please dont hate me tacoma world
Discussion in 'Wheels & Tires' started by Detective_Dan, Dec 26, 2010.
  1. Dec 26, 2010 at 6:42 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i want to get nitto terra grapplers and they dont have them in a 275 which is what i wanted. i have the rear spring TSB done, so if i get bilstein 5100's up front set at 2.75, will 285/70/17's fit without rubbing?
  2. Dec 26, 2010 at 6:45 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The billy's go up to 2.5". You can run those 285's (if you have aftermarket wheels with 4.5" backspacing, or wheel spacers on you stock rims) with some trimming.
    You'll be nose-high with the tsb rear and the fronts at 2.5 though.
  3. Dec 26, 2010 at 6:47 PM
    Detective_Dan
    Colorado Springs
    im getting aftermarket wheels as well, forgot to say that. they have a 4.5 bs so im good there. if i set the billys at full height (thought it was 2.75 sorry) its still gonna rub?
  4. Dec 26, 2010 at 6:50 PM
    KPT
    09 Prerunner
    yep, setting them at 2.5 will mean you will still have to trim fender well plastic, and possibly chop the cab mount.
    If you want to see a no-trimming-required option, check out my build in my sig. I have the billys at 1.75, tsb rear, and 32" tires (265/65/18)
  5. Dec 26, 2010 at 6:53 PM
    Detective_Dan
    Colorado Springs
    well fuck lol. i guess ill try hard to find 275's or ill just stick with 265/70/17
  6. Dec 26, 2010 at 6:57 PM
    KPT
    09 Prerunner
    It's not the width that's the problem its the diameter.
    You could do a 32" 285 and likely won't have to trim.
  7. Dec 26, 2010 at 7:10 PM
    Detective_Dan
    Colorado Springs
    you helped me out a few days ago when i had all these tire questions so im assuming you know a lot about them (at least more than i do)
    so with these wheels....(on the chart, 5th one down)
    http://jkwheels.com/product.php?productid=2098&cat=0&page=1
    what is the largest tire i can run with billys set at 2.5?
  8. Dec 26, 2010 at 7:19 PM
    KPT
    09 Prerunner
    Those are 17x9', -12 offset. That calculates to 4.5" BS, so you are good to go there (like you mentioned earlier).
    The biggest common size you can run without ANY trimming is 265/70/17. With some trimming and a possible cab mount chop, you could upsize to 285/70/17.
    For the odd sizes in between, like 275's, it's hard to say, because there haven't been many people before you to try it, because the tire size is uncommon.
  9. Dec 26, 2010 at 7:23 PM
    Detective_Dan
    Colorado Springs
    well im fine with trimming some plastic, thats not a problem. im NOT comfortable with chopping the cab mount because it actually serves an important purpose. if it does rub, its only gonna be with the wheel cranked fully right or left correct?
  10. Dec 26, 2010 at 7:25 PM
    KPT
    09 Prerunner
    Correct.
  11. Dec 26, 2010 at 7:26 PM
    Detective_Dan
    Colorado Springs
    well, i can live with that. theres not many times i have to pull the steering wheel that hard anyways
