbor, Fl.
    Do u mind me asking what install cost is? U can PM me if you prefer.
