PL5400 problem...already
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mcbagpiper, Jan 14, 2014.
  1. Feb 3, 2014 at 11:05 AM
    617mike9c1
    617mike9c1 Well-Known Member
    Newton, MA
    2008 DCLB Sport 4wd
    A little of this and a little of that
    Hmmmm... no contact from P&L as of yet. On Saturday, left them a VM and sent them an email explaining the situation. Called etrailer to let them know what happened and they will be following up with P&L.
    Not as critical anymore since I was able to jimmy open my tonneau cover with a long screwdriver and get access to the bed. Then removed the plastic tailgate plate and released the lock in the P&L handle. Ended up removing the whole stupid thing and reinstalled the OEM handle and called it a day.
    I'll give P&L another shot if they bother to call/email me since it may just be a bad lot of codable locks. We'll see what happens.
  2. Feb 4, 2014 at 12:04 PM
    617mike9c1
    Newton, MA
    2008 DCLB Sport 4wd
    Got in contact with lead tech guy, Jason from P&L and he was pretty helpful. He is going to overnight a new unit to me and have me send mine back to them for inspection. He mentioned that they've sold thousands of these already and only a small handful are reporting problems. So customer service (if you can find them) is pretty good.
  3. Feb 5, 2014 at 7:06 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Great to hear that customer service is doing there job, and backing up their warranty.
  4. Feb 10, 2014 at 7:42 AM
    mcbagpiper
    mcbagpiper [OP] Well-Known Member
    Ottawa, Canada
    14 DC/LB TRD Sport
    Tonneaupro hard tri-fold 3D Maxpider floor mats 10g steel skid plate N-Fab steps AVS bug guard & window visors 5100's @ 1.75" 1" steel rear blocks 265/70/17 Nitto Terra Grapplers Graphite metallic sport rims 20% front tint MBRP dual cat-back exhaust
    Just received my replacement unit today, hopefully it's problem free this time! Another positive word for P&L customer service.
  5. Feb 19, 2014 at 5:52 PM
    Kozy22
    Kozy22 Member
    RI
    Trd sport
    Anymore issues? Was wanting this but not so sure now
  6. Feb 20, 2014 at 4:49 AM
    617mike9c1
    Newton, MA
    2008 DCLB Sport 4wd
  7. Apr 6, 2014 at 4:51 PM
    Freezercat
    Freezercat Active Member
    '17 TRD Sport 4x4 Magnetic Grey
    Mine just locked up as well after about a month. Any tips on getting the back tailgate cover off when the tailgate is in the up position? It looks like it is still blocked in even after I take off the fastners?
  8. Apr 6, 2014 at 4:54 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There's some "pins" that go through the skin to lock it into position.
    It needs to lift away from the gate, then up.
    Can you get the screws out that are across the bottom? I thought they were hidden by the bed.
    Only way might be to simply cut an access panel in front of the latch, then use some "J" nuts to secure a replacement panel.
  9. Apr 19, 2014 at 8:09 PM
    Freezercat
    Received my replacement from Pop N Lock today - so on a positive note great response to customer claims. I went the route of removing the top tailgate cover then using screwdriver to push the mechanism holding the rods which released the tailgate.
    The replacement lock mechanism seems stronger... hopefully replacement will last longer than a couple months!
