Pioneer ???
Discussion in 'Audio & Video' started by fjrmurph, Nov 1, 2011.
  1. Nov 1, 2011 at 3:37 PM
    fjrmurph
    fjrmurph [OP] Well-Known Member
    If i install a Pioneer AVIC-X930BT Navigation Receiver will i be compatible with our rear camera? Has anyone installed this unit, any thing to say about it good or bad?
    THKS
    murph
  2. Nov 1, 2011 at 3:40 PM
    saitcho
    saitcho Well-Known Member
    New Orleans
    '11 DC 4x4 trd off road
    I had the same question. If I remove the factory radio, does that also disable the rear view camera? In other vehicles this was true, not sure here on a toyota.
  3. Nov 1, 2011 at 5:41 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Removing the radio does nothing to the late model rear-view mirror display from the camera. To use the camera feed on the X930 (or any other aftermarket video device) you will have to make a custom set of connections between the OEM wiring and the video input. I know I've seen a post with photos of which wires have to be tapped, etc., shouldn't be hard to find.
  4. Nov 2, 2011 at 12:50 AM
    fjrmurph
    BUMP
    Someone must have this system ?
  5. Nov 2, 2011 at 1:41 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Lots of people, myself included have the system. I answered about the camera - what else do you want to know?
  6. Nov 2, 2011 at 6:25 PM
    fjrmurph
    I guess what i'm trying to decide is should i attempt this install myself or leave it to a pro.
    THKS
  7. Nov 3, 2011 at 1:27 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Read the stickied items at the top of the forum. It turns out the Tacoma is actually quite easy compared to a lot of other cars. But if you're really nervous try to find someone in your area that has swapped out a stereo before. The basics are the basics, the only variable really is how to do the NAV/Video bypass, and the specific mechanisms of getting the old out/new in (pull climate control panel, undo 4 bolts, pull out, and then put new unit in. I would seriously suggest you get the Metra wiring harness adapters for Toyota, and if using the ASWC for steering wheel controls get that adapter too.
  8. Nov 4, 2011 at 9:25 AM
    fjrmurph
    i just talked to an installer he is telling me this unit Pioneer X 930BT, has a application that shuts down the DVD after 60 KPH, he is saying it picks up the 60 KPH from the GPS and there is no way to bypass it ??? is he full of shit, he is trying to sell me an Alpine HU ??
  9. Nov 4, 2011 at 3:30 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Don't know where you are located(KPH), but he is full of it for US models, from personal experience.
  10. Nov 4, 2011 at 3:43 PM
    fjrmurph
    OK thanks
    i just wanted to check before i dropped $1000.00 on this unit
  11. Nov 4, 2011 at 5:24 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Hopefully that's installed, and comes with speaker installation -- Crutchfield has it for $799 with full factory warranty, and Sonic has it for $569.
  12. Nov 9, 2011 at 11:53 AM
    roboots21
    roboots21 Taco Supreme!
    Brian
    Pittsfield, MA
    2007 TRD Sport DC LB
    Bilstein 5100's, Grillecraft, Flowmaster, Nitto's, NFab's, BHLM, BFLM, 20% tint, more to come.
    I have the 930BT and I love it. I did the parking brake bypass and also the mute wire hardware bypass and it works perfectly. Got mine for $550 on Amazon and got a $100 MIR through Pioneer. No complaints!
  13. Nov 9, 2011 at 4:46 PM
    fjrmurph
