Polyurethane Energy bushing vs moog bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Aug 19, 2011.
  1. Aug 23, 2011 at 11:53 AM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    did you grease yours properly and with the proper grease? had an offroad shop known for its products tell me to use a particular grease that was not petroluem based silicone or synthetic
  2. Aug 23, 2011 at 10:18 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    go with the moog I have a set of energy poly sitting in the garage that tried to install but to put them on u must burn the rubber out of the old bushings or they dont fit the need the sleeve to fit right. plus poly doesnt flex as well offroad and squeaks uless u lube often. I have poly on the rear spring bushings and they are very noisy if i dont lube every 6 mos or so. I have a new set of poly bushing u can have for $40 if u wanna go that route. brand new in the box
  3. Aug 24, 2011 at 9:39 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There's no such thing as too much grease. Smear that crap everywhere. Just wipe off the excess after install... Use the grease that comes with the bushings, though...
  4. Aug 24, 2011 at 9:43 AM
    jbrandt
    Justin
    Not true (bolded). Poly/urethane flexes better than rubber. The poly bushings don't even "flex", they actually slide inside the sleeves, the rubber just twists and can limit travel based on how much the rubber can deform and twist.
    You have to burn the old ones out no matter what you replace them with.
  5. Aug 24, 2011 at 9:43 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    No squeeks so far with mine. My truck is COMPLETELY poly. It really makes the steering more responsive. If you can use more grease with them or add a zerk or greasable bolt with them and use green grease or lubrathane they really ride nice. The added vibration is hardly noticeable. Mine dissapeared when I swapped my hard body mounts for the softer (hard to believe, I know) poly.
    Worth the money. Use lots of grease. I burned mine out. You can also press them out.
  6. Aug 24, 2011 at 9:46 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    What about sway bar bushings? I have some ES sway bar frame mount bushings but never put them on the 05. Will put them on the 08 at some point....just because I have them.
  7. Aug 24, 2011 at 10:45 AM
    jbrandt
    Justin
    if you have them, might as well throw them on... Sway bar bushings aren't high on my list, but if I see them starting to crack, I'll probably throw poly ones on. ES bushings are pretty cheap, too. just about the same price as OEM rubber ones, IIRC.
  8. Aug 24, 2011 at 4:22 PM
    2000GTacoma
    Snow Hill NC
    right now as it sits i have a set of poly and a set of moog rubber heavy duty. the alignment cams dont fit as well in the poly ones
  9. Aug 24, 2011 at 6:33 PM
    2000GTacoma
    Snow Hill NC
    got my new alignment cams today and after comparing the ES to the moog and the fit with the alignment cam i think im going with moog. the ES doesnt support the cam on one end and the metal sleeve and washer that came with the kit do not fit the alignment cam either
  10. Aug 25, 2011 at 12:14 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    Haven't used Moog for this job. But I have used them a lot before and have found their products to be top quality. Im sure their bushings in this case will also be good stuff.
    Good luck on the install. And try not to drop the F bomb too often. Also remember to look away before bashing shit with a hammer. The amount of shit that has fallin in to my eyes working under the truck is crazy
  11. Aug 25, 2011 at 12:52 PM
    jbrandt
    Justin
    :notsure:
  12. Aug 25, 2011 at 2:14 PM
    2000GTacoma
    Snow Hill NC
    ive always had good luck with moog so i really think thats the route im going plus i dnt do offroading at off the most offroad the truck sees is the occasional path going hunting
  13. Aug 31, 2011 at 10:31 PM
    2000GTacoma
    Snow Hill NC
    installed moog bushings today decided im going to take the polys back just didnt like there design also installed inner tie rod ends along with new alignment cams also installed outter tie rod ends about 2 weeks ago all of said parts are moog except alignment cams had to get them from toyota took about 7 or 8 hours but its done time for alignment tomorrow.
  14. Oct 30, 2014 at 8:30 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Bump- how are you like the Moogs? I thin Poly would be easier to install, but I want the NVH reduction rubber gives.
  15. Mar 12, 2015 at 3:04 PM
    #35
    clamb
    clamb New Member
    Toronto ON
    2007 X-Runner
    Hey guys were are you buying your poly bushings from? I haven't had much success finding any online.
  16. Mar 12, 2015 at 3:55 PM
    #36
    bighouse01
    bighouse01 Well-Known Member
    NY
    04 DC TRD
    I just did Moog bushings in my lowers. They were $13 a pair from rock auto. I do not remember a part #. They were a workout to remove. I would torched em but I didn't want the smoke.
    I wound up drilling out the rubber and slicing the remaining shell with a sawzall and the driving the remaining bushing shell out with an air chisel.
    They new moogs slid right it with a threaded rod and sockets/washers like a screw press.
    Rubber for me. I've seen urethane come parts fall apart.
  17. Mar 12, 2015 at 4:03 PM
    #37
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    That's what she said!
  18. Mar 12, 2015 at 6:43 PM
    #38
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have been using Poly bushings in my front and rear suspension parts for a while now and they have been pretty solid and very minimal squeeking. Only thing I recommend is to avoid them for replacing body mounts because it makes the ride inside very harsh.
  19. Aug 11, 2015 at 8:59 PM
    #39
    nelsam360
    nelsam360 New Member
    San Diego
    1999 Tacoma Extended Cab SR5
    This thread has saved me so much time. Thank you to everyone that contributed.
  20. Aug 24, 2015 at 12:19 AM
    #40
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Does anybody know if Energy Suspension sells a kit just for the lower control arm? I have aftermarket control arms so I don't need them for the top.
