Redside Electric Plug-and-Play Switch Illumination Harnesses
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by kmorgan3, Dec 3, 2020.
  1. Dec 3, 2020 at 9:25 AM
    kmorgan3
    kmorgan3 [OP] Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    What are these?
    For sale are breakout harnesses that allow you to tap factory switches in order to illuminate aftermarket switches without the need to splice into your factory wiring. This keeps your factory wiring nice and tidy and is fully reversible. This also allows you to control the dimming of your aftermarket switches with the factory dimmer. Each harness comes with a new green connector that replaces the connector you got with your CH4x4/Cali-Raised/AOB/MIC-Tuning Toyota-style switches. This makes things as "plug-and-play" as possible when it comes to lighting up your switches! Also for sale are daisy-chain expansion harnesses that allow you to illuminate as many switches as you'd like without needing to crimp them all together.
    Here is an example of my personal switches being illuminated using one of my harnesses and several daisy chains:
    Ordering
    There are multiple harnesses for sale. To determine which harness(es) you need, follow these steps:
    1. Figure out where you want to put your new switches. Note that each "base harness" comes with the ability to illuminate 1 switch without splicing. You have 3 options:
      1. Left of the steering wheel
      2. Overhead
      3. Below the head unit (A/T only for now)
    2. Determine how many switches you want to illuminate and purchase the appropriate number of daisy-chain expansion harnesses
      1. Each expansion harness adds the ability to illuminate 1 extra switch
      2. The expansion harnesses are infinitely expandable, so you may purchase as many as you need if you expand in the future
    3. Place your order over PM with me
    Products + Pricing
    Click the SPOILER button to get more details about each harness!
    Left of steering wheel $25 -- SOLD OUT
    This harness plugs into the cargo light switch connector to illuminate switches left of your steering wheel. All 3rd Gen Tacomas have this switch connector regardless if you have a cargo light! That includes us Access Cab weirdos. The connector is just tucked behind the plastic.
    The harness you're purchasing plugs right into the above circled area:
    Below the head unit (A/T only) $20
    This harness taps into the ECT PWR switch below your head unit. We utilize this connector to illuminate new switches below the head unit. To access the rear of the switch you will need to remove your head unit and pop it out. The whole process will only take a few minutes.
    Daisy chain expansion $15/ea
    As you have seen, each base harness comes with a single green connector to plug into your new switch. If you are going to be illuminating multiple switches (there are no "hard limits" as far as how many you can illuminate) you will want to purchase some daisy chain harnesses. These expansion harnesses are infinitely expandable, are reversible, and modular. You can add and subtract these as your setup changes. Once you get your hands on one you will see that they are pretty intuitive to use. I have made the leads extra long so you can illuminate switches that are 2-3 switch spots away from each other. Here are 5 daisy chains hooked up to an overhead harness; this will illuminate 6 switches.
    This is what each daisy chain looks like. You plug the green connector from your base harness into the male, and then each daisy chain has 2 females that go into your switches. To add another just plug the female (right side of the above image) into the male of the next daisy chain harness, so on and so forth until you have populated your switch panel.
    Shipping
    Shipping is a flat fee of $5 anywhere in the USA. International orders will be shipped at a quoted ship rate. I get fair rates so please inquire.
  2. Dec 3, 2020 at 9:52 AM
    elmontemike
    elmontemike Well-Known Member
    Is this hooked up so you able to control the lighted switch with the dimmer function?
  3. Dec 3, 2020 at 12:57 PM
    Ams556
    Ams556 New Member
    2017 Black Tacoma OR
    Meso Puddle Pods Meso Interior Lights DiamondBack HD
    I assume I can tap this on the output side to avoid cutting OEM harness for a relay for Bed Lights. If this is the case, I’ll take the last one!
  4. Dec 3, 2020 at 1:48 PM
    elmontemike
    I’ll take 1
  5. Dec 3, 2020 at 7:51 PM
    kmorgan3
    Kyle
    PNW
    More on the way and I will re-up this post when materials arrive.
    Ams556, kecknj and WHIT4K3R like this.
  6. Dec 4, 2020 at 6:05 PM
    kecknj
    kecknj Well-Known Member
    Nick
    '19 TRD Off-Road
    Definely interested in one of these if you make more.
    kmorgan3[OP] likes this.
  7. Dec 4, 2020 at 6:38 PM
    kmorgan3
    Kyle
    PNW
    We’re looking at the end of next week for components to show and I can take orders around then.
