Pop at engine area when shutting down 2013 taco, help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 100, Feb 22, 2013.
  1. Feb 22, 2013 at 10:08 PM
    100 [OP] I have 4 Dogs
    Texas
    2013 DCSB(Prerunner) TX Edition
    When I turn the truck off, I hear I vacuum sound then a small and faint pop noise coming from the engine. I got the truck with 160 miles and now it has1,700 miles, it still happens; everytime am shutting it off. I have not overreacted and taken it to the dealership , should I? Is this normal?
  2. Feb 22, 2013 at 10:11 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    Check engine light on?
  3. Feb 22, 2013 at 10:12 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    sounds like the smog pump. Apparently a normal noise for you new model guys.
  4. Feb 22, 2013 at 10:19 PM
    Texas
    No check engine light on, in the 1,700 miles it has total.
    QUOTE=tostidos;6485383]sounds like the smog pump. Apparently a normal noise for you new model guys.[/QUOTE]
    Why would this be an issue if in the past it was not? Why would it cause a small faint pop noise? Possible cycling still while in shutdown mode?
  5. Feb 22, 2013 at 10:19 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    When I owned my 2011 DC it didn't do this. I got my 2013 and it has been doing it since day one. From what I have been told from other members on this site, it's normal.
  6. Feb 22, 2013 at 10:21 PM
    Frissen
    Frissen Well-Known Member
    2013 PreRunner 2wd and i dont get this noise...
  7. Feb 22, 2013 at 10:23 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    maybe they changed the smog pumps?
  8. Feb 22, 2013 at 10:23 PM
    Texas
    On mine it happens which seems like every shutoff. Hot, cold, rain...etc. there are times I may not hear it, but It's there. Have you asked any technicians and/or dealership?
  9. Feb 22, 2013 at 10:24 PM
    Texas
    Weird, mine is a 2013 Prerunner as well, mine has that noise.
  10. Feb 22, 2013 at 10:25 PM
    Texas
    Any way we can verify this? It would be good to find out. This is obviously my first truck/Tacoma.
  11. Feb 22, 2013 at 10:27 PM
    95 taco
    95 taco Battle Born
    I'm not sure, maybe ask the dealer if the part #'s are different?
  12. Feb 22, 2013 at 10:28 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Its normal mine does it every day I got used to it
  13. Feb 22, 2013 at 10:29 PM
    Texas
    Was it the smog pump as others implying? or did you not look into it?
  14. Feb 22, 2013 at 10:30 PM
    sde780
    sde780 Well-Known Member
    2012 V6 DCLB : does this most of the time
  15. Feb 22, 2013 at 10:38 PM
    Texas
    Have you seen or heard a pattern of when it happens?
  16. Feb 22, 2013 at 10:57 PM
    sde780
    Short drives where the truck hasn't warmed up completely
  17. Feb 22, 2013 at 11:07 PM
    chaosbound
    chaosbound Member
    Seattle, WA
    Ex Cab V6 4x4 SR5
    I'm not exactly sure what causes the sound, but my 2013 V6 makes the same noise when shut off too. I wouldn't worry about it.
  18. Feb 23, 2013 at 12:29 AM
    MGMTacolover55
    Orygun
    floor Mats
    it could be the smog pump but I don't even know what that is I know the old term for it was secondary air injection
  19. Feb 23, 2013 at 3:49 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    My Truck does it also. It has about 600 miles on it now. When I shut it off, I thought the noise was coming from the clutch fan. I will have it looked at by the service dept. on my 5k service. It really doesnt bother me. I just find it odd. Gives the truck a personality.
  20. Feb 23, 2013 at 6:45 AM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
