Polyurethane Radiator Support Mounts (Cab Also)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Feb 1, 2015.
  1. Jul 9, 2017 at 12:28 PM
    #1121
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Thankfully the alignment shop had em right.
    This clunking/rattling (i honestly dont even know how to describe it anymore) has been going on since i swapped my coilovers and UCA's and first alignment beginning of this year. I just cant figure whats going on with it. Hate hearing these sounds every time im out wheeling.
    Just ordered the bushings though, hopefully it solves my problem. If not Ill just chalk it up to preventative maintenance
    Kolunatic[QUOTED] likes this.
  2. Jul 25, 2017 at 12:21 PM
    #1122
    heffer
    Jeff
    Los Angeles
    So the clunking and rattling is gone on that side. But now im getting a clunking popping coming from the driver side cab mount (the one under my feet). Going to recheck everything tonight when i get off work
  3. Oct 2, 2017 at 3:24 PM
    #1123
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Might be your brake calipers. I’ve got what I’d also call an audible “clunk” or “pop” sound from the front left when hitting bumps or going in reverse, that I can FEEL, and I’ve checked the LCA torque and whatnot and no dice. Apparently you can buy an OEM brake retention type spring to lessen the issue if it is in fact the caliper noise.
    Discussed here, worth a shot:
    https://www.tacomaworld.com/threads/brake-click-fix.157684/page-3
  4. Oct 3, 2017 at 5:14 PM
    #1124
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  5. Oct 3, 2017 at 5:44 PM
    #1125
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
  6. Oct 3, 2017 at 5:46 PM
    #1126
    fatfurious2
    David
    Ashburn, VA
    ok. Thanks for the confirmation!
  7. Oct 4, 2017 at 12:52 AM
    #1127
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
  8. Oct 4, 2017 at 6:19 PM
    #1128
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
  9. Oct 4, 2017 at 6:20 PM
    #1129
    fatfurious2
    David
    Ashburn, VA
    Yes. @EatSleepTacos ordered some too. Shouldn’t be too difficult of a task
  10. Oct 4, 2017 at 6:21 PM
    #1130
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Mod day and knock them all out at once?
    fatfurious2[QUOTED] likes this.
  11. Oct 4, 2017 at 6:30 PM
    #1131
    fatfurious2
    David
    Ashburn, VA
    HCJ likes this.
  12. Oct 4, 2017 at 6:44 PM
    #1132
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I'm debating if I want to do the full set now or just the radiator core support
  13. Oct 4, 2017 at 7:17 PM
    #1133
    fatfurious2
    David
    Ashburn, VA
    If you do the cab mounts, your ride will be rougher. Or so i hear
  14. Oct 4, 2017 at 7:45 PM
    #1134
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Already rides like ass so no biggie there. I ordered just the radiator mounts for now though :)
    Hoping I can wait on cab mounts a while, that job sounds like a pain
  15. Oct 4, 2017 at 7:49 PM
    #1135
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    rollin904[QUOTED] likes this.
  16. Oct 4, 2017 at 7:55 PM
    #1136
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
  17. Oct 5, 2017 at 3:36 AM
    #1137
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm always down for a mod day! We need to install Johns leafs as well.
    HCJ and rollin904[QUOTED] like this.
  18. Oct 5, 2017 at 12:06 PM
    #1138
    hoarder23
    Shay
    NJ
    Scratches
    I had no issues with ride quality.
    The lesson learned I had was in a double cab pull both rear seats at the beginning and don't reinstall untill you've done both aft cab mounts. I did driver's side, put it back together then realized that to pull passenger side the driver's needs to come out.
    Easy job, did it alone with the rework in about 2 hours.
  19. Oct 5, 2017 at 10:44 PM
    #1139
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I never pulled any seats. In the rear, just the storage bins.
  20. Oct 8, 2017 at 2:48 PM
    #1140
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Accomplished this today. Pretty straight forward, but thanks for posting the info.
