Pioneer - Metra - Orange wire - Installation help please!
Discussion in 'Audio & Video' started by MoonCrawler, May 12, 2016.
  1. May 12, 2016 at 1:45 AM
    MoonCrawler
    MoonCrawler [OP] Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    2003 Tacoma
    Pioneer DEH-80PRS
    Metra 70-1761 harness adapter
    I've read a bunch of posts about connecting the wrong orange wires together and either blowing a fuse for the dash cluster or even worse, burning up the rheostat.
    Most seemed to involve a orange/black wire on the metra harness. Some say to leave all orange wires alone to avoid any problems.
    The metra harness I bought (70-1761) that was packaged in 2012 doesn't have orange/black like most have reported about theirs.
    It DOES have a mostly orange wire with a faint and thin white stripe on each side. (great marking). No other orange wires.
    The metra key says orange/white is *Dimmer* whereas plain orange would be *illumination*.
    Pioneer has orange/white and says this is for *lighting switch terminal*. (That's so helpful)
    If I could, I'd like to have the radio light dim when the headlights are turned on. That would be *illumination* and not *dimmer*, no? I don't care about dimmer control via the rheostat knob.
    Has anyone wired these and achieved that without blowing up their truck?
    Should I just leave all orange alone? Nothing I've found online is very clear and my Metra harness which shares the same part number as others' somehow has a different orange wire.
    TacoTuesday!! likes this.
  2. May 12, 2016 at 1:57 AM
    Guywithatruck
    Guywithatruck New Member
    2008 2.7 Single Cab
    Every head unit I installed I left that orange wire capped. Some stereos have their own dimmer settings anyways.
  3. May 12, 2016 at 2:13 AM
    MoonCrawler
    Sacramento, CA
    Thanks for the reply.
    The manual for this HU says:
    "To prevent the display from being too bright at night, the display is automatically dimmed when the car’s headlights are turned on. You can turn the dimmer on or off."
    But I don't see how it would know unless it's tapped into the headlight wire somehow. (I guess that's what they mean by *lighting switch terminal*).
    I think you're right though. The orange on the metra is probably not the orange that the pioneer is seeking. Unless someone else chimes in, I'll just cap them.
  4. May 12, 2016 at 3:12 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The OEM head unit probably already had a lead for the headlight signal and maybe the dimmer.
    With any of the remaining unhooked wires, try using a meter to see its function.
    Or, locate one of the free service manual sites and look at the radio schematic.
  5. May 12, 2016 at 10:36 AM
    MoonCrawler
    Sacramento, CA
    I get that, that's what I'm trying to figure out. It's not clear in any of the info I've found or from the info on the harness adapter I'm using.
    Here's a diagram I've found:
    https://www.installdr.com/Harnesses/Toyota-Wiring.pdf
    There's no mention of an 'illumination' wire, which is what I'm looking for. The orange wire on my metra harness goes into slot "j" which is labeled "no not use".
    The OEM radio definitely dims. I just don't from where it gets it's signal.
    I also have the FSM with wiring schematics but either don't understand them or haven't found the info I need. That's why I asked here and also why I bought the easy hook-up harness.
    Anyway, thanks for the help. I may just leave them out and save it for another day.
  6. May 13, 2016 at 5:38 PM
    MoonCrawler
    Sacramento, CA
