Polyurethane Energy bushing vs moog bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Aug 19, 2011.
  1. Aug 19, 2011 at 8:02 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I'm debating on bushings for my truck. First it needs the lower control arm bushings for the front. I have had good luck with moog parts and know they are pretty tough. I'm having trouble getting moog bushings. They make them its just the problem of getting them. Also Moog bushings would be $100 vs Energy Bushings would be about $45. Whos had experience with energy bushings? go or no go
  2. Aug 19, 2011 at 8:12 PM
    2000GTacoma
    Snow Hill NC
  3. Aug 19, 2011 at 8:58 PM
    2000GTacoma
    Snow Hill NC
  4. Aug 19, 2011 at 9:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Energy Suspensions makes good stuff. I've used their bushings in the steering rack kit as well as the rear leaf springs. Not familiar with the moog stuff. Are they polyurethane like the energy suspensions stuff?
  5. Aug 19, 2011 at 9:16 PM
    2000GTacoma
    Snow Hill NC
    moog is not polyurethane just a heavy dute aftermarket. any squeaks from the energy sus. bushings are anything you didnt like about them heard it both ways
  6. Aug 19, 2011 at 10:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I would always choose poly over rubber. If you go that way be sure you lube them up good so you wont have squeaks.
  7. Aug 19, 2011 at 10:18 PM
    2000GTacoma
    Snow Hill NC
    im debating poly is cheaper but ive heard some bad stuff about it
  8. Aug 20, 2011 at 10:28 PM
    2000GTacoma
    Snow Hill NC
    anyone else with any experience?
  9. Aug 20, 2011 at 10:35 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    I have Energy poly bushings. They are awesome. Tightened up my steering. Oil and dirt can get around those all day and you don't have to worry about them.
  10. Aug 20, 2011 at 10:43 PM
    2000GTacoma
    Snow Hill NC
    good to hear really thinking about going that directions
  11. Aug 21, 2011 at 4:31 PM
    FowlTaco
    FowlTaco Member
    Denton, Texas
    01 PreRunner
    I installed ES bushings in my '01 3 years ago (front only).
    The uppers were cake, but the lowers are very difficult and don't think i would do it again. But they work and there are no noise issues I've ever noticed.
    -Royce
  12. Aug 21, 2011 at 4:35 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    What have you heard? All the 2nd gen. aftermarket UCAs use poly bushings.
  13. Aug 21, 2011 at 10:22 PM
    2000GTacoma
    Snow Hill NC
    ive heard they dnt last as long and squeak but i also have found out proper grease and the silicone synthetic? particular type must be used
  14. Aug 22, 2011 at 9:18 AM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    I've got the Engergy Suspension poly bushings. Go with the poly if you're replacing them anyway. They last longer, and if you get red, they look cool (lol). I got a kit both uppers and lowers for around $40. I got a kit for the rear leaf pack too. Currently sitting in my garage collecting dust as I try to find the time to put them in!
    I've only replaced the front uppers so far, but will likely be doing the lowers soon. Need to get my steering rack off first. Damn stuck bolt... doh.
  15. Aug 22, 2011 at 10:14 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Grease them up really good when installing. I didn't and now Im putting up with squeaking which is driving me nuts. I cant be fudged pulling it all apart again to grease them, but will have to at some point.
  16. Aug 22, 2011 at 12:18 PM
    2000GTacoma
    Snow Hill NC
    i need to replace my inner tie rod ends too. I just replaced outters. have inners so i think i will have enough clearance once i take the inner tierod end off.
  17. Aug 22, 2011 at 12:18 PM
    2000GTacoma
    Snow Hill NC
    you mean the entire bushing? outside inside grease everywhere?
  18. Aug 22, 2011 at 12:19 PM
    2000GTacoma
    Snow Hill NC
    order poly energy bushings for lower control arms today and i have my tie rod ends so i will probably tear it all down this weekend
  19. Aug 23, 2011 at 11:00 AM
    96Taco
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Outside definately. Inside, sure. Last thing you want is an annoying squeak. Even some WD40 or that silicon lube spray. Just don't try to stick it in dry.
  20. Aug 23, 2011 at 11:49 AM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    Don't the energy bushing squeaks a lot when suspension is flexing
