POLL: For those who have DTRL and its melting your lights.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brian, Oct 13, 2011.
DTRL Melting your lights?
  1. I have DTRL, I have two wires going into the plug, no issues.
    31.4%
  2. I have DTRL, I have three wires going into the plug, no issues
    24.2%
  3. I have DTRL, I have two wires going into the plug and my lights melted the socket
    38.6%
  4. I have DTRL, I have three wires going into the plug and my lights melted the socket
    5.9%
  1. Feb 11, 2014 at 8:30 PM
    #121
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Good luck.
    There is no electronic flasher available to replace the 12-pin unit used on trucks with DRL.
    There used to be a unit, and VLEDs still lists it.... as backordered.
    It's been backordered for 2 years.
  2. Feb 12, 2014 at 3:04 AM
    #122
    se7en
    se7en Go Vols!
    East TN
    16 Limited 4x4
    Great!! I was affraid someone was going to say that.
    Oh well, thanks for the update.
  3. Feb 22, 2014 at 6:25 AM
    #123
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's set @ 0 with OME 883x coils up front . Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. 4 Runner Trail 17in. Wheels.
    Well last and final up date . I went ahead and did the green wire with red stripe mod and it worked like a champ. No more melting of lights.
  4. Feb 23, 2014 at 6:57 AM
    #124
    se7en
    se7en Go Vols!
    East TN
    16 Limited 4x4
    Wait...what mod is this green wire/red stripe?
    Personally, I replaced the headlights with new DEPO lights and switched from 4157 bulbs to 3057. I know its only a couple watts less, but I'm hoping it will be enough. Fingers crossed.
  5. Feb 23, 2014 at 11:30 AM
    #125
    tacoma guy
    Joe
    Phoenix Az.
    There is a write up and I 'm not sure where it is , I will try to find it but it talks about a wire coming off the DTRL module that powers the DTRL. By cutting this wire it disables only the DTRL and your turn signals still work properly. The module is on the side of the fuse panel under the dash by the steering column. Hope this helps. If I can find the link I will post it .
  6. Feb 23, 2014 at 3:47 PM
    #126
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.tacomaworld.com/forum/lighting/85326-dtrl-toggle-switch-mod-stealth-mode.html
    This guy put in a switch, I just cut the wire on my 2009, worked perfect with no side effects.
  7. Feb 23, 2014 at 4:18 PM
    #127
    tacoma guy
    Joe
    Phoenix Az.
  8. Feb 23, 2014 at 6:30 PM
    #128
    Rich91710
    Rich
    Los Angeles
    08 Base
    You were lucky you stopped there.
    I finally took mine out of the box and tried to install them today.
    I have the Depo housings, and I was able to get them to mount up (they were pushing on the lens).
    Hit the turn signals and it blew the 15a fuse.
    These not only do not fit the Tacoma housing, they are not the 3157CK wiring and do not work with the Tacoma.
    Will Jumpers work on a 2-wire socket?
  9. Feb 24, 2014 at 3:47 AM
    #129
    se7en
    se7en Go Vols!
    East TN
    16 Limited 4x4
    What bulbs have you been running? I don't want to melt my new housings...again.
  10. Feb 24, 2014 at 7:12 PM
    #130
    Rich91710
    Rich
    Los Angeles
    08 Base
    I have the adapter harness but have not yet installed it.
    I'm wanting to get into LED or a lower wattage lamp before doing the conversion.
  11. Feb 25, 2014 at 4:02 AM
    #131
    se7en
    se7en Go Vols!
    East TN
    16 Limited 4x4
    The lowest wattage bulb, that I'm aware of, is the 3057. Its only 1.66 watts less (26.88 vs. 28.54), but it was the least I could find. I hope it will be enough not to melt again.
  12. Feb 25, 2014 at 7:40 PM
    #132
    Rich91710
    Rich
    Los Angeles
    08 Base
    Or a 1 ohm, 40 watt power resistor in series with the lamp. That'll knock it down by 4 watts or so, and shouldn't be enough to cause hyperflash.
  13. Feb 26, 2014 at 1:59 AM
    #133
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I did the green wire snip, too. It was AFTER melting the lenses and sockets, replacing the whole headlight assemblies, installing LEDs and doing the blinker shave modification to get the correct flash rate......If I'd known about the green wire snip in the first place, I would've just done that and did away with my DTRLs first. What a great find!
  14. Feb 26, 2014 at 9:56 AM
    #134
    se7en
    se7en Go Vols!
    East TN
    16 Limited 4x4
    If I was going to add inline resistors, I would just go ahead and go LED's. Back in the day, that's how we had to wire motorcycle lights. I just didn't want to do that this time because I HATE the heat build up of those damn inline resistors.
  15. Feb 26, 2014 at 7:33 PM
    #135
    Rich91710
    Rich
    Los Angeles
    08 Base
    Inline resistors reduce current draw and wattage.
    LED retrofits require parallel resistors to bring the current back up to spec, and they run hot.
    With an inline resistor, the resistor will be carrying only a few watts.
    And I agree, I would not run LED with parallel resistors on a DRL application where they are always on.... at least not without a resistor that is rated at least double the required wattage, and solidly mounted to the radiator support for heat dissipation.
  16. Jun 18, 2014 at 8:29 AM
    #136
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    Dealer replaced my headlights this morning with the new design headlights. Both DTRL lens were melted and passenger side lens was cracked.
  17. Jun 18, 2014 at 11:20 AM
    #137
    Thunder Fish
    Thunder Fish Active Member
    100 Mile House BC Can
    2017 TRD OR DCSB
    The dealer replaced mine under a "silent" recall last week also
  18. Jun 18, 2014 at 7:29 PM
    #138
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    What is the new design?
    Those look like standard TRD Sport headlights.
    RJM
  19. Jun 18, 2014 at 7:31 PM
    #139
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    Something so they aren't supposed to melt again. Really, they look the same. I'm almost wondering if the dtrl bulbs are closer to the lens now. lol
    Those are the same lights that are on all Taco's no matter the package.
  20. Jun 18, 2014 at 9:08 PM
    #140
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    Looks nice. Got part numbers?
