Po420 code
Discussion in '1st Gen. Tacomas' started by jprichard, May 9, 2009.
  1. jprichard
    jprichard [OP] New Member
    02 prerunner
    revtek lift flowmaster exhaust,k&n fipk, throttle bodie spacer
    Hey guys, got the 420 code (Catalysr efficiency below threshod bank 1.
    I replaced rear Cat, checked for leaks before rear o2 sensor, ran injector cleaner. Cleared the code but still comes back. Any ideas? Rear o2 sensor? Thanks.
  2. 00tacond
    00tacond Member
    Michigan
    00 pre-runner v6
    Donahoe front coils, deaver leafs
    I would say the front O2. If both O2's are switching from rich to lean it is because the rear O2 is trying to correct the front O2. Replace the front O2.
