Please help... Need stereo diagram
Discussion in 'Audio & Video' started by Jubei99, Mar 20, 2017.
  1. Mar 20, 2017 at 4:34 PM
    Jubei99
    Jubei99 [OP] Active Member
    Arizona
    2010 White Tacoma Double Cab Sport
    I was able to swap my 2010 JBL head unit with a 2014 JBL navigation unit using a Entune wiring pin out diagram off a 2012 diagram. I hit a snag though. The wiring configuration for the voice signals wires that control the voice navigation directions doesn't match with 2012 to 2014. When I use my navigation you can hear the music dim out when directions commands are prompted but no voice. I even went to my local Toyota dealer. I was told that the stereos couldn’t be swapped. After he seen it with his on eyes. He went into Toyota TIS system and was unable to locate the pin out. Could anyone please tell me where or how to find 2014 stereo pin-out diagram like this? Thanks in advance...
  2. Mar 20, 2017 at 5:22 PM
    DunkinDal
    DunkinDal Active Member
    South of Boston
    2015 TRD Off Road
    here is the wire diagram for the Mic on a 2014 jbl nav
  3. Mar 20, 2017 at 5:48 PM
    Jubei99
    Arizona
    DunkinDal, my mic works fine through the stereo Bluetooth as far as voice commands Ex( Phone calls, tell my Nav to "Go Home". My voice navigation for directions doesn't work. If you look at the Entune connections 2010-2012 attachment I posted. 2012 has R16 pin-out. The 2014 stereo has R31 pin-out.
  4. Mar 21, 2017 at 4:41 AM
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
  5. Mar 21, 2017 at 4:51 PM
    Jubei99
    Arizona
    Bear263, I appreciate the diagram. I'm having a hard time reading it. If you look at the Entune connections 2010-2012 attachment I posted. Where would I connect IVO+, IVO- voice signal of my R3 harness too? I didn't see any wires labeled as voice signal on the chart you provided.
  6. Mar 21, 2017 at 6:34 PM
    bear263
    Florida
    IVO+ goes to pin 2 on the 2014 radio 6 pin plug
    IVO- goes to pin 6 on the same 6 pin plug
    Don't worry about the 2014 diagram saying that those pins are RL+ and RL-. Both 2010 IVO+/- and 2014 RL+/- goes to the same pins on the jbl amplifier.
    Here's a 2012 diagram. Toyota didn't change anything between 2010 and 2013. There's added quotes to give you an idea of how to wire things up.
    http://www.mediafire.com/file/c2eajhwyg2gjcrd/KingKoda+2012.pdf
  7. Jul 24, 2017 at 8:08 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Philly
    2009 AC TRDOR
    thanks for posting this. I have a 2015 radio in my 2009 truck. My intentions are to get the rear view camera from the mirror to the radio screen. I mistakingly bought the camera source harness that will do this but for 2010-2013 IIRC. I think I can still use it for the truck side of the harness. the radio side I Will have to cut the plug off and repin the wires into the radio. from that wiring diagram (please correct me if I'm wrong) I'll need the N26 white plug at the radio. In this plug, I need to utilize pins 11 CA+, 12 V+, 23 Camera Ground, and 24 V-. as long as those wires are in the same positions to match my trucks wiring, I should be good. I just need to verify that.
  8. Jul 26, 2017 at 6:04 PM
    bear263
    Florida
    I don't know about the camera. I left my 2013 in the mirror as I like it better there. But looking at the diagram, you seem to be correct in your wireing.
    Redmann[QUOTED] likes this.
