PLEASE HELP!!! SUSPENSION TROUBLE
Discussion in 'Suspension' started by Jacobw6, Feb 2, 2012.
  1. Feb 2, 2012 at 2:40 PM
    Jacobw6
    Jacobw6 [OP] Active Member
    Lake Village, AR
    White lightnin'
    Hellbent 3" lift. Aem bruteforce cold air. Pioneer p2300dvd screen. Aftermarket smoked cab lights. Active suspension system in rear.
    getting some 33's saturday. will post pics so you can see! and monday i will fix the "taco lean"
  2. Feb 2, 2012 at 2:43 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Well I wouldn't have expected the ride to change any, but be aware that you are allowing the suspension to extended 4" further than it was designed to do at full droop. That binds the ball-joints big time. Don't flex the truck offroad, or go over speed bumps quickly if you don't want to damage the truck.
    also a top plate spacer setup like that makes the front bump stops useless. You'll bottom out the shock way before you hit the bumps.
  3. Feb 2, 2012 at 2:46 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    its not exactly 4", but its considerably more, i can tell if something overextends or gets in a bind. so back to the lean problem, would taking out the washers do the trick???
  4. Feb 2, 2012 at 2:49 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Apparently you cannot tell. Take all of the washers out, they are not intended for lifting a truck. Get a taco lean spacer and it will be fixed. Your not going to find many members here that will recommend any type of "cob-jobbing", and yes thats what you did
  5. Feb 2, 2012 at 2:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  6. Feb 2, 2012 at 2:51 PM
    TexasTacoma37
    Whatever you say man but I'd get that entire lift off the truck asap. It is damaging the suspension, whether you notice it or not.
  7. Feb 2, 2012 at 2:57 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    what the hell is the difference between a lean spacer and a washer? nothing at all, except looks, and price. One is free at any parts house, and the other is an ungodly amount. does the same exact thing. a simple yes, take some out or no, it wont help would have sufficed. but i can see that people who dont work on their own vehicles wouldn't know. good day
  8. Feb 2, 2012 at 3:02 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    One is a solid piece of billet... one is a stack of washers. The top plates cost what, $20? You have an expensive truck and you want to lift it with $0.05 washers?
    Also, if you're truely at 4" of lift, your CV angles would not look good and you wear out your CV boots and joints very quickly. You asked us for help, don't jump on us because we're pointing out the flaws in your logic... :cool:
  9. Feb 2, 2012 at 3:06 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Well for one a washer is used to spread the load of a bolt. A spacer is made to place a space between two items. Clearly you are not that mechanically enclined or you wouldnt need us to tell you that your gas tank is on the drivers side and weighs down the DRIVERS SIDE. Did you ever notice your lean occurs more with a full tank? Obviously you didnt :rolleyes:
    And thats funny how you say you work on your own vehicles but just a few posts back you whined about removing your diff drop because "its too hard" lol
  10. Feb 2, 2012 at 3:13 PM
    TexasTacoma37
    Right.....we're the ones who don't know what we are taking about
  11. Feb 2, 2012 at 3:17 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Heres your simple yes, take all the spacers, washers, and blocks off the truck. Start over. Make a decision how much lift you want. Spend a good couple hours on this site and make good friends with the search function. Then you'll know exactly what to do in order to have the truck sit and look exactly like you want it to.
    As for that last comment, you'll find that a majority of the active people on this site do work on their own vehicles, and that's exactly why we are telling you what we are telling you. As a matter of fact, I'm 18 and the only time my truck goes in to the shop is for an alignment or my state inspection.
    Good day and good luck to you sir.
  12. Feb 2, 2012 at 4:01 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What's the angle of your cv's look like?
  13. Feb 2, 2012 at 5:17 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Well since your shock is now your bump stop when you bottom out the entire weight is on 3 washer sized spots on the shock tower. There is a reason your shocks have a plate at the top, so it spreads the load.
    I guess if he ever wheels it will be a toss up at which part will break first. He might break a ball joint, or break a spindle with the gnar added 4" droop. He might break a shock or maybe even punch the washers through the shock tower from the loss of 4" of uptravel.
  14. Feb 2, 2012 at 5:24 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    If you knew what you were talking about, you would know that that lift will result in a broken shock or other bj problems, also that the diff drop does NOTHING.
  15. Feb 3, 2012 at 5:08 AM
    #35
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    Still waiting on pics of this setup!
  16. Feb 15, 2012 at 9:52 AM
    #36
    tybikes
    tybikes Member
    I've noticed this lean on my 2010 as well, and more noticeably recently on the front left. I have the stock suspension setup, which I would think/hope would address any weight differentials due to battery, gas tank, etc. Anyone having this issue with the stock suspension? I hate to take it to the dealership and pay the BS diagnostic fee only to have them tell me its just a poor design and not covered under warranty or something.
  17. Feb 15, 2012 at 11:18 AM
    #37
    TexasTacoma37
    lol forgot about this thread.
  18. Feb 15, 2012 at 11:23 AM
    #38
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Not a 100%, (about 99% tho') on this but I'd get those washers out of there, the strut towers are not that thick of steel & they're designed for a flush fit all the way around the inside of the tower. Washers are going to cause a "rocking" effect & eventually will fatigue the metal around the washers & they'll crack & possibly rip away from the tower & sure i don't have to say what a fun ride that'd be... just my $.02;)
  19. Feb 15, 2012 at 11:26 AM
    #39
    TexasTacoma37
    Yeah we tired telling him that but he got mad and hasn't been back on TW since :laugh:
  20. Feb 15, 2012 at 11:26 AM
    #40
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    didnt see this, 100 % true
