Please help...found the source of my squeak! Is this dangerous?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Apr 25, 2011.
  1. Apr 25, 2011 at 5:17 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Ok I was spraying some WD-40 to see if it would help my squeak and I noticed I'm missing a nut and washer from the bolt in the pics and the bolt has slipped out a little but cant slip anymore because the head of the bolt is up against another part. :eek:
    I hope it's not dangerous to ride like this for a day or two so I can get a nut and washer like the other side has. Where can I get one of these nuts and washers? I need these soon!
    Thanks guys! :)
    Sorry the last two pics should be rotated.
  2. Apr 25, 2011 at 5:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Certainly not good- but like you said- it's not gunna go anywhere. Just get a bolt and washer on it ASAP.
  3. Apr 25, 2011 at 5:20 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Well , that's less than awesome .
  4. Apr 25, 2011 at 5:22 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    fixed:)
    what does that hold on exactly? i cant see ha
  5. Apr 25, 2011 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Leaf springs.
  6. Apr 25, 2011 at 5:28 PM
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    2019 Tacoma Cav Blue
    Ha. I was doing the diff breather mod about a month ago and saw the same thing happened to me. Except my bolt had back out as well. Couldn't get it back in. Drove to the dealer about 15 min away no problem and got it fixed with a bolt and lock tight. Should be fine to drive til you fix it just don't jump your truck.
    I had no idea how long it was like this, thank goodness I caught it before it flew out completely. Apparently once the nuts loosen up back there they pretty much just go. Glad I caught it before going to the desert with lembowski that night ;)
  7. Apr 25, 2011 at 5:31 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Good call...I'm in the middle of planning a cross country trip for tmrw...Not totally paying attention...
    Good news is-It's fixable!!
  8. Apr 25, 2011 at 6:10 PM
    jmed99
    SC
    The nut that came off on mine is actually the nut right above the one that came off one yours.
  9. Apr 26, 2011 at 11:22 AM
    Kauluwela
    Kauluwela Well-Known Member
    Dave
    Seattle, WA
    07 TACOMA DOUBLE CAB V6 6SPD TRD
    TOYTEC SPACER, OME 885'S, OME STRUTS, TOYTEC DIFF DROP KIT, TOYTEC CARRIER BEARING DROP KIT, LIGHT RACING UCA'S, DEALER TSB'S, OME AAL, OME SHOCKS, VISTA TOP, GROM AUDIO IPOD INTERFACE, ALL PRO EXTENDED BRAKE LINES, ALL PRO SLIDERS, FULL LIMO TINT, AMERICAN RACING MOJAVE WHEELS, WILD COUNTRY XTX 285-70-17, HI-LIFT, TOYTEC HI-LIFT SLIDER ADAPTER
    Go to your local screw and nut store and get Grade 8 Nylocks that match the thread angle and replace all of them. Torque them to spec. Problem solved.
  10. Apr 26, 2011 at 11:33 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    use lithium grease or penetrating oil instead..it coats the rubber so much better than wd40..wd40 is old technology now..hope this helps
