POOR MAN LIFT KIT GOING WRONT "PLEASE HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco de Carnista, Sep 29, 2011.
  1. Sep 29, 2011 at 8:03 AM
    Taco de Carnista
    Taco de Carnista [OP] Well-Known Member
    michigan
    2005 TRD OFF ROAD
    Hi everybody I finally decide to lift my truck. here is the list of the parts:
    1- toytec 3" kit with the 5100 and the sprint for the front with the 1/2" top plate , 5100 and the add a leaf for the back,differential drop kit and cooper s/t 255 85 16. the problems that I have now is my alignment, the shop said the my camber and caster are max out so the truck is not within the range here is the aligment number
    camber (L) 1.7 (R) 0.9
    caster (L) 1.4 (R) 0.2
    toe (L) 0.03 (R) 0.00
    cross camber 0.8
    cross caster 1.2
    total toe 0.03
    My question is can i fix this with new UCA or
    I remove the top plate also the front 5100 are set to the lower setting the shop said that I can drive like this but Im not sure if if ok PLEASE HELP ME I YOU CAN
    THANK ANY WAY
    (sorry english is not my first language)
  2. Sep 29, 2011 at 8:09 AM
    wannatoy570
    wannatoy570 Well-Known Member
    Dave
    Lock Haven, PA
    05 Toyota Tacoma SR5
    I just put the same lift except i put the 885 spring in front on my truck a few weeks ago, I had no problem getting mine aligned so maybe go to a different shop and talk to them about it?
  3. Sep 29, 2011 at 8:11 AM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    New uca's and or remove the top plate spacer. Either will work. To the best of my knowledge you can run the truck out as is, out if alignment but you will kill your tires prematurely.
  4. Sep 29, 2011 at 8:13 AM
    Taco de Carnista
    michigan
    2005 TRD OFF ROAD
    Did you think new uca will give me more camber and caster ?
  5. Sep 29, 2011 at 8:14 AM
    Taco de Carnista
    michigan
    2005 TRD OFF ROAD
    hey did you have the top plate space?
  6. Sep 29, 2011 at 8:16 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    anytime you lift above 2.5" you will need new UCAs.
  7. Sep 29, 2011 at 8:17 AM
    Taco de Carnista
    michigan
    2005 TRD OFF ROAD
    according to the shop the toe is what kill your tire but I don't know if they just blowing smoke out my ass
  8. Sep 29, 2011 at 8:18 AM
    wannatoy570
    Dave
    Lock Haven, PA
    Yes i do
  9. Sep 29, 2011 at 8:20 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Look into light racing uca's. that should take care of your alignment problems.
  10. Sep 29, 2011 at 8:20 AM
    wannatoy570
    Dave
    Lock Haven, PA
    Yeah, i have the 5100s and 885 ome springs and it gave me 3in and m alignment was right on.
  11. Sep 29, 2011 at 8:21 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Get UCA's OP
  12. Sep 29, 2011 at 8:24 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yes, new UCA will make it possible to align.
    But your current numbers look terrible even for what you have.
    UCA puts more adjustment possibilities in the hands of the capable technician. But the beginner just gets more confused.
    bottom line: with or without UCAs you need a smarter alignment shop.
  13. Sep 29, 2011 at 8:26 AM
    Taco de Carnista
    michigan
    2005 TRD OFF ROAD
    THAT WHY I LIKE TACOMA WORLD WE GOT MORE INFORMATION THAN N.A.S.A [/SIZE]
  14. Sep 29, 2011 at 8:28 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i would take it to a different alligment shop, see what they say. if they cant get it in allignment then get light racing ucas
  15. Sep 29, 2011 at 8:28 AM
    Taco de Carnista
    michigan
    2005 TRD OFF ROAD
    anybody know a good shop in Michigan detroit area?
  16. Sep 29, 2011 at 8:38 AM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    Hell until about a week ago I was running 8 inches with stock control arms lol I don't recommend that at all I now have light racing control arm. And yesterday I found that I ripped my inner cv boot so you gotta pay 2 play
  17. Sep 29, 2011 at 9:00 AM
    Taco de Carnista
    michigan
    2005 TRD OFF ROAD
    OK Now the million dollar question which UCA manufacture would you recommended ?
  18. Sep 29, 2011 at 10:47 AM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    As stated previously in this thread....light race upper arms. There not to pricey and you don't really have to maintain them. I got them and all is good
  19. Sep 29, 2011 at 11:16 AM
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
    I have 3 inch revtek spacer lift, and no problems with alignment.
  20. Sep 29, 2011 at 11:25 AM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    hey just curious, how those 255 tires? any reason for getting them so narrow? Look good btw
