Pioneer AVIC-W8400NEX Installation and Review
Discussion in 'Audio & Video' started by Techsan, Sep 27, 2018.
  1. Apr 21, 2019 at 8:57 PM
    #161
    dnguy77
    dnguy77 Well-Known Member
    Duey
    Baton Rouge, LA
    '18 White Tacoma DC TRD Sport, '03 Grey Tundra AC SR5
    You might have to. I just checked mine and my "parking assist" was "enabled" under my maestro settings.
  2. Apr 30, 2019 at 6:12 PM
    #162
    TacoLoco17
    TacoLoco17 Well-Known Member
    Craig
    Conshy, PA
    17 TRD OR DCSB Super White
    TRD Sport Hood swap TRD Exhaust TRD Intake TRD Skid plate TRD Pro Faux grille w/ Raptor lights MORIMOTO XB LED Headlights Rigid D series Fog lights Rigid E series 20” lightbar Spot/Flood MESO Ultimate Turn signal MESO Stage 1 Tailights 3x Remote Start Hypertech In-line Speedo Calibrator OV Tune Bilstien 6112/5160 Set at 5/6 OME Dakar Medium Leaf Pack Pioneer Avic 8400 NEX Headunit Infinity Reference 6x9s Front 6.5"rear Kicker Subaru Tweeters JL Audio Stealthbox w/ JL Audio RD500/1 amp ARE CX series cap Toyota OEM Trifold Hard Tonneau Body Armor HiLine Front Bumper Smittybilt X20 Gen 2 10K Winch SCS Ray 10 17x8.5 Gunmetal Rims 275/70 Falken Wildpeak AT3W tires
    i swapped the tweeter for the subaru tweeter how do you like the rest of the kicker speaker upgrades
  3. Apr 30, 2019 at 8:53 PM
    #163
    dnguy77
    Duey
    Baton Rouge, LA
    It's 10x better than the stock speakers. I usually keep the volume around 13-15, 20-22 when I'm feel like jamming and it packs a nice punch.
  4. May 23, 2019 at 10:30 AM
    #164
    tooolman
    tooolman New Member
    2017 Tacoma TRD Off Road
    None....So Far
    Very nice post on your installation. I have a couple questions I was hoping you could answer.
    1) Were able to reuse the factory microphone for phone calls and voice control?
    2) Were you able to use all of the factory wiring without cutting off the plugs with the Maestro RR kit?
    3) Does the factory harness for the rear camera plug in directly to the HU or does it adapt through the Maestro wiring?
    I'm trying to cut as little of the factory wiring as possible. Any feedback would be greatly appreciated.
  5. May 23, 2019 at 4:19 PM
    #165
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    There is zero cutting of factory wiring when using the RR
    As for the factory mic, this is the only thing I’ve seen (for any vehicle) but the thread seems dead
    https://www.tacomaworld.com/threads/retaining-factory-mic-location.503653/
  6. Jun 11, 2019 at 6:11 PM
    #166
    TacoJHawk
    TacoJHawk Member
    2017 Quicksand Tacoma Limited
    I finished the install and I love the wireless CarPlay. The navigation is also super slick!
    I am, however, having trouble getting the rear camera and the steering wheel controls to work. Did anyone encounter this problem? I also have a front camera that I’d like to hook up. Any advice helps.
  7. Jun 11, 2019 at 6:14 PM
    #167
    TacoLoco17
    Craig
    Conshy, PA
    When you flash your maestro u have to select none for options on the right side steering wheel buttons. i had an issue when i chose different commands certain buttons. so i used default for left side buttons and selected none for all the buttons on the right side. everything works for me. the rear camera had no issues
  8. Jun 11, 2019 at 6:31 PM
    #168
    TacoJHawk
    TacoJHawk Member
    I remember being proactive and doing some customization. Thanks for the tip! Do you remember which port you plugged your Backup camera into? The harnessCrutchfield sent had two conflicting inputs that were similarly labeled.
  9. Jun 11, 2019 at 6:31 PM
    #169
    TacoLoco17
    Craig
    Conshy, PA
    you have the 8400 right
  10. Jun 11, 2019 at 6:43 PM
    #170
    TacoJHawk
    TacoJHawk Member
    Yes. The wiring harness I got had a yellow 3.5mm cable and I was told this goes into the unit but I also got a wiring diagram that it connects partly to the Maestro.
