Please check my diagram
Discussion in 'Technical Chat' started by aro, Oct 27, 2019.
  1. Oct 27, 2019 at 1:52 PM
    aro
    aro [OP] Well-Known Member
    Orange County, CA
    2019 OR DCLB 4X4
    Does this wiring look good? I want to get one of the many generic aux fuse panels (correction: switch panel kit) for some lights, no big draw. I want to power it from the ignition though, not the battery.
    My next question is, any suggestions what fuse to tap?
  2. Oct 27, 2019 at 1:58 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    100 amp fuse? What are you running off of it? Almost zero point of even having a fuse if youre gonna use one that high in a vehicle haha.
    Running Board Man, whatstcp and Hobbs like this.
  3. Oct 27, 2019 at 1:58 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Are you planning to run a "generic aux fuse panels" or a "switch panel kit"?
    Your diagram suggests to me that you plan to run up to 100 amps through a Bosch-style relay. Is that your intent?
    Running Board Man and Blue92 like this.
  4. Oct 27, 2019 at 2:00 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That looks correct to me. Just wanna make sure you have a relay that can handle the current, which aren't hard to find.
    SR-71A likes this.
  5. Oct 27, 2019 at 3:00 PM
    aro
    Orange County, CA
    2019 OR DCLB 4X4
  6. Oct 27, 2019 at 3:32 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I would figure up what the amperage draw of whatever you wanna run off the circuit is, then find a breaker that suits it better. 100 amps is a lot. The wire will definetly melt at that amperage before the breaker is gonna trip. Unless youre running like 4 awg into the cab.
  7. Oct 27, 2019 at 3:38 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I’d consider wiring the relay a constant hot rather than an ignition keyed source. That will give you the flexibility to run the lights whenever you want rather than only by leaving the key turned on in the truck.
  8. Oct 27, 2019 at 5:40 PM
    aro
    Orange County, CA
    2019 OR DCLB 4X4
    The relay will be about 1 foot from the battery, and the 100 A circuit breaker will be between them. Basically, I would have a 1 foot long 4 awg cable, between the relay and battery. The relay will be on top of the switch panel box. Shouldn't be a problem with such a short run.
    I know... I'm still thinking about this.
  9. Oct 27, 2019 at 5:51 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    What are you running thats gonna pull anywhere near 100 amps? Thats so overkill that it could be dangerous. Find out how many amps the load is gonna draw and utilize an appropriately sized breaker. If it draws 25 amps, use a 30 amp breaker for example.
  10. Oct 27, 2019 at 5:55 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No it’s not. If anything it’s more safe. Once you start adding things up, i.e. fridge, lights, compressors, etc. it’s best to err on the side of overkill and have a wire that’s too thick as opposed to too thin. Plan for worst case scenario of all things running at once and add a little cushion.
    Hobbs likes this.
  11. Oct 27, 2019 at 5:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So we're assuming "Engine Fuse Box" is ignition switched, right?
  12. Oct 27, 2019 at 6:06 PM
    0xDEADBEEF
    I'm not sure how you're getting that a higher current fuse/breaker is safer. I'm all for thicker wire, but the fuse should be sized just a big bigger than the load you want to run, and then upgraded as additional loads are added.
    Blue92 likes this.
  13. Oct 27, 2019 at 6:10 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Im not reffering to wire, Im talking about the breaker size. If his load is only gonna draw 50 amps for example, why would he need to utilize a 100 amp breaker? Thats a ton of room for error and stuff to start smoking. ARB fridge doesnt draw anywhere near that per this thread . OP, again, what are you planning to run?
    Running Board Man likes this.
  14. Oct 27, 2019 at 6:11 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    If the fuse/switch panel he is running has individual fused circuits (like a Blue Sea) I wouldn’t be concerned because the individual outputs are protected at that point. Even if it’s something like a Switch Pro he can wire each output fused independently appropriate to its draw. The 100amp breaker is essentially just protecting the fuse/switch panel from failure.
    Area51Runner likes this.
  15. Oct 27, 2019 at 6:12 PM
    0xDEADBEEF
    Agreed.
    I think we need more schematic than will fit on the post it note he posted.
  16. Oct 27, 2019 at 10:33 PM
    aro
    Orange County, CA
    2019 OR DCLB 4X4
  17. Oct 28, 2019 at 1:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah what he said. Each circuit is fused on its own so the large 100A fuse/circuit breaker is for say if you get in a front end collision, and that 4 gauge wire breaks free. Now instead of being able to freely short out on something metal and potentially starting a fire, the fuse should prevent that.
  18. Oct 28, 2019 at 2:14 AM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    Please check my diagram. That’s what the blonde said to the gynecologist.
  19. Oct 28, 2019 at 3:12 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    I like your idea to have the power supply switched with the accessory circuit. But isn't the Bosch Relay only rated for 40 amps? Your probably going to need a solenoid for this.
  20. Oct 28, 2019 at 3:32 PM
    aro
    Orange County, CA
    2019 OR DCLB 4X4
    True... something to keep in mind when calculating the load