    Does anyone have a preference on the length of the pigtails? I’ve just been making them pretty short (6” or so) as I assume people’s wire runs aren’t going very far.
    riverrat958 and kecknj[QUOTED] like this.
  8. Dec 4, 2020 at 6:47 PM
    kecknj
    Nick
    '19 TRD Off-Road
    6" is perfect for me. I'll likely splice them directly into 4 or 5 JST connectors so I can add up to that number of illuminated switches. Did something similar with my overhead console....no fancy pass through connector like this though!
  9. Dec 4, 2020 at 11:41 PM
    jakeworthy
    jakeworthy Well-Known Member
    Jake
    HB
    2019 DCLB
    I too would be in for one if you indeed make more! Please and thank you.
    kmorgan3[QUOTED][OP] likes this.
  10. Dec 5, 2020 at 5:57 AM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I am in for one as well. I have already spliced my wires, but I am going to be wiring up some switches for a friend's truck and the clean look and reversibility is exactly what he is looking for.
    I think that should be more than enough wire. A couple piggyback connectors on the first switch makes it easy to daisy chain the rest of the near by switches. There are a couple different versions available.
    0190110035 Molex | Connectors, Interconnects | DigiKey
    Female to Double Male 1/4 in. Piggyback Push On Terminal Adapter - WiringProducts, Ltd.
    Amazon.com: DZS Elec 30pcs A.W.G 12-10 16-14 22-16 Crimp Connector Kit PVC Semi-Insulated Piggy Back Spade Quick Splice Male/Female Wire Terminals: Car Electronics
    kecknj and kmorgan3[QUOTED][OP] like this.
  11. Dec 5, 2020 at 10:40 AM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    I'm in...ima sucker for clean wiring and PnP!
  12. Dec 5, 2020 at 2:47 PM
    kecknj
    Nick
    '19 TRD Off-Road
    Thanks for that link! These will come in handy when I piggyback the aux/cig port.
  13. Dec 5, 2020 at 2:52 PM
    fatboyfirebass
    No problem. :cheers:
    kecknj[QUOTED] likes this.
  14. Dec 5, 2020 at 10:03 PM
    Jaime.portillo
    Jaime.portillo Well-Known Member
    Jaime
    Albuquerque, New Mexico
    2018 TRD OR
    Put me down! To confirm this could be used for rock lights to illuminate when the rear white cargo light turns on right?
  15. Dec 5, 2020 at 10:11 PM
    kmorgan3
    Kyle
    PNW
    It can be done but I’d be tapping Pin 5 instead of the two tapped here in the offered harness purely for illumination. I can make you one with the tap off Pin 5 but the rest is up to you (@Boswell requested the same thing). Here’s the diagram:
  16. Dec 6, 2020 at 7:02 AM
    Jaime.portillo
    Jaime
    2018 TRD OR
    That would be awesome. Count me in!
  17. Dec 6, 2020 at 8:02 AM
    Cappy
    Cappy Well-Known Member
    Georgia
    @kmorgan3 so I'm a dummy when it comes to wiring. My switches have 4 wires. Besides the +/- wires, I have a wire to illuminate part of the switch when activated and another to illuminate the other part of the switch when the lights are turned on. I'm assuming the two pigtails are for the two different illuminations that are in the switch. Is this correct or am I missing something? Will I still have to tap into something else for the switch to light up properly when the lights are on or activated? Thanks
  18. Dec 6, 2020 at 8:13 AM
    kmorgan3
    Kyle
    PNW
    Can you link your switch for me? I’ve never heard of em being wired like that. Typically the LED that comes on when you press it is tied to the outboard pin and doesn’t require a separate illumination circuit.
    The harness has a tap for illumination (+) and variable (-) (variable ground controls the dimmer).
  19. Dec 6, 2020 at 8:24 AM
    Cappy
    Georgia
    The switch I'm talking about is from ch4x4 and I have a caliraised one on order with ditch lights.
  20. Dec 6, 2020 at 8:55 AM
    kmorgan3
    Kyle
    PNW
    That’s what I thought. So the 4 wires coming out of the back of your switches are:
    • illumination
    • Ground
    • Out (to accessory)
    • In (from power source)
    If you were to use one of my harnesses you would connect the (+) from the harness to your illumination wire and the (-) from the harness to your ground wire. Your “out” on the switch would go to a relay or an accessory and your “in” would come from either a keyed or constant 12V source (most likely from the fuse box).
