Please help pulley bearing replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slazz29, Mar 18, 2020.
  1. Mar 18, 2020 at 1:21 PM
    Slazz29
    Slazz29 [OP] Well-Known Member
    Colten
    1995 Tacoma 2.7 3.5 inch offsets black
    Barnes 4wd diff cover bull bar kc lights toolbox smoked tail lights 3 inch leveling kit ion alloy 3.5 inch offsets 31x10.50r15 gt's
    Ok so this is a pic of my 2007 taco v6 standing right at the front looking straight down in on the pulleys. The small pulley wheel in the middle of the pic you can grab it and feel play in it now. I'm getting this kind of rattle grind noise on idle now and I think it is the culprit. This is one of the idler pulleys? The small one in the middle of this pic. Can I get just a bearing and replace it? If so where can I get one? And how do you go about taking the belt tension off? The pulleys are left handed threads right? Any help would be greatly appreciated
  2. Mar 18, 2020 at 1:25 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  3. Mar 18, 2020 at 1:27 PM
    anthony250f
    Anthony
    San Diego, CA
  4. Mar 18, 2020 at 1:38 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Mar 18, 2020 at 3:58 PM
    Slazz29
    Colten
    Ok is that small pulley the tensioner pulley? I have the v6 4.0
  6. Mar 18, 2020 at 4:02 PM
    BillsSR5
    bill
    2014 SR5
    yes the small pulley looks to be the tensioner pulley in your picture,most times they replace the whole tensioner arm with pulley, but if you just got a bad pulley bearing might be easier to do just the Pulley, seems that replacing the pulley might be the best option, I would use an OEM.
  7. Mar 19, 2020 at 12:44 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  8. Mar 19, 2020 at 3:44 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    I did all 3 with a new belt for under 100.00 and 20 mins.
  9. Mar 19, 2020 at 8:53 AM
    Slazz29
    Colten
    Ok thanks for the help I got an idler pulley on the way it will be here tomorrow. Now to get the belt off I take it the tensioner is right in the center of them I haven't looked at it yet but is it pretty easy to loosen the tension?
  10. Mar 19, 2020 at 8:57 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It's not left hand thread.
    You CAN knock out bearings and just replace them. Motion should have them. Koyos prob. but any name brand is good. No name, no good.
  11. Mar 19, 2020 at 12:31 PM
    Slazz29
    Colten
    Any part #'s for the bearings with a v6? Do both idlers take the same bearings
  12. Mar 19, 2020 at 12:39 PM
    BillsSR5
    bill
    2014 SR5
    Crux, I thought the Tensioner pulley on the v6 4.0l was a reverse thread? righty losey?
  13. Mar 19, 2020 at 12:58 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I quite probably am mistaken then. Carry on.
    That's not a great idea to just go throwing that stuff out there once in while. Ford Courier trucks had LH thread lugs on pass. side. Most people broke a few. Well, I did anyway.
    Wyoming09 likes this.
  14. Mar 20, 2020 at 2:34 PM
    Slazz29
    Colten
    Can anyone tell me how to remove belt tension. I know the tensioner but how does it work. Putting a ratchet on it and rotating it clockwise doesnt work
  15. Mar 20, 2020 at 3:16 PM
    BillsSR5
    bill
    2014 SR5
    https://www.youtube.com/watch?v=V67u-wf6iY0
  16. Mar 20, 2020 at 4:00 PM
    Slazz29
    Colten
    Update got the belt off and new idler pulley off and the sound still remains...it only makes the sound on idle and the sound appears to be around the ac compressor. Sounds like a higher pitched bearing growl. It goes away immediately if you increase rpms. Could this be the water pump? Any advice would be appreciated. I'll try and post a video
  17. Mar 20, 2020 at 4:26 PM
    BillsSR5
    bill
    2014 SR5
    with the belt off did you spin all the other pulleys and listen for sound or not spinning smoothly. could be in need off all pulleys replaced
  18. Mar 20, 2020 at 4:44 PM
    Slazz29
    Colten
    Yes I spun the pulleys that would move and the idlers had a bit of play but were quiet. Alternators ever make a growl? I cant post a video for some reason
  19. Mar 20, 2020 at 4:51 PM
    Slazz29
    Colten
    Update if I turn up the radio the noise goes away! Getting pretty frustrated now so I'll just give it time to either fix itself or get louder and easier to locate!
  20. Mar 21, 2020 at 12:19 AM
    muddog321
    FL
    If its a 2007 then replace all 3 idlers and the tensioner. Then on to possible alternator or AC compressor. Flush the PS pump/rack as detailed on other posts.
