POOR TURNING RADIUS AFTER 6" FABTECH INSTALL??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by POWHANA, May 25, 2012.
  1. May 25, 2012 at 7:42 AM
    POWHANA
    POWHANA [OP] Well-Known Member
    Lake Tahoe
    2012 Tacoma TRD Off-Road
    So I got my truck back a couple of days ago from being lifted...I immediately noticed a noise in my front right CV joint, looked at it and it was loose and the truck didn't seem to make quit a sharp turn as before. I took the truck back and they are fixing the CV joint today but...should the truck normally lose it's turning radius after a lift is installed?? :eek:
  2. May 25, 2012 at 7:45 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Subd interested on the answer
  3. May 25, 2012 at 7:59 AM
    POWHANA
    Lake Tahoe
    Whoa...bummer. You'd think it would be the same or better huh for wheelin sake. Oh well, she still looks freakin sick! I'll get some before and after pics up when I figure out how to post em, I'm computer literate but cant seem to figure out how to upload my build. Thanks Whippersnapper for your continued awesome help!
  4. May 25, 2012 at 11:49 AM
    POWHANA
    Lake Tahoe
    Another question...does anyone know if the CV joint gets taken apart when installing the Fabtech lift? The dudes who put on the lift are telling me that it is probably a bad CV joint...however it was fine when I gave it to them to install the lift...
  5. May 25, 2012 at 11:53 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    i actually had a better turning radius with my 6" lift, over my current 3" set up. but my personal experience doesn't compare to whipper's knowledge :rolleyes:
    :p
  6. May 25, 2012 at 9:59 PM
    PLC721
    Patrick
    Chandler, Az
    yes there are steering stops, which were not removed when i went down to 3"
    and no...no true measurements were taken :(
  7. May 25, 2012 at 10:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    no, they're popped out of the diff though, but left assembled.
  8. May 25, 2012 at 10:20 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    http://www.fabtechmotorsports.com/pdfs/instructions/Fabtech-install_FT26026i.pdf
    The Fabtech lift includes new spindles. Looking at the spindle in the install instructions, the steering stops are cast into the spindle. It is very possible the stops are longer, causing reduced steering angle.
    CV joint damage is also possible when installing the lift, because the driveshaft has to be hammered out of the OEM spindle.
  9. May 25, 2012 at 11:01 PM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    Bilstein 5100 (2.5") aFe short ram intake KC light bar PIAA halogen Lights Hella Lights on top Yakima Load Warrior
    subbed. interested in outcome of this
  10. May 25, 2012 at 11:02 PM
    PLC721
    Patrick
    Chandler, Az
    i was interested when i didnt know what i was doing and 4wheel parts said it was better off road than a cam burg front deaver/ fox rear :rolleyes:
  11. May 25, 2012 at 11:08 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Just looking at the spindles the stops look longer but in my opinion not enough to notice a difference. Then again...?
    Take a look when you get it back, do your wheels go from stop to stop, if so then that's the problem. If not then you've got other issues.
    Loose CV? A slight amount of play at the diff is normal, what do you consider loose? What kind of noise?
  12. May 27, 2012 at 9:11 AM
    POWHANA
    Lake Tahoe
    So they ended up putting a new axle in...sound gone now. Thanks all. Pretty cool to have this website with so much knowledge.
  13. May 28, 2012 at 3:02 PM
    jgray
    jgray Well-Known Member
    josh
    boyds,md
    05 Ext.cab "murder was the case"
    Aero turbine sidepipe 3" pipe Murdered out 3"revtek leveling kit 33's
    Just got my fabtech 6 inch done with 35-12.50's and they rub on the cab mount a little. How many of you guys have done the cab chop and is there a write up?
  14. May 28, 2012 at 3:07 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Chop chop time.
