PLEASE HELP - TRUCK WONT START
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rlofthouse, Feb 14, 2016.
  1. Feb 14, 2016 at 12:54 PM
    rlofthouse
    rlofthouse [OP] Well-Known Member
    Robert
    Bay Area
    2024 Tacoma TRD OR
    I decided to replace the spark plugs and battery in my truck, the original plugs had been in for 75K miles and battery over 5 years. I thought it would be a good preemptive idea to replace them in my 2008 2.7L. Tacoma. After putting in two new sets of plugs, the car wont start. What is going on?? Here is a breakdown below:
    Yesterday: Bought and installed new Denso SK20HR11 Plugs along with a new car battery. I did not gap these. After starting car- I noticed a pungent smell of gasoline coming through and car could barely keep idle. I thought plugs were maybe defective so I took them back and got a new set of 4.
    Today- Before installing new plugs, I decided to install the OLD Original plugs to make sure the problem was in fact the plugs. Sure enough, the car started (although it still was not idling like it normally does). I then put in the new set of plugs, and now the car wont start..
    Please advise.
  2. Feb 14, 2016 at 1:16 PM
    Joe D
    Joe D .
    Have you checked ALL the connections?
  3. Feb 14, 2016 at 1:19 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Yes, everything seemed to be in order..
  4. Feb 14, 2016 at 1:21 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Anything in particular i should be looking for?
  5. Feb 14, 2016 at 1:23 PM
    Joe D
    Joe D .
    Man, I'd check the wires by just shaking them...from the cap to the plugs. Otherwise, I'm blank....
  6. Feb 14, 2016 at 1:30 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Well they're one electrode plugs, so that's not the issue. Toyota doesn't like the dual or quadruple electrode plugs. I don't think your coils are making good contact with the new plugs. Make sure the boots are snugging down firmly on the plug ends. Or, you didn't tighten the plugs down tight enough (don't over-do it though!), or you cross threaded something. Did you get the plugs started off of the ratchet? Remember to never get any threads started on a wrench or ratchet. If those plugs come with a whacky gapping from the factory, it could be why it is having a hard time igniting, as your output to the plugs is tuned to have a certain gap to allow the ignition system to easily create the arc. If none of that is the culprit, try a different brand of plugs.
    Hope this helps. I did my plugs a few months ago and they run like a charm.
  7. Feb 14, 2016 at 1:31 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
  8. Feb 14, 2016 at 1:36 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Yours is 6cyl, his is 4cyl. Try letting the truck run for a while. Disconnecting the battery resets learned timing, the computer knows bad plugs, and you put in new ones, so give it a bit to figure that out.
    Watari06V6[QUOTED] likes this.
  9. Feb 14, 2016 at 1:39 PM
    Watari06V6
    Wounded Knee
    TRD-V6-SR5-06
    oopsy daisy
  10. Feb 14, 2016 at 1:50 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    I first hand started the plugs to ensure they would not cross thread- Im sure thats not the cause. I torqued each plug to 15 foot pounds- as suggested on this site. I believe the plugs come pre gaped at .044, where my truck manual specifies .043. Is such a small difference a possible cause?
    If it is the coils- anyway to isolate the bad one instead of replacing all 4?
  11. Feb 14, 2016 at 1:53 PM
    Silence9
    Alberta, Canada
    Ok, that's good. A .001" gap differential won't be the problem. I would then say it is the coils not making good contact with the plugs. Everything ran smooth when you put the old ones back in though? If so, the coils aren't damaged, they're probably just not seating properly.
    As for isolating them, do you have a multimeter?
  12. Feb 14, 2016 at 2:00 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Is the pcv hose connected? So it won't run at all? Or just run really rough?
  13. Feb 14, 2016 at 2:00 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Update- in frustration I decided to put the old plugs back in. Car still does NOT start. In addition- I smell gasoline coming from the exhaust. Is this indicative of faulty coils?
    No I do not have a multimeter...
  14. Feb 14, 2016 at 2:01 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    All hoses are connected. It wont start at all
  15. Feb 14, 2016 at 7:59 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Would an OBD Diagnostics Scanner help me isolate the problem?
  16. Feb 14, 2016 at 8:13 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    maybe, if there are any trouble codes. so it just cranks and cranks right? doesnt seem like it is trying to start?
    bogginator likes this.
  17. Feb 14, 2016 at 8:24 PM
    Jcollins
    Jcollins Well-Known Member
    Justin
    Browns summit north carolina
    2013 grey tacoma trd
    Light bar and pods with strobe back up camera any time mod 886 backup lights and a Detroit true track posi
    If you hold a decent magnet barely over the coil pack you should feel the magnet plus everytime it fires. If you don't then bad coils. Just a little trick I was tought and it works. I have checked a lot of different coils that way
  18. Feb 14, 2016 at 8:25 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    If the truck ran fine before you changed the plugs, I highly doubt the coils are bad. I'd say check your fuses... I've seen fuses blow on occasion when changing the battery.
    Howen and adanfon like this.
  19. Feb 14, 2016 at 8:31 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    ^agree, it has to be something that was done during either spark plugs or battery swap
  20. Feb 14, 2016 at 9:14 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    In terms of battery, I used a 24F battery from Costco, 700CCA. The CCA rating was higher than the recommended 585 CCA (according to the costco battery pamphlet finder). Would this higher CCA rating be a problem?
