Plug and Play Brake Light taps
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Puppypunter, Feb 11, 2021.
  1. Feb 11, 2021 at 12:24 PM
    Puppypunter
    Puppypunter [OP] Well-Known Member
    Johnny
    2019 Black SR
    Damn, sorry. Got kind of hectic there :) I believe I might have enough to squeeze out one more, I’ll check when I get home tonight. If not, I have a few more pieces on the way right now, so it won’t be but a couple days. Hopefully before Monday even so I don’t have to go back to the post office :annoyed: Either way, your first in line for the next one
  2. Feb 11, 2021 at 12:38 PM
    urshur
    urshur Well-Known Member
    2020 TRDOR ACLB
    Count me in if you have more parts on the way as well!
  3. Feb 11, 2021 at 12:47 PM
    Majora
    Majora Well-Known Member
    Andrew
    MD/WV
    2017 Quicksand TRD OR
    Chrome Delete Ultimate Phone Mount TacoVinyl Raptor 2.0 Grille Meso Puddle Lights Victory 4x4 Center Console Molle Rack
    Interested!
    crazyfingers likes this.
  4. Feb 11, 2021 at 1:06 PM
    kndrd
    kndrd Active Member
    Hailey, ID
    2021 TRD Off Road DCLB
    I'd be interested in getting one from the next batch.
  5. Feb 11, 2021 at 1:21 PM
    BokerTov
    BokerTov Well-Known Member
    The Rockies
    3rd Gen DCSB
    I'd like to purchase one, please.
  6. Feb 11, 2021 at 1:33 PM
    arrakis429
    arrakis429 Waiting for the Mets to repeat 1986
    Ben
    Springfield, OR
    2016 Quicksand TRD Sport ACLB 3.5L 6MT (OVTuned)
    Fuel Mavericks w/ Falken Wildpeak AT3W 285/70/17 (Soon to be SCS Ray 10 w/ Falken Wildpeark AT4W 255/80/17) Leer 100 Topper + Prinsu Cabrack Cali raised Bed stiffeners RCI Sliders RCI skids Bilstein 6112 Front 5/4 w/ Eibach 700lb Coils SPC LR UCA's Bilstein 5160 Rear OME Dakar HD Leafs Wheeler's UBolt Flip w/ Bumpstops N2 Designs MT remote starter OVTuned ARB Awning w/ Windbreak and Deluxe 'Room' SpartanXCustoms Amber Scoop light Pelfreybilt Aluminum Front Plate Bumper w/ CaliRaised 32” light bar and Baja Designs Amber Squadrons Wide Cornering Warn Zeon 10s Platinum Winch 2Lo Mod URD Stage 3 Clutch with Heavy flywheel Accumulator delete mod TacoGarage Dash Multimount Warfab Phantom Rear Bumper OVTune Dump tubes
    In, PM sent
  7. Feb 11, 2021 at 1:53 PM
    Pentangler
    Pentangler 24 Aces
    2022 DCSB OR 4x4
    Previous Toys: 2021 DCLB OR 2017 DCSB SR5 2006 RAV4
    Interested as well
  8. Feb 11, 2021 at 2:15 PM
    franco6888
    franco6888 Member
    Bobby
    El Paso, TX
    2018 Blue Tacoma TRD Off Road
    Exterior: Avid Off Road Sliders CBI full skids (steel) DRT Fab Hitch Skid Prinsu Roof Rack 40" S8 baja designs light bar CBI ditch light brackets S2 pro ditch lights S2 sport chase lights S2 sport work lights Leitner ACS Forged bed rack Rebel Off Road table mount Roam Vagabond XL RTT Roam Awning DMOS delta shovel Pro Eagle 1.5 ton off road jack Stromung tucker series exhaust Archive Garage Hammer hangers Archive Garage high clearance cross tube Duro bump stops with flip kit Kings 2.5 extended travel w remote resi SPC UCA BFG Ko2 285/75/16 Expedition Essentials bed side compressor mount ARB twin onboard air SPOD ARB safari snorkel Syclone pre filter Volant air intake Uptop under hood lights Interior: Meso map lights Meso V2 dome light Meso Chrome delete kit Midland GMRS radio Expedition Essentials V1 T3PAM Rago Molle with bridge Desert Does it seat riser New Holland door panel Molle Teton workshop shifter
    Is there a way to get this to work with the baja designs RTL?