    Hopefully this diagram can help others.
  11. Jun 11, 2019 at 6:46 PM
    #171
    TacoLoco17
    Craig
    Conshy, PA
    the 3.5 is for aux in port that’s below the usb port on the dash. from what i remember i plug the yellow rca was labeled rear camera from maestro to the brown rca from the pioneer.
    Rockoma5 likes this.
  12. Jun 12, 2019 at 6:57 PM
    #172
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Did you hook up the reverse camera harness?
  13. Jun 12, 2019 at 7:38 PM
    #173
    TacoLoco17
    Craig
    Conshy, PA
    im pretty sure i did and it connects to the maestro harness from the diagram
  14. Jul 10, 2019 at 10:16 AM
    #174
    Dfloman
    Dfloman New Member
    2018 Tacoma LTD
    I just did a complete AVIC w8400NEX install on a 3rd gen 2018 Tacoma LTD with JBL. The above info was extremely helpful.
    One thing that was a bit confusing was the discussion about the data cable from the Maestro RR to the head unit. There were some posts about the yellow cable which is for Kenwood and the 3.5 jack going into the port marked W/R on the back of the unit. Disregard that whole discussion. Here is what I got from Maestro tech support. The only cable that you need from the Maestro RR package is the black data cable. It's a 4 prong cable that plugs into the Maestro RR and goes into the 4 prong slot in the back of the 8400.
  15. Jul 10, 2019 at 11:19 AM
    #175
    TacoLoco17
    Craig
    Conshy, PA
    anyone having issue with the steering wheel controls working intermittently. It happens to me maybe once a week but once i shut off truck and restart it works again? The HU is updated to 1.01 and the maestro is updated also.
  16. Aug 12, 2019 at 1:45 PM
    #176
    dragonle87
    dragonle87 Well-Known Member
    Atlanta, GA
    '13 DCLB TRD Sport
    I'm planning to upgrade my factory HU soon. I've been reading throughout the forum. But still not sure what wiring harness, connectors etc that I will need.
    AVIC-W8400NEX has been discontinued. So gonna go with 8500.
    So far these are the things I will need:
    - Scosche Dash Kit
    - Maestro RR
    - T01 Wire Harness
    - 28-Pin Wiring Harness Jumper/Adapter
    I'm not sure what other wiring harness I need. My Taco have standard radio and no GPS.
    I look up Crutchfield and seems confusing.
    Thanks in advance if any body can assist me.
  17. Aug 12, 2019 at 1:52 PM
    #177
    TacoLoco17
    Craig
    Conshy, PA
    the install is fairly easy, hardest part is cramming all the wires into the dash
    Metra 40-LX11 - Antenna Adaptor Cable
    AXXESS AX-TOYUSB - USB-Aux
    Maestro HRN-RR-TO2
    Maestro Acc-SAT-TO2 (only for Factory Gps & satellite radio) if you don’t have that option you don’t need because you will be running the headunit supplied gps antenna and xm antenna
    i purchased from Amazon. and i got the 8400 from Ebay brand new for $700 with xm radio tuner
    dragonle87 likes this.
  18. Sep 3, 2019 at 2:25 PM
    #178
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    I installed the AVH 501 EX which has alot of the features minus Carplay. Great sounding unit
    I am also having steering wheel control issues. Crutchfield is sending a new Crux interface to see if this resolves my issue.
  19. Oct 4, 2019 at 3:28 PM
    #179
    Rockoma5
    St Louis
    I ended up having no luck with crux or the meastro they sent. Sent it back for a full refund. Now I am on the hunt for a new HU. Not sure if I should try Kenwood or Stay with Pioneer.....
  20. Oct 4, 2019 at 3:50 PM
    #180
    Taco_Coma
    South NJ
    2018 DCSB SR5
    I've been looking at a 4400nex/4500nex for a long time, Thinking it's the most logical option from pioneer. It has wireless carplay, which is a plus. but if you're really on a budget this seems like one of the better ones https://www.tacomaworld.com/threads/alpine-ilx-w650.595016/ but it only has wired carplay
