Plugs
Discussion in '4 Cylinder' started by derevere, Dec 16, 2009.
  1. Dec 16, 2009 at 6:58 AM
    derevere
    derevere [OP] New Member
    Jamie
    Stephens,Ga.
    2003 Tacoma 4cyl
    Can anyone direct me to any information on changing plugs on a 2003 Tacoma 4cyl. manual trans. Thanks in advance. J
  2. Dec 16, 2009 at 7:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW.
    I dont think there is a write up on how to do it, but its a pretty straight forward venture. Use a little bit of anti sieze on the threads of the new plugs, and do not torque them past 15 ft-lbs. Also, use the OEM twin ground electrode plugs. Both sides gapped to .040"
  3. Dec 16, 2009 at 8:35 AM
    derevere
    Jamie
    Stephens,Ga.
    2003 Tacoma 4cyl
    Thanks , Just a bit confused as to why that bridge has to run right over the top of the plugs.
  4. Dec 16, 2009 at 8:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    What "bridge"?
  5. Dec 16, 2009 at 9:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you are talking about that bracket, it can be removed. I think there are (2) 12mm bolts holding it. you remove the top one, and loosen the bottom one, and you can move it out of the way.
  6. Dec 16, 2009 at 9:11 AM
    derevere
    Jamie
    Stephens,Ga.
    2003 Tacoma 4cyl
    right side of engine directly over the plugs is a something you might call a "Maintenence Inhibitor" I will take a picture and attach it to the thread . Thanks
  7. Dec 16, 2009 at 9:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    :rofl:
    Yeah, I have run across some of those in my life.
  8. Dec 16, 2009 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As have I. Some are known as "Red Locktight", "My Wife", "Going to ER", etc.....
  9. Dec 16, 2009 at 10:15 AM
    The Parts Whore
    The Parts Whore Slinging parts since '03
  10. Dec 16, 2009 at 10:18 AM
    98tacoma27
    Ben
    Not Beech Creek
  11. Dec 16, 2009 at 2:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. Your right. I didnt catch that it was the 4 banger. :eek:
  12. Dec 21, 2009 at 7:22 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I'm looking at getting new plugs, too. I know Chris is an advocate for stock plugs, and I've looked around the net at TTORA and TW and google and concluded that anything besides oem ignition stuff is basically a waste of money unless you're s/c'ed.
    So I should get the Denso Iridiums like these IK20's?
    If Autozone has 'em I'm gonna head down there to get my friends and family 20% discount!
  13. Dec 21, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On my 2000 2.7, I ran the OEM plugs ( Non iridium), and had good results. I didnt get the Iridium plugs until I SC'ed.
  14. Dec 21, 2009 at 7:44 PM
    sachou
    Sam
    Just looked at my Haynes. It lists either:
    Denso K16R-U
    NGK BKR5EYA
    So...go for the Denso's K16R-U's/the iridium IK20's, or the NGK's
    OR
    It doesn't really matter at all, you're giving me a headache with all these choices just get whatever.
    Input appreciated ^_^
