Pop and Lock on an 2009 with the back-up camera?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fish Tacos, Aug 22, 2008.
  1. Aug 22, 2008 at 4:01 PM
    Fish Tacos
    Fish Tacos [OP] Active Member
    Conn
    2009 Double Cab TRD Off-Road
    Does any know what the options are to locking your bed if you don't want to remove the backup camera on the 09s? It looks like adding a pop and lock will remove the housing around the latch along with the camera.
    My issue is I am considering getting a BAK G2 bakflip cover which requires being able to lock your tailgate in order to secure everything.
    If I can't lock it without removing the camera I may opt for a hinge-type cover which I can lock from the top and "locks" the tailgate in when down.
  2. Aug 22, 2008 at 4:45 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I am looking for the same thing but I had an undercover installed today and it secures the tailgate somewhat. But I am sure they will come out with a lock for the tailgate eventually.
  3. Aug 22, 2008 at 4:54 PM
    Fish Tacos
    Conn
    TDM - how secure does the undercover lock in the tailgate? Do you feel like your stuff is safe or could you pry it open with enough force if someone wanted to??
  4. Aug 22, 2008 at 5:02 PM
    tdm156
    San Antonio, TX
    Well I just had it installed today but I pulled the latch on the tailgate and it wouldnt move so someone would have to pry with a good bar to get it open. Not sure of the strength of the tailgate but the cover is pretty tough. I figure no matter what you have on there if someone wants in bad enough they will find a way but I am happy so far with it.
  5. Aug 22, 2008 at 5:07 PM
    Fish Tacos
    Conn
    Thanks for the info .... I am 50 - 50 right now between the undercover and the bakflip - both seem like good covers.
  6. Aug 22, 2008 at 5:08 PM
    tdm156
    San Antonio, TX
    I saw the back flip myself but with the undercover it seemed more secure and Very Easy to remove and hang on your garage wall. But with the back flip you can flip it back without planning to haul whatever. Good luck with your choice. After I travel with mine we will see if I made the right choice.
  7. Aug 22, 2008 at 5:54 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You might try an electric lock:
    http://www.dynolock.com/tota20w.html
    I haven't seen the backup camera on the '09s yet. Do you think you could drill the pop-n-lock so the lens could see through it?
  8. Aug 30, 2008 at 8:32 PM
    2009Taco
    2009Taco Well-Known Member
    Northern Virginia
    2011 Highlander
  9. Aug 31, 2008 at 10:36 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
  10. Aug 31, 2008 at 10:48 AM
    2009Taco
    Northern Virginia
    2011 Highlander
    ya, no picture. i am almost definitely going to get it though and within the next few days if i decide too, so i will let you know what it's like. i can always return it if i don't like it.
  11. Aug 31, 2008 at 11:21 AM
    canadiankid
    canadiankid Well-Known Member
    Langley BC Canada
    09 DC LB TRD SPORT
  12. Aug 31, 2008 at 11:47 AM
    2009Taco
    Northern Virginia
    2011 Highlander
    Ya, I did notice that, it says it was for an 05, so hopefully they have worked out the issues for the 09, guess i'll find out in a few days.
  13. Sep 10, 2008 at 12:09 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I e-mailed pop & lock about 2009 compatibility...
  14. Sep 10, 2008 at 5:02 PM
    canadiankid
    Langley BC Canada
    09 DC LB TRD SPORT
    thats good new. Thanks for the info.
  15. Nov 1, 2008 at 6:18 PM
    2009Taco
    Northern Virginia
    2011 Highlander
    i finally ended up ordering the electronic lock. i hope to get it installed in the next few days. i will let you know how it turns out.
  16. Nov 1, 2008 at 6:20 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i think pop and lock is making a lock for 09 tailgate. I just have to be patient
  17. Nov 1, 2008 at 6:22 PM
    2009Taco
    Northern Virginia
    2011 Highlander
    is pop and lock that much better than the dynolock?
  18. Mar 19, 2009 at 9:35 AM
    itjack
    itjack Member
    Berea OH
    09 PreRunner
    I just purchased the Bak Flip and the Pop & Lock 5200. It looks like the lock is to require drilling through the camera to be able to mount it. Has anybody done this?
    Thanks,
  19. Mar 19, 2009 at 10:16 AM
    2009Taco
    Northern Virginia
    2011 Highlander
    I don't think the 5200 will work. They are coming out with a new one, the PL5300. It should be out next month. There is also a group buy currently going on as well.
  20. Mar 19, 2009 at 10:34 AM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I'm interested in the group buy...
    Any info?
