Please help diagnose my abandoned TACO in the mountains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDBandit, Jul 23, 2011.
  1. Jul 23, 2011 at 7:43 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    That definitely looks like a bent spindle, same exact thing happened to me. Just have to replace the spindle. Yes it is drivable, throwing the spacer on there is a good temporary fix. Just don't drive on it too long to avoid uneven wear on your tires. ;)
    Good luck!
  2. Jul 23, 2011 at 7:44 AM
    TRDBandit
    TRDBandit [OP] TACOMANATOR
    Justin
    CRAWLORADO
    07 Dbl Cab TRD O.R. Dark Blue
    Afe Stage 2 CAI Tinted windows Many to come
    How much is that? Is it hard to do?
  3. Jul 23, 2011 at 7:44 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    A spidertrax spacer could maybe limp your truck home very slowly?
  4. Jul 23, 2011 at 7:45 AM
    TRDBandit
    Justin
    CRAWLORADO
    I hope lol. I am going to 4wheel parts to see if they have some
  5. Jul 23, 2011 at 7:45 AM
    Dark Knight
    Jeff
    NC/SC
    Or at least get the truck to where a normal tow truck could pick you up versus the more expensive off road recovery tow truck
  6. Jul 23, 2011 at 7:46 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    I was thinking the same thing...
  7. Jul 23, 2011 at 7:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    <-- agrees with ^^^ youz guyz
    It might, but what bothers me is you said the further you moved it, the worse the wheel dug into the suspension.
    I'm not 100% sure pre-runner spindles work on a 4x4. Is the bore size the same?
  8. Jul 23, 2011 at 7:56 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'm 99% sure the stock prerunner and 4x4 spindles are identical.
  9. Jul 23, 2011 at 7:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    What's the 1% holding you back?
  10. Jul 23, 2011 at 7:58 AM
    TexasTacoma37
    The fact that it's from what I've read on here, and not from first hand experience. :)
  11. Jul 23, 2011 at 8:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    I know most aftermarkets aren't interchangeable. It would make sense that the stocks would be the same, from a manufacturing standpoint anyway.
  12. Jul 23, 2011 at 8:00 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    spindle is def bent. might be able to do the change where its sittin and drive it out.
  13. Jul 23, 2011 at 8:13 AM
    Dark Knight
    Jeff
    NC/SC
    This is a problem if that is bent. I cant tell, weird angle maybe??
    Time to stop mobing stuff huh?
  14. Jul 23, 2011 at 8:15 AM
    Dark Knight
    Jeff
    NC/SC
    Maybe it looks funny because the bent spindle is putting pressure on the bushing making it look weird to me?
  15. Jul 23, 2011 at 8:19 AM
    #35
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    If no spacer, maybe a stock wheel / tire.
    PK
  16. Jul 23, 2011 at 8:20 AM
    #36
    Dark Knight
    Jeff
    NC/SC
    Thats what he is running. But good idea, an aftermarket wheel / 265 tire could do the job...
  17. Jul 23, 2011 at 8:25 AM
    #37
    TRDBandit
    Justin
    CRAWLORADO
    I got the stock wheel on there now since its smaller. I think I might have a shot with the spacer! Heading up there soon
  18. Jul 23, 2011 at 8:26 AM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    :popcorn:
    Good luck Justin
  19. Jul 23, 2011 at 8:43 AM
    #39
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I was going to suggest the stock wheel only because you probably have it on the truck--and who cares if you trash the tire? It's reasonably cheap.
    Good luck to you.
  20. Jul 23, 2011 at 1:46 PM
    #40
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    If It's the uca I have one in garage if ya need it.
