Planning on Bilstein 5100s, 1.5 AAL rear. Need some advice.
Discussion in 'Suspension' started by adamryi, Aug 6, 2011.
  1. Aug 6, 2011 at 12:04 PM
    adamryi
    adamryi [OP] Member
    Planning on getting the Bilstein 5100s front (downsouth motorsports), and the 1.5 AAL from wheelers offroad. My currently model is the 2007 Toyota Tacoma 2WD Double Cab 4.0L V6, NON TRD, NON TSB. Ive been searching around and saw this is a pretty solid setup for someone who doesnt offroad. 95% of my driving will be highway, and 5% will be on bumpy gravel dirt roads to get to some good fishing spots. I plan on running the 2.5" up front. Would this be a good setup for my driving conditions? Anyone know the biggest tire size I can fit without having to trim or cut? Thanks!
  2. Aug 6, 2011 at 12:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Lots of folks are running that set up. You'll need to consider getting new shocks for the rear, and the best option is a set of Old Man emu springs and the billy's set at 0" for the best ride. Also consider some new Upper Control Arms to get the alingment back in check. Do a search on 5100 lift for more info, and what others think about the set up youre considering.
  3. Aug 6, 2011 at 1:49 PM
    adamryi
    adamryi [OP] Member
    Thanks for the info. Im also thinking about getting the TSB done, and just getting the bilstein 5100 for the front to keep it level. Ive read that 265/75/16s will fit stock suspension no problem but what offset does the wheel need to be?
  4. Aug 6, 2011 at 3:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thta tire size fits the OEM wheel.
  5. Aug 6, 2011 at 4:20 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x2 and if you are looking at aftermarket wheels, wheels with a backspacing of between 4.5" and 5.5" will work for the 265's.
    The offset for that particular setup will vary depending on the rim width.
  6. Aug 6, 2011 at 4:53 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're going with 5100's from Downsouth Motorsports, they also sell Icon's 3-leaf AAL which is the same as the one from Wheeler's. Althought Wheeler's is a great source, it might save you some shipping costs if you get everything from one vendor.
  7. Aug 6, 2011 at 5:05 PM
    Pugga
    Massachusetts
    WHAT?!?! I had to pay shipping for my crap!! It's not bad though.
  8. Aug 6, 2011 at 9:01 PM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    So when I get back to the states and pick out my truck I was going to ask the dealer if they will install 5100's all the way around for me along with the AAL. Should I have them set the front to 1.75" and the rear at 0 if I go with the Icon's 3-leaf AAL? I know a lot of you are sick of this question. LoL
  9. Aug 6, 2011 at 9:16 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Just fyi 1.75 don't need UCA to get alignment in check. Also the rear billys are not adjustable. Just the fronts are. 1.75 with a 1.5 AAL, 265/75/16, 4.5 BS makes a perfect stance IMO. (Check my pics I have this setup) Being that your truck is a 07, don't waste you time trying to have toyota do the tsb. Try to shop around for a independent shop for the install, you'll get out a lot cheaper. Its a basic shock replacement so a decent shop should be able to do it no problem. Just buy a 1.5 aal or the icon 3 aal. I've heard nothing but good things about the icon setup.