  9. Feb 11, 2021 at 2:16 PM
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    Where does this tap in, at the bulb?
  10. Feb 11, 2021 at 2:22 PM
    Pyrotech
    Pyrotech Well-Known Member
    In..
    Bigdaddy4760 likes this.
  11. Feb 11, 2021 at 2:29 PM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    It’s two OEM plugs. A female and a male plugged that are wired together to make a connection from your tail light to your truck wiring. With two wires coming off of it to attach to your third brake light or whatever. In the description you can see the two plugs and the black and red wire coming out.
  12. Feb 11, 2021 at 2:41 PM
    dvill002
    dvill002 Member
    Dave
    2020 Cement Tacoma Off-Road
    I'm in!
  13. Feb 11, 2021 at 3:01 PM
    Puppypunter
    Johnny
    2019 Black SR
    This would be able to feed the brake portion. That being said, making a plug and play for all of the functions of the RTL (turn/brake/reverse I believe?) is possible. I am not sure of the amp draw of the RTL though, so worst case plug-n-play would also include a power wire ran from the battery and a chassis ground. I can reach out to BD (or maybe @memario1214 might have the info?). But as to this particular application, this plug could be part of it, but I’d say if you’re going to do a RTL, let’s do it as an all in one solution.
    It taps in at the connector for the bulb. So not a wedge connection or anything.
  14. Feb 11, 2021 at 3:04 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I love alternatives to cutting oem wire. If I needed one I would def get in line to buy one!
  15. Feb 11, 2021 at 3:56 PM
    #35
    LG Taco
    LG Taco Well-Known Member
    I'm in for the 2nd batch if still available
  16. Feb 11, 2021 at 4:27 PM
    #36
    crazyfingers
    Chuck
    Annapolis, MD.
    This is really a great idea.
  17. Feb 11, 2021 at 4:35 PM
    #37
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    In, for 2 please.
  18. Feb 11, 2021 at 5:39 PM
    #38
    elbaldwino
    elbaldwino Well-Known Member
    Brian
    Arizona
    2020 Off Road 4x4 Long Bed
    Stock
    Also interested if you do another run.
  19. Feb 11, 2021 at 5:57 PM
    #39
    vmart
    vmart Well-Known Member
    victor
    Southern California - Riverside Area
    2020 Tacoma Double Cab TRD Premium Package Offroad 4x4 Short Bed Advanced Technology Package
    OV Tune - Valley Runner Installed Authorized Installer For Valley Tuning PM me for details Black Out Trim Package Toyota Bed Mat TRD Skid Plate TRD Cold Air Intake TRD Shifter TRD Pro Tail Lights ADS Suspension Front Coilovers with Reservoirs ADS Suspension Rear with Reservoirs Dirt King Upper Control Arms Cali Raised Off Road Rock Sliders Gibson Exhaust Air Bags with Daystar Cradles U402 Stage 1 Deaver Leaf Spring Kit Snugtop Rebel Shell Snugtop Wireless Pro Lock Power Lock Tailgate Rago Fabrication Bed Stiffeners Spiker Engineering Hood Struts Tinted Windows Rain Guards DMM - Dash Multi Mount Sequencial Turn Signals Raptor Lights in stock 2020 grill Baja Designs Squadron Fog Lights FN Wheels - Konig Countersteer Type X Dark Metallic Blue 17" x 8" Great Design, Quality and Price Point. Thanks Dustin - Great guy to buy your next set of wheels from - www.fnwheels.com Nitto Ridge Grapplers 285/70/R17 - Americas Tire Cab Mount Chop - Beast Fab in San Bernardino Thanks Geraldo - You did a fantastic job https://www.instagram.com/tv/CGbT97SHBtg/ Parts yet to be installed: Body Armor Hiline Front Bumper Light Bar for above Rugged Ridge Trekker 12LB Winch for above Screen Protech Kit Future: Regear Rack Rear Bumper ??
    I'm in for next bath
  20. Feb 11, 2021 at 5:58 PM
    #40
    vmart
    victor
    Batch not bath !
