Pop and Lock power tailgate lock questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arthur Vandelay, Jan 5, 2016.
  1. Jan 5, 2016 at 7:21 AM
    Arthur Vandelay
    Arthur Vandelay [OP] Member
    2015 TRD Off Road
    I just ordered the pop and lock power tailgate lock for my '15 DC. Also, I've see the tread for the support bracket install (considering ordering). I like the idea of running the wire into the cab through one of the body plugs under the fwd passenger seat vs. into the engine compartment and through the firewall. Just crawled under the rig and found these body plugs...
    What's the best hole to use? How did you seal it? Any cons to running the wire this way?
    Also, I wanted to use the conduit for the backup camera to get from the tailgate into the undercarriage.
    How do you get into this conduit?
    Thanks for your help!
    -Art
  2. Jan 5, 2016 at 10:10 AM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    Is the '15 different than an '08? For my year I remember 2 locations you could tap into for the tailgate lock.
    One method was to run it into the engine compartment then through the firewall. This involved running more wire and taking off more interior panels than the second option, which was to come up through a plug under the drivers seat and splice into a wire on the B pillar. I went with this second option and it was easy.
    The plug is wrapped in tape and once you undo it you'll see what is in the first pic below. I taped the wire to a phillips head screwdriver, lubed it with liquid soap and pushed it through the grommet. The interior rocker panel comes out easy and provides the short path to the B pillar wiring. Of course, the '15 may not have the same wiring and plug location so ignore this if that is the case.
    When I ran my wire I bought split loom cover and ran it along the factory harness (next to the frame), zip tying it every 8 inches or so. This is much easier than trying to get new wiring into existing factory wiring cover, IMHO.
  3. Jan 5, 2016 at 10:42 AM
    Little Blue Truck
    Little Blue Truck Active Member
    Ottawa-ish
    2015 TRD Sport DCLB
    I used the larger of the unused grommets under the passenger seat. Drilled a small hole in grommet and pushed the wire through. Didn't bother to seal it because it was a tight fit.
    I chose to run the pop-n-lock wire inside the short (~10") tailgate camera harness (between the tailgate and the bed) rather than making a new hole in the gate or using a tailgate drain hole. I detached the holders at each end of the loom that fasten the loom to the gate and body, opened up the loom, ran lock wires alongside the camera wires from under the body where the connection is, through to the inside of the gate. Then I taped everything up and reinstalled the loom. The end result looks good, but to be honest I'm not sure I'd do it that way again, because it was a pain to pop the harness out of the plastic do-dads at each end of the loom, and I had to remove and replace a lot of the tape around the wiring for the camera because there wasn't much room inside the loom for another pair or wires - you can't just place the pop-n-lock wiring in the existing loom easily. It also took several tries to get the pop-n-lock wire in the correct position within the loom between the gate and bed, so that it was long enough to be zip-tied to the frame underneath without excessive wire hanging down. Definitely the most fussy part of the install if you choose to do it that way.
    Agree with 916carl, between the gate and the passenger seat grommet, just get some split loom and zip tie to inside of frame.
    I was too cheap to purchase the support bracket, fabricated my own using a wood block zip-tied to the cross-member in the gate. Trial and error got me a block with dimensions that prevent the mechanism from moving if forced. Seems to work ok.
    Good luck with your install.
  4. Jan 6, 2016 at 9:12 AM
    Arthur Vandelay
    2015 TRD Off Road
    Thanks for the info. Looking forward to figuring it out.
  5. Jan 9, 2016 at 10:21 AM
    Arthur Vandelay
    2015 TRD Off Road
    So it turns out there is just enough room to squeeze the wire along the side of the clips in the frame and tailgate for the backup camera. image.jpg
    I taped it up with the conduit for the backup cam, and it looks fairly clean. image.jpg
    Ran the wire along the conduit for the brake lights, I'm concerned about the heat, hopefully it won't be an issue.
    Entered the can through the smaller body plug.
    Works great. That's for the help!
  6. Jan 27, 2016 at 5:11 PM
    kbob
    kbob It could be worse... you could be on fire.
    Kevin
    Punta Gorda, FL
    2015 White Tacoma
    What wires did you end up using to send the signal to the power lock? I have been searching and cannot find anything specific. I have a '15 and would like to code it so the double click opens the lock rather than the single click of the remote. Thanks!
  7. Jan 27, 2016 at 5:20 PM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    You tube vids are great. I tapped into the power door locks for driver side rear door. Can't remember the color I think green and purple. I'll look for the video what model popalock did you get?
  8. Jan 28, 2016 at 12:50 PM
    kbob
    Kevin
    Punta Gorda, FL
    2015 White Tacoma
  9. Feb 1, 2016 at 2:45 PM
    Arthur Vandelay
    2015 TRD Off Road
    They are. I tapped into the colored wires listed in the instructions. The tailgate opens with the passenger doors.
  10. Feb 2, 2016 at 10:36 AM
    Ryan.orr87
    Ryan.orr87 Well-Known Member
    Has anyone found a locking mechanism that allows to back-up camera to stay? I don't want to get rid of that thing.
  11. Feb 2, 2016 at 11:27 AM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    maybe im missing something, but if your looking for a locking actuator that will lock the tailgate AND you have a fact camera, pop and lock sells one.
    Ryan.orr87 likes this.
  12. Feb 2, 2016 at 11:29 AM
    bogginator
    bogginator Well-Known Member
    Marsh
    Cherokee County
    2015 Black DCSB XSPX
    It's a never ending $100-$200 a week thing & still going.
    The "pop and lock " keeps the back up camera.
  13. Feb 2, 2016 at 11:30 AM
    Do58
    if you get the right one.
  14. Feb 2, 2016 at 11:30 AM
    Do58
  15. Feb 2, 2016 at 11:32 AM
    Do58
    looks like they have one also that will allow you to get a new handle WITH a lock and key but you have to buy the camera clip. just did a quick look at the site. just a call away to make sure though
  16. Feb 6, 2016 at 11:52 AM
    kbob
    Kevin
    Punta Gorda, FL
    2015 White Tacoma
