Plug and Play Brake Light taps
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Puppypunter, Feb 11, 2021.
  1. Sep 17, 2021 at 2:17 PM
    #541
    Puppypunter
    Puppypunter [OP] Well-Known Member
    Johnny
    2019 Black SR
    Those look great where you put them!
    mynameistory[QUOTED] likes this.
  2. Sep 17, 2021 at 9:58 PM
    #542
    Puppypunter
    Johnny
    2019 Black SR
    I haven't given up on this, but combining brake and turns gets tricky. I believe @caribe makaira had a way to do, and if I ask real nice and explain that I am a forgetful idiot, he might tell me again? :fingerscrossed:
  3. Sep 17, 2021 at 10:00 PM
    #543
    caribe makaira
    Caribbean, Puerto Rico
    Of course Johnny. What is the specifics on the FULL, is the 7 or the 4 circuit?
  4. Sep 17, 2021 at 10:04 PM
    #544
    Puppypunter
    Johnny
    2019 Black SR
    PM sent
    PM sent. For anyone reading, yes, I can make taps for the OEM tailgate lock as well if you have a locking topper.
    PM sent as well.
    PM sent :)
    I can. If Dave hasn't hooked you up already, let me know :)
    Just wanting to point out to @Diode Dynamics that there is plenty of room in these housing, and even an open slot in the deutsch connector to have 2 backlight colors.... Like Amber and red, red and white, or amber and white.... Oh, the things I could do! :drool:
  5. Sep 17, 2021 at 10:10 PM
    #545
    Puppypunter
    Johnny
    2019 Black SR
    I would think maybe the 4? I wouldn't know where to begin on adding a brake controller (that' not entirely true. I would begin something like "hey, Caribe.... )
  6. Sep 20, 2021 at 1:31 AM
    #546
    Bcarp100
    Bcarp100 Well-Known Member
    Brooks
    2017 White Tacoma SR5 4x4
    4Runner TRD wheels
    I’ll take one!
  7. Sep 20, 2021 at 4:12 AM
    #547
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I don’t really know either but my ‘02 Tundra has an aftermarket harness for a brake controller so that may help us a tiny bit. I was planning to clean it up when I install my RedArc.
  8. Sep 23, 2021 at 5:59 PM
    #548
    Martian__
    Martian__ Well-Known Member
    Southern California
    I got my harness in today. Install was super clean and easy. Great quality product! Thanks again!
  9. Sep 23, 2021 at 7:03 PM
    #549
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    This is a cool idea. It would mean that more hierarchy would be required in order to control them without some sort of external controller. For example, red (for braking) would be lowest priority, then amber (for turning/flashing) would slot above that, and the main chips would turn on for reverse function.
    There's a two-stage hierarchy already built into them, so the idea isn't that far out. The backlight LEDs turn off when the main emitters fire. This is a great feature because it makes plugging them into the trailer port for my use very easy.
    Perhaps @Diode Dynamics hasn't ventured here because they would basically be full-function taillights at this point, and I think that means DOT compliance would be required to advertise them as such. As it is, the backlights work best as simply accent lighting, especially with the different swappable optics that would make compliance difficult or impossible.
  10. Sep 23, 2021 at 7:28 PM
    #550
    Puppypunter
    Johnny
    2019 Black SR
    I would be happy with just another color option, same hierarchy on both and just let it be field configured. Or, for what I originally wanted to do, a separate ground for the backlight color would have been way cool to. My original plan was to have White Primary/White backlight, but have the backlight hooked up like the puddle pods. But since those are ground switched, I couldn't do it.
  11. Sep 24, 2021 at 7:13 AM
    #551
    Diode Dynamics
    Diode Dynamics Automotive Lighting Experts Vendor
    St. Louis, Missouri
    We have plans for the future, there is a reason we picked 4 pins instead of 3 :)
    Very perceptive. Yes, the compliance concerns have held us back from making a full "tail light pod" or something along those lines, but we do have some fun things planned that are not intended for tail light replacement.
  12. Sep 24, 2021 at 7:36 AM
    #552
    Puppypunter
    Johnny
    2019 Black SR
    Great, now I’m dying to know!
    “Off Road Use Only” :rofl:
    I would love to see something from Diode Dynamics as far as what you guys could do.
    Something to compete with the Baja Designs RTL series? Or multiple color option SSC’s would be really cool.
    mynameistory and daveeasa like this.
  13. Nov 12, 2021 at 4:15 AM
    #553
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    can I place an order?
  14. Nov 14, 2021 at 3:42 PM
    #554
    greymachine
    greymachine @taupetacoma
    SoCal
    19 Quicksand TRDOR 4x4 DCSB
    I would like to order one as well!
  15. Nov 21, 2021 at 3:58 PM
    #555
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    you can feed 3rd brake light wire, etc. through that little hole there on 2nd gen. dumped wired leads right by where my cap wiring is.
    Crooked Beat and thebaker like this.
  16. Nov 23, 2021 at 3:38 AM
    #556
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Came to ask this as well.
  17. Nov 23, 2021 at 5:52 AM
    #557
    daveeasa
    David
    PNW
    For what purpose?
    see also
  18. Nov 23, 2021 at 12:10 PM
    #558
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    DD is selling this reverse light kit with taillight taps for the 5th gen 4Runner. I wonder if it would be possible to source the connectors and swap pins to use the turn signals instead of the running lights (I have amber backlights and 4000K white lamps).
  19. Nov 23, 2021 at 1:29 PM
    #559
    Freeheelbillie
    Billie
    Saint Clair, MI
    auto high-intensity reverse lights
  20. Nov 23, 2021 at 1:40 PM
    #560
    daveeasa
    David
    PNW
    In an aftermarket bumper? Using which lights specifically? Do you know the connector? Do you know the current draw?
