Planning Lift - but how high and what tires? (pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TruKnight, Jun 24, 2012.
  1. Jun 25, 2012 at 3:35 PM
    #41
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Im running 285's with Spidertraxx 1.25 inch spacers here are some pics
    As far as what you will actually be trimming, normally it will be some of the actual fender flare. The way i found what i needed to trim was just drive normal and let it rub for a day or so, you will then see some marks where your tires are rubbing and just trim that area off.... Its a hit and miss thing took me a few days to get everything because i would hit a bump or dip and hear a new rub then i would find it and get rid of it....
    Ive been lucky so far and havent had to do the cab mount chop..
    As for what to use i used a small saw, but you can you anything really that will cut the fender....
  2. Jun 25, 2012 at 5:12 PM
    #42
    TruKnight
    TruKnight [OP] Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    That doesent look too bad, I think I kinda like them sticking out abit like that. Does it cause any issues?
    I guess ill do a drive and see with the trimming then. Hate to have to chop anything tho.
    Will the 1.25" spacer prevent rubbing on the uca also? Ive read other threads where I saw tires do that.
  3. Jun 25, 2012 at 5:23 PM
    #43
    BulletToothTony
    I like how it looks also, no really issues although it does throw mud, dirt, rocks etc on the rocker panels of your truck more doesnt really bother me though. At first i didnt want to have to cut into my new truck either, but then i was like fuck it lol and you dont really see it anyways. Only way you see it is if you really "looking" for it. And yes with the spidertrax i DO NOT rub my uca's...
  4. Jun 25, 2012 at 8:06 PM
    #44
    slcnbldr
    slcnbldr Well-Known Member
    Anthony
    Northern California
    DCLB TRD Sport
    20% tint on the front windows. 8-15-13 Installed Icons front and rear with Dakars. 2012 4Runner wheels with 275/70/17 BFG T/A KO2's. Weather Tech mats front and back. Leer shell with Leer Locker and roof racks.
    OP thanks for the post it has also finalized answering all my questions as I am doing the same. Mostly road driving other than the winter steelhead fishing trips. I'm going with Option 2 (OME w/ Dakars) with the LR UCA's, spacers and either 275-70-17 or 285-70-17 BFG A/T's on sport wheels like yours. Leaning to the 275's as I think they will fit the wheel a bit better but BulletToothTony's may make me change my mind. And after all the reading and research I cannot wait to get it done!!!
    BTW nice trucks to all the guys who posted here thanks.
  5. Jun 25, 2012 at 8:31 PM
    #45
    TruKnight
    Tru
    Arkansas
    read build thread
    Sure thing man, im still reading and researching myself while I raise the dough I need for this. Time to crack open that jar of pennies! Im prolly a month away from ordering parts here tho, I like to have things paid for before I order them.
    One kinda funny thing in all my searching and reading is that, in alot of the posts, the first reply is usually 'use the search', which is kinda ironic when it was the search that showed me the thread asking the question I wanted to know the answer to also. :confused:
    Next thing ill be looking for is good places to buy all these parts from or places I should avoid buying from.
  6. Jun 25, 2012 at 8:42 PM
    #46
    slcnbldr
    Anthony
    Northern California
    DCLB TRD Sport
    I'm on about the same timeline as you to have it paid for when shipped to me. I've found on here seems to be the place of choice. And OZ-T has let me know I may not need the spacers with 275's...thanks OZ-T
    Post pics when you get it done.
  7. Jun 26, 2012 at 6:16 PM
    #47
    TruKnight
    Tru
    Arkansas
    read build thread
    I will definately have several dozen pics to share when its done no doubt.
  8. Jun 30, 2012 at 8:29 PM
    #48
    TruKnight
    Tru
    Arkansas
    read build thread
    I hate when threads end abrubtly with no resolution, so heres what ive decided to go with:
    Front:
    OME 90000 NitroCharger Sport Front Shock Set
    OME 885 front coil springs
    OME 95PF5 5MM Trim Packer
    Light Racing UCA's
    Front Extended Brake Lines
    Rear:
    OME N182 NitroCharger rear shocks
    OME CS047 2.75" Lift Dakar Leaf Spring Set
    Bushing set
    U-Bolt Set for OME Leaf Springs
    Solid Steel Axle 3 degree Shims w/ Leaf Spring Center Bolt & Center Pin Collars
    Rear Extended Brake Lines
    Tires:
    BFG AT T/A KO 285/70/17
    Spidertrax Wheel Spacers 1.25"
    Total cost from parts to rolling down the road: 3k ish, give or take.
    _____________
    Ive also tracked down some pics of what the final setup should look like:
    First one is a photoshopped swb (#3 from my first post) and the second one I found from google image search.
    (Hopefully some of you people in the future doing searches on this will find this helpful also.)
  9. Jun 30, 2012 at 8:35 PM
    #49
    BulletToothTony
    :woot: looks like a good setup tru cant wait for you get everything put on...
  10. Jun 30, 2012 at 9:16 PM
    #50
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Same set up as me except the 285's , I have 275 ATm's , no wheel spacers ^^^^^
  11. Jun 30, 2012 at 10:11 PM
    #51
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    Rather then start a new thread -
    I need new tires ASAP. I'm looking to get taller ones, but obviously I'm limited by ride hight. Do any of these lift options cost wheel travel? I really can't sacrifice any wheel travel as my primary off-roading is done in the dunes and flats.
    Long term goal is to go Long-Travel.
  12. Jul 1, 2012 at 1:37 AM
    #52
    BulletToothTony
    What kind of tires are you running now and what kind of lift do you have?
  13. Jul 1, 2012 at 3:56 AM
    #53
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    slcnbldr, your TRD sport should be able to fit 275/70r17's on there stock, have them on mine, no lift no rubbing on my 2012 TRD sport. Have beat it hard off road and no rubbing, well in sand and mud anyhow. All we have in Florida
  14. Jul 1, 2012 at 9:09 AM
    #54
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    I'm stock TRD OR
  15. Jul 1, 2012 at 9:50 AM
    #55
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    With any lift other than LT you will loose some down travel. With stock suspension you can fit 265/75/16s (a little over 1" taller) and will look good stock to 3" lift. Any larger and you need a lift.
  16. Jul 1, 2012 at 11:04 AM
    #56
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    looks good OP, full OME is your best bet for 2.5"-3" lifts, also good choice on the LR UCA's, you will lose 1-3 mpg's running 285's because they're wider, just throwing that out there
