Plug and Play Brake Light taps
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Puppypunter, Feb 11, 2021.
  1. Nov 23, 2021 at 1:41 PM
    #561
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I see only one tap so you'd only have turns on one side right? Or you'd have to buy two of these which might hurt cost-wise?
    bishtaco likes this.
  2. Nov 23, 2021 at 1:48 PM
    #562
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Yeah. Cost-prohibitive to buy one kit for a taillight connector, let alone 2. I'm not hurting for it, just running off my trailer plug as it is. Might keep it that way for simplicity's sake.
  3. Nov 23, 2021 at 1:52 PM
    #563
    daveeasa
    David
    PNW
    I think they are 090II connectors so one option you could consider is de-pin and re-pin and we send you some 090II 6 position connectors and color-matched jumpers with double-crimps for the taps you want?
    It'd look like this
    1. take a photo of the connector and color positions
    2. de-pin oem connector and place into replacement 6 position
    3. add jumpers to mating replacement 6 position in color-matched spots
    4. pin ends of jumpers to oem connector in the correct spots as before
    Now you have effectively a plug and play T harness, just you're stuck with it unless you want to repeat things in reverse order. At least it's cheap and no-cut.
    de-pinning those unsealed connectors is not very hard at all.
  4. Nov 23, 2021 at 4:00 PM
    #564
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Pretty sure I have those connectors, Dave. At least I can confirm it on my T4R. Look the same as the factory 120V outlet.
    daveeasa[QUOTED] likes this.
  5. Nov 23, 2021 at 4:03 PM
    #565
    daveeasa
    David
    PNW
    Get on it Kyle, Tory needs some love.
  6. Dec 2, 2021 at 4:22 PM
    #566
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Are these still available for a 3rd gen? Just looking for brake lights.
    one stupid question... this is likely pretty obvious, but after looking through this entire thread, i'm just confirming this tap goes behind the tail light? Assume it doesn't matter which one?
    EDIT: found a used on locally. thanks
  7. Dec 9, 2021 at 6:06 PM
    #567
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    Hey everyone.... I even hate asking the question as I should probably know.
    I hooked up a 3rd break light today using a @Puppypunter adapter (nice)... and tested as I went. I have it going to a waterproof disconnect so i can take it off if needed.
    All worked great.... drove to a meeting. came out 3 hours later... all good. Went to the gas station... left the radio on while pumping gas...
    And when i went to start the truck (2021 TRD Pro - new battery), it wouldn't start.
    I have one of those portable jump starters that worked great... so got home. BUT...
    My long-winded question is... if there is a short somewhere between the two wires... would that cause my battery to drain? I think yes... just asking.
  8. Dec 9, 2021 at 6:31 PM
    #568
    daveeasa
    David
    PNW
    To answer your question, there are exactly 3 wires on a 3rd gen brake tap. Parking light, brake and ground. Your brake light is only on if you press the pedal. While you aren't in the vehicle, unless you left a rock or cinder block on the brake pedal, the brake lights are off.
    Parking lights are another story. You did not mention if you left them on while pumping gas.
    However, the radio is likely to drain the battery just as much as the parking lights would.
    Sounds just like you got a lemon battery and/or used it hard. Since you're a '21 and a pro, hit up the dealer for a warranty replacement?
    oostroma, Willy-N and Puppypunter[OP] like this.
  9. Dec 9, 2021 at 6:36 PM
    #569
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    First off... thanks for the quick reply.
    I am only using Brake... so two wires. So i guess what you are saying is that there couldn't be a constant short because I'm not always pushing the brake..... makes sense even to me :)
    Just seemed not a coincidence that it happened within hours of wiring it. Otherwise... has been perfect.
    My lights were on (set on auto)... so there was a draw there for sure... but should have only been for less than 10 minutes.
  10. Dec 10, 2021 at 9:17 AM
    #570
    Puppypunter
    Puppypunter [OP] Well-Known Member
    Johnny
    2019 Black SR
    I think @daveeasa explained it pretty well. There is a very small chance that a crossed wire could complete a circuit like this and not blow the fuse first, but that is a very small chance. If it does it again, you can try unplugging the brake tap and see if the problem goes away. I suspect it won't, but the process of elimination is one of the best ways to troubleshoot.
    tomgru[QUOTED] and daveeasa like this.
  11. Jan 9, 2022 at 9:49 AM
    #571
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    @Puppypunter you still have some brake light tap for 3rd gen? I picked up a used Softopper and need to do this
  12. Jan 9, 2022 at 12:15 PM
    #572
    Puppypunter
    Johnny
    2019 Black SR
    I do still make these. I saw your PM, but figured I would let everyone else know I am still alive :) If I don't respond here, by all means, shoot me a message and I'll get back to you.
  13. Jan 15, 2022 at 12:35 PM
    #573
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    New taps came with blue and white/black wire. I’m sure it’s just process if elimination but which one would you connect to a universal third brake light if the wires for that comes with a black and red?
  14. Jan 15, 2022 at 12:37 PM
    #574
    daveeasa
    David
    PNW
    Blue is OEM brake positive, white with black is Toyota for ground aka negative.
    i.e. Blue to red, black to white w black stripe.
    gsubioguy likes this.
  15. Jan 15, 2022 at 12:38 PM
    #575
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    Appreciate it!!
  16. Jan 15, 2022 at 12:39 PM
    #576
    daveeasa
    David
    PNW
    Johnny should be using his fancy heat shrink label printer more :)
    :boink:
    907rx7 and Jeff Dartfrog like this.
  17. Jan 31, 2022 at 7:15 AM
    #577
    Puppypunter
    Johnny
    2019 Black SR
    Yeah, I need to label them more. I also need to stop by my own thread more :rofl:
    itzyoboipaul and gsubioguy like this.
  18. Jan 31, 2022 at 2:46 PM
    #578
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    I need one for my topper wiring, can I be added for the next batch?
  19. Feb 6, 2022 at 11:02 AM
    #579
    daveeasa
    David
    PNW
    I'm about to drill, what would be your choice on this? I foolishly forgot to bring the flange with me but going to make the pilot hole right now and I want to get it centered. I'll look up flange dimensions.
    ETA: Looks like 2.2 x 1.4 for the 6 pin flange. So call it 1.5" tall and center my hole on that vertical axis?
  20. Feb 6, 2022 at 11:09 AM
    #580
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Top would probably be better, I would take it apart but I am away for work. Fishing wire may be interesting based on the screenshot from a taillight installation video.
