Poor Gas mileage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wallacedu, Feb 28, 2017.
  1. Aug 14, 2020 at 8:49 AM
    #261
    Erodgers
    Erodgers Member
    Ev
    First Tacoma- '18 TRD 4x4 OR
    New shoes, Grille, Tint, Others on the way
    Glad someone caught me trolling, that was after just filling up and coasting downhill. Its the highest i'd ever seen so i had to snap a pic. I usually get about 16...
  2. Aug 14, 2020 at 8:52 AM
    #262
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    It was funny but only slightly less credible than folks claiming to get 25mpg :rolleyes:
  3. Aug 14, 2020 at 8:53 AM
    #263
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    its a truck..... if you wanted MPGS, should have bought a Prius, or a TESLA.... or gone with a diesel jeep/truck. they still get over 22MPG in a fullsized 2500/350 TD....
    Jukeboxx13 and TNToyo79 like this.
  4. Aug 14, 2020 at 9:00 AM
    #264
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Hey, just because you can't, doesn't mean it isn't possible lol. Although, as I said, it was one flat trip. But usually I'll get 23 or 24 on that same stretch of road. I think I also had the windows and sunroof cracked and no AC running too so there's that.
  5. Aug 14, 2020 at 9:02 AM
    #265
    RedWings44
    Michigan
    Doesn't mean you can't make your money go farther (literally). Not to mention usually poor MPGs (in normal conditions) can be a sign of something going wrong with the vehicle. Especially when you're getting well below the rating under normal circumstances.
  6. Aug 14, 2020 at 9:14 AM
    #266
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
    And now your gas mileage is????
  7. Aug 14, 2020 at 9:19 AM
    #267
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    most of us are running trucks with larger tires, lifts, and heavy armour on... MPG will suck no matter what.. I get roughly 19.5 depending entirely on speed below 70mph.. sure... above 70MPH// dont count on it... more like 16MPG....
  8. Aug 14, 2020 at 9:47 AM
    #268
    RedWings44
    Michigan
    Adding all that stuff isn't exactly something I would classify as "normal circumstances."
  9. Aug 14, 2020 at 9:57 AM
    #269
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  10. Aug 14, 2020 at 10:01 AM
    #270
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    I said "MOST OF US" and i have hit 22mpg, but that was driving very slow, on speed control with speeds under 65mph... that was with all my gear...
    tarbal255 likes this.
  11. Aug 14, 2020 at 10:39 AM
    #271
    RedWings44
    Michigan
    Yes, but I would argue that "most of us" isn't actually most people. Either way, I have hit 21.7 or so with my RTT at 70. My RTT has generally brought me down about 2 MPG and my bike rack a little more than that. I'll get about 15-16 running 80 with my full setup.
  12. Aug 14, 2020 at 11:05 AM
    #272
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    My Taco gets 35MPG loaded with 35s and a trailer hooked to it (idling in gear up on jackstands)
    My girlfriend also weighs 150lbs (on Mars)
  13. Aug 14, 2020 at 11:26 AM
    #273
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    shit, i get 70 mpg going down a steepgrade! but it goes back down on the next hill. reset mpg calculator, then engine brake down a long grade and you will see the same thing.
    Steve Urquell likes this.
  14. Aug 15, 2020 at 7:21 AM
    #274
    TNToyo79
    TNToyo79 Just a Dude...
    Josh
    Georgia
    2019 SR5 2WD : 2016' 4 Runner
    5.29 Nitro Gear, JBA Offroad UCAs, Rough Country M1 Coilovers, Rear: Bilstein 5100's with 2.75"in. Blocks, 20" Fuel Assault on Atturo: Trail Blade XT's, Stereo that will make you go deaf.
    18.9 on Avg. ...which is cool but I bought it knowing the MPG.
    The absolute biggest improvement (for me because I'm running 33's) is that the truck no longer "hunt's" for gears......highway, hills or other wise. It's now running at the correct RPM (2100) and correct gear for it to stick at and speed and even accelerate if needed, going uphill as well. No more of the shifting all the time.
    Money well spent. It's actually like having a new truck IMO.
    Prior to this install, I was driving around town and in any application less than 60 MPH with the truck manually shifted down into 4th gear.
    At 70 MPH on the highway the truck was constantly bouncing in and out of 5th and 6th gear......add cruise control and forget it, it was just all over the place.
  15. Aug 15, 2020 at 7:25 AM
    #275
    TNToyo79
    Josh
    Georgia
    Instead of just pressing cruise and letting off.....press it and hold it until the green cruise light in your gauge cluster turns into the green image of the speedometer...radar is now disabled.
    SouthernFried[QUOTED] likes this.
  16. Aug 15, 2020 at 8:02 AM
    #276
    Pinballwizard_king
    Pinballwizard_king Well-Known Member
    2020 blue Tacoma TRD off road
    Personally I say if your concerned about gas mileage then dont buy a truck buy a smart car instead. I dont look at gas mileage. I fill it up when it needs it and dont even look at how much it cost per gallon
  17. Aug 15, 2020 at 9:01 AM
    #277
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    You can always get a prius like the wife wanted. I never hear a peep now thats she's got that car after dumping her trailblazer.
  18. Aug 15, 2020 at 9:03 AM
    #278
    TheTacoMarine
    TheTacoMarine Well-Known Member
    2016 Tacoma TRD Sport
    B57E35CA-9171-4255-A608-F45D1CA4496C.jpg This was busy after installing a lift and packing up the truck to go on a light camping trip. Stayed around 60mph the whole way there
    GHOST TACO likes this.
  19. Aug 15, 2020 at 10:04 AM
    #279
    RedWings44
    Michigan
    As I pointed out before, poor fuel economy (under normal circumstances) can be an indication of something going wrong. Plus, if you're commuting, you would like your money to go farther and not everyone can afford 2 vehicles when they need a pickup truck outside of going to and from work.
  20. Aug 16, 2020 at 4:05 AM
    #280
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    Again I it is a truck... mpgs fluctuate with weather, temperature & load... only indication of an issue would be getting 14mpg or less..unless you are climbing mountains daily..
