POLL: For those who have DTRL and its melting your lights.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brian, Oct 13, 2011.
DTRL Melting your lights?
  1. I have DTRL, I have two wires going into the plug, no issues.
    31.4%
  2. I have DTRL, I have three wires going into the plug, no issues
    24.2%
  3. I have DTRL, I have two wires going into the plug and my lights melted the socket
    38.6%
  4. I have DTRL, I have three wires going into the plug and my lights melted the socket
    5.9%
  1. Jun 7, 2013 at 7:56 PM
    #81
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not an option for Canadian models. DRLs are legally required.
  2. Jun 9, 2013 at 6:52 AM
    #82
    Zarny
    Zarny Well-Known Member
    Prem
    Mississauga, Ontario
    13 MGM DCLB TRD Sport +leather
    So the only way to fix that problem is to turn the beams on?
  3. Aug 16, 2013 at 11:45 PM
    #83
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Commiefornia
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Just noticed this today. I have an extended warranty and fingers crossed it pays off. I'll check the wiring tomorrow.
  4. Aug 17, 2013 at 9:26 PM
    #84
    jabrackin
    jabrackin Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    Extended warranty will not cover cosmetic
  5. Aug 18, 2013 at 12:40 AM
    #85
    Rich91710
    Rich
    Los Angeles
    08 Base
    Even though there is a TSB on it?
  6. Aug 18, 2013 at 6:13 AM
    #86
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    On my 13 you can drive without them on, I never use them.
  7. Aug 18, 2013 at 9:53 AM
    #87
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2011 Double Cab V6 SR5 4x4
    2011, two wires, no issues
  8. Aug 19, 2013 at 12:07 AM
    #88
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    2009
    Two Wires
    Melted/cracked lenses (both sides)
    Socket intact.
  9. Aug 21, 2013 at 1:04 PM
    #89
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    I called Toyota's extended warranty.... they said they will not cover cosmetic appearances... they consider the melting spot cosmetic
  10. Aug 21, 2013 at 1:34 PM
    #90
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT
    Wow!!! That's fucking awesome of them!:rolleyes:
    It's a known issue and they won't cover it. That sucks
  11. Aug 21, 2013 at 1:46 PM
    #91
    firetaco18
    firetaco18 Well-Known Member
    have a '13 with 3 wires, no issues but I avoid using dtrl out of fear from these stories. 6k odo.
  12. Sep 18, 2013 at 9:02 PM
    #92
    joes06tacoma
    Joe
    Central Coast, CA
    Does anyone know what the functional difference is between the two wire and three wire sockets?
    I have two wire sockets, no DRL and am considering adding DRL using factory parts as discussed elsewhere on this forum. There is no mention of needing different parts for two wire or three wire setups when doing that mod.
    It would seem that the three wire setup could be running both filaments in the bulb, instead of just one. It would seem that would create more heat and cause more problems, yet most three wire folks report no problems with their lenses. Maybe the three wire setup is just newer?
  13. Jan 10, 2014 at 6:30 PM
    #93
    Rich91710
    Rich
    Los Angeles
    08 Base
    I've never seen verification that the 3-wire sockets are actually wired to anything.
    The DRL mod is the removal or installation of a plug and a jumper on the back of the fuse box, and the replacement of the flasher module.
    This mod works for any '05-'11, and the procedure is the same (but different part numbers) for '12+
    The mod does not in any way access a third wire.
  14. Jan 16, 2014 at 7:11 AM
    #94
    se7en
    se7en Go Vols!
    East TN
    21 Limited 4x4 Nightshade, Wind Chill Pearl
    I've been watching this thread for a little while, now. I have the same issue as most others here...bubbled, brown and cracked. Fox Toyota in E. TN = FAIL! in regards to any help on the issue.
    So, I've ordered some new DEPO lights to replace the old OEM's. Now, I'm looking at keeping it from happening again with new DEPO's.
    I found these DRL LED's (with load resistors already on the LED): http://www.carid.com/2009-toyota-tacoma-led-lights/lumen-led-lights-10257304.html
    I think these will solve any issues with the heat buildup of the incandescent bulbs...now I'm a little concerned with the load resistors on the LED's themselves. I have an email into them asking this very question. I'll post up their response as soon as I have one.
    As another note, these seem to be made so as not to create the fast-blink error the regular LED's have. Fingers crossed that this is a one-stop fix for the problem.
  15. Jan 16, 2014 at 7:23 AM
    #95
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    :popcorn:
  16. Jan 16, 2014 at 8:00 AM
    #96
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    These look pretty damn good. Which ones of the Lumens are you getting? The higher brightness ones?...
    Seems like maybe the regular amber ones will not be very bright?
    Looking forward to their response to your resistor questions.
    Thanks.
    PC
  17. Jan 16, 2014 at 8:15 AM
    #97
    medic2230
    Murph
    Bama! Roll Tide
    2011 SR5 with DRL 52,000 miles started around 42,000
    2 wires
    Melted lenses and cracked one on passenger side.
    Both filaments lit up.
    No damage to socket just lenses.
    Toyota refuses to do anything.
  18. Jan 16, 2014 at 9:04 AM
    #98
    se7en
    se7en Go Vols!
    East TN
    I'll get the PlaZma (420 lumen) ones.
    I also have a slight concern about fitment length. These look L O N G. I have not compared spcs to the OEM bulbs yet. Who knows, maybe they are the same length. I'll check on that later.
  19. Jan 16, 2014 at 12:08 PM
    #99
    Collins
    North Carolina
    ok, cool...thanks...the PlaZma's look more rugged too.
    There are some other LED type lamps out there that look like
    the same basic LED 'frame' as the Lumens use and those dimensions are pretty close
    to the standard 3157/4157 bulbs.
    Good luck with it...
  20. Jan 30, 2014 at 6:17 PM
    #100
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I have the two wire with the smoked head lights. Has anyone had the issue of melting with the smoked ones?
